Author Topic: 850-T-3 oil pan bolt pattern, a bit of a rhetorical question...  (Read 2064 times)
Offline radguzzi
So I went to have a peek at an 850-T nearby, I just went to see if, on an off chance that it would have one of the early T-3 engines.  Just because.
Well low and behold, I see this bolt pattern.
Now I am 99.99% certain that his tells me that it is in fact a filtered engine.  Correct...?  Thought I would ask the collective.
Thanks,
Rob
« Last Edit: May 14, 2021, 07:31:44 PM by radguzzi »
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline 73 sport
Re: 850-T-3 oil pan bolt pattern, a bit of a rhetorical question...
« Reply #1 on: May 14, 2021, 07:34:10 PM »
Is filtered good or bad?
Offline Gliderjohn
« Reply #2 on: May 14, 2021, 07:39:36 PM »
I am quite sure that all T-3s had filters. There should be a total of 18 bolts concerning the pan.
Back in central KS
Offline radguzzi
« Reply #3 on: May 14, 2021, 07:57:59 PM »
Good...
Oh I agree John,
I should have asked whether this bolt pattern could be a definitive as to whether there is a filter residing in that pan Without dropping it..?
Thanks,
rad
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
« Reply #4 on: May 14, 2021, 08:36:07 PM »
On pans with a filter there will be a circle casting mark between the fins at where the screen pick up is located.
Need a strait up shot for that one.
« Last Edit: May 14, 2021, 08:37:21 PM by guzzisteve »
« Reply #5 on: May 14, 2021, 08:37:17 PM »
Per the bolt pattern. 99.99 percent sure it should have a filter. Now if there is one in it??????
Offline radguzzi
« Reply #6 on: May 14, 2021, 08:50:51 PM »
That is a good point.  So the circle casting is a mark as to the location of the screen, not the spin on oil filter...?  And is that a certain mark as far back as 1974/75-ish...?  Even the T had the screen, no...?
I hate to drop that pan but I will if I must.
Thanks Steve.
Rob
Well, funny that you would mention that... the engine is stuck or at least the engine will not turn by jamming a gear and trying to roll it over.  Not sure if it is the engine locked or the gearbox.  Either way it will be a rebuild.
rad__
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
« Reply #7 on: May 14, 2021, 08:58:14 PM »
That is an oil filter pan. only 14 perimeter screws on non-filtered engines, 18 (including the 4 shown) on filtered engines.
Offline TOMB
« Reply #8 on: May 15, 2021, 03:49:46 PM »
Look at the front of the oil pan underneath the alternator area if it has a filter there will be three plug holes on the pan front the plugs are about 1/2 inch in diameter if you have plugsyou have a filter no plugs no filter
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
