Author Topic: V85TT observations after 1000 miles break-in  (Read 11621 times)
Offline rudyr
Re: V85TT observations after 1000 miles break-in
« Reply #30 on: May 16, 2021, 04:06:59 PM »
A Moto Guzzi dealer in Las Vegas Nv. Sent some info. On v85 tt travler, less than $12000. Sent him a email if that was out the door.  I’ve got  a couple free SW tickets I’ve got to use before fall.  Fly out ride back stop ok city and 1000 mile service.  Should not take a couples days.  We’ll see  what they say. Rudy
Online Vagrant
« Reply #31 on: May 16, 2021, 04:31:37 PM »
 bottle of single malt says he adds $2000 in BS fees then the tax. Buy elsewhere!
Online Moparnut72
« Reply #32 on: May 16, 2021, 05:16:28 PM »
I'll raise that bet to two bottles. My  $7,000 2019 V7lll was at list when they added on all their BS fees. I once priced a used Burgman at their Reno store. A $1500 scooter was then $3000 before tax and license. You won't save anything there.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #33 on: May 17, 2021, 06:40:37 AM »
Tell me move about the speedo/odometer change you did. Is it a tweak in GuzziDiag? Mine is off about 5%. Not bad, but annoying.
Manufactured a new rear tone wheel with less slots to feed a lower frequency.
find duplicates in csv online
That worked brilliantly, but the odometer now sensed a reduced number of revolutions so a consequently reduced amount of kilometres was registered... :sad:
Then there’s the gear indicator issues... :sad:
Online Vagrant
« Reply #34 on: May 17, 2021, 07:08:50 AM »
Huzo, what would happen if you were to reduce the front from a 19" to a 17"? Would it throw the computer out of wack especially for the Anti-lock portion. I have been considering that and a custom 1" lower rear shock to get my stubby old legs closer to the ground. I just use my bike as a road bike nowadays.
« Reply #35 on: May 17, 2021, 07:14:31 AM »
Maybe best mate if we discuss this on “V85 innacuracy” thread, so as not to hijack this one further.
Rough Edge racing
« Reply #36 on: May 17, 2021, 07:26:20 AM »
That is how long it take to get the butt broken in to the seat, and you also get more comfortable are reving the motor higher in lower gears.
 :boozing:
  Good explanation
Online Vagrant
« Reply #37 on: May 17, 2021, 07:42:04 AM »
Fine with me. Thanks
« Reply #38 on: May 17, 2021, 09:52:26 AM »
Why not just raise the forks combined withe the lowered shock?  That probably in my future as well to lower the bike.
« Reply #39 on: May 17, 2021, 11:07:02 AM »
That’s what I did.
I suggested he do the same.
Offline 45thparallelguzzi
« Reply #40 on: May 25, 2021, 01:30:02 PM »
I've definitely noticed that the 850 engine is in its' happy place in the upper half of the rev range. Dropping to 5th on the freeway doesn't feel right intuitively but the bike (and your hands) will appreciate it.
Online Trialsman
« Reply #41 on: May 25, 2021, 10:10:11 PM »
While you have the forks off unscrew the top caps and pour out the oil.  It is 7.5wt and causes the compression damping to be a bit harsh on bumps.  The fork will remain intact but you can slide down the tube to invert and drain the oil.  I measured 300cc of oil and replaced it with the exact same amount of 5wt.  I did this on my other V85 and it worked great.  One bottle is enough to do the entire job.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2025 Arctic Leopard Ex-800
« Reply #42 on: May 25, 2021, 10:43:54 PM »
Both forks the same..?
As I understood it, there is only damping on one fork so the internals are different, but your recommendation is put the same volume in both sides ?
Offline Phil/TX
« Reply #43 on: May 26, 2021, 09:38:43 PM »
My 2c, this is my 8th guzzi, from 1100 sport to 750 Breva, and hands down this is the best guzzi I have ever owned, on par with my 790 KTM Adventure for getting down the road, not as much power, but definitely handling and comfort , just not the same off road.
"You will seldom regret what you have done, but you will always regret what you have not"
2024 V7 Stone Corsa (850)
2024 Triumph Speed 400
20 Guzzi V85TT Coast Guard (super chicken)
23 V100 S Mandello ( wing man)
