Author Topic: V50 Rear Drive Oil Seal  (Read 1072 times)
Offline Scout63
« on: May 29, 2021, 09:50:30 PM »
I finally got tired enough of oil dripping onto the rear wheel to remove and disassemble my v50 rear drive.  What a pain.  It has to be completely dismantled to get to the wheel side large oil seal. I ordered a few gaskets and the seal from MG Cycle and I’ll be back wailing around town this week.
Ben Zehnder - Orleans, MA USA
Re: V50 Rear Drive Oil Seal
« Reply #1 on: May 29, 2021, 09:57:04 PM »
Yep, a lot more work than an older "big-block" rear drive.
Offline Scout63
« Reply #2 on: May 29, 2021, 10:26:56 PM »
Absolutely Charlie. On my G5 I just popped out the seal from the outside, cleaned up the housing and installed a new one.  I thought this would be the same. I couldn’t get a socket on the bolts holding the whole shebang together without pulling the bearing inner race.   Maybe I could have with an open end wrench, but it looked iffy.  Three hours and a bearing puller later it was all apart. At least it gave me a chance to clean everything up nicely.
Offline Off @ 90
  • Heron Head Heretic.
« Reply #3 on: May 30, 2021, 08:28:07 PM »
When you push the new seal in be careful not to go any deeper than flush with the casing. I made the mistake pushing too far and the seal can touch the ball race with resultant leak . There is no shoulder to stop it . Also polish the  lip seal contact area on the shaft .
Hope all goes well .
Duncan
Offline Scout63
« Reply #4 on: May 30, 2021, 09:49:36 PM »
Thanks for the tips Duncan. They will help.  Ben
« Reply #5 on: May 31, 2021, 06:56:23 AM »
Now, the inner seal will start leaking.  :evil: You thought the outer seal was hard to get to.. :smiley:
Albert Einstein
Offline Scout63
« Reply #6 on: May 31, 2021, 03:01:13 PM »
Should I just replace the inner seal now Chuck?  It’s right there.  I’ve got to go order it now...
« Reply #7 on: May 31, 2021, 04:16:07 PM »
I would replace it while you have it apart. Warm the housing and the outer race of the bearing will fall out, allowing access to the seal.
Online Pescatore
« Reply #8 on: May 31, 2021, 05:49:09 PM »
Hey Scout63, do you have pictures of the disassembly steps?
The workshop manual shows at least 5 different custom tools.  Seems like you used a bearing puller and some sockets?
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Scout63
« Reply #9 on: May 31, 2021, 09:46:43 PM »
Hey Pescatore:
I didn’t take any photos.  It comes apart pretty easily.  The only pain is that to get a socket on the bolts holding the drive assembly together you need to pull the bearing inner race.  I put a 13mm open end wrench on them but the purchase wasn’t good.  It needed a socket on an impact driver. There is a circlip around the shaft that I didn’t see at first.  A standard bearing puller of the clamshell type will pull the race:
https://www.harborfreight.com/bearing-separator-and-puller-set-62593.html.
Thanks for the tip Charlie. I’m hoping the outer race drops out with heat. I’d rather not have to stick a blind bearing puller in there.
Ben
« Reply #10 on: June 01, 2021, 07:00:24 AM »
While you are at it.. have a look at the shaft the inner seal rides on. Polish if necessary and don't use synthetic lube.
Albert Einstein
« Reply #11 on: June 01, 2021, 08:47:47 AM »
With fresh seals, using synthetic gear oil shouldn't cause any issues. I've always filled customer small-block rear drives with Bel-Ray Gear Saver Synthetic 85w140 and none have reported having any issues.
« Reply #12 on: June 02, 2021, 07:42:37 AM »
^^^^ the synthetic lube thing came from Sean Fader. He told me not to use it on the old small block rear drives, so I don't.  :smiley:
Albert Einstein
