Author Topic: Redline 10W-60  (Read 8500 times)
Offline SmithSwede
  • I don't want a pickle
Redline 10W-60
« on: June 02, 2021, 11:03:49 AM »
Redline makes a 10W-60 oil, and also a “motorcycle” 20W-60.
I contacted Redline and they advised that their 10W-60 contains 1225ppm zinc and 1375ppm phosphorus, which they say is plenty of protection for Guzzi flat tappet cam and lifters.
Just passing this along
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Re: Redline 10W-60
« Reply #1 on: June 02, 2021, 02:52:02 PM »
Has Guzzi ever said how much zinc they recommend Prescott?
Offline SmithSwede
Re: Redline 10W-60
« Reply #2 on: June 02, 2021, 06:54:08 PM »
Not that I’m aware of.
Guzzi specifies a SG oil, a rating which implies a fairly healthy dose of ZDDP.   I’ve read that 1200 ppm is a healthy dose; 1000 ppm or lower is getting marginal.  The more recent grades tend to have reduced levels in order to protect catalytic converters, and based on the assumption you are not running it in some antique tractor engine with highly loaded flat tappets.
So the concern is you might buy a modern oil that seems good, and has a rating that is supposedly “backwards compatible” with the older SG, yet not have a sufficient amount of the ZDDP.
You actually don’t want more than about 1800 ppm since that level fosters corrosion.
Like with a any oil related discussion, I don’t think this matters to 99% of people who will probably sell the bike after less than 20,000 miles.   The exception is probably hard core Guzzi riders who, no joke, plan to run their bike to 100,000, 200,000 or more miles.
Offline sign216
Re: Redline 10W-60
« Reply #3 on: June 02, 2021, 07:47:47 PM »
Swede,
I'm impressed that Redline got back to you w the data.
I bit the bullet and got some ZDDP additive.  With that, I can buy a wider variety of oils.
Especially since Guzzi dry clutches don't limit us to motorcycle oils, so we can get oils w friction modifiers.
Joe
« Last Edit: June 03, 2021, 08:20:02 PM by sign216 »
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline SmithSwede
Re: Redline 10W-60
« Reply #4 on: June 02, 2021, 08:57:06 PM »
Swede,
I but the bullet and got some ZDDP additive.  With that, I can buy a wider variety of oils.
Joe
Joe.  I was surprised as well.   I sent a random email to Redline last night about 11:00 pm, expecting no answer or maybe a non-answer 10 days later.
Nope.  First thing this morning I got a cogent response.  I’m impressed.
GeorgiaGuzzi
Re: Redline 10W-60
« Reply #5 on: June 02, 2021, 09:02:11 PM »
I use Valvoline VR1 20w-50. 1300 ppm Zinc and 1200 ppm phosphorus. Bike seems happy.
Offline chrisfer
Re: Redline 10W-60
« Reply #6 on: June 03, 2021, 12:02:36 AM »
Thank you for this feedback  :thumb:
2022 V7 850 Stone - 2019 V7 III Carbon - 2004 V11 RossoCorsa - 2002 V11 Le Mans - 1995 750 Nevada
Offline Noguzznoglory
Re: Redline 10W-60
« Reply #7 on: June 03, 2021, 06:38:18 AM »
This is what I switched to since I can’t find the eni/agitprop oil any more. On the shelf in most of the big box parts stores
93 750 Nighthawk
73 Honda CB350
73 Honda CL450
04 Breva 750
15 Norge
16 VERSYS 650
elvisboy77
Re: Redline 10W-60
« Reply #8 on: June 03, 2021, 06:57:02 AM »
I think Guzzi switched its recommendation to Castrol not too long ago.  That is what my manual calls for.
Online Ncdan
Re: Redline 10W-60
« Reply #9 on: June 03, 2021, 07:31:44 AM »
Mobil 1 full synthetic 15-50, heavy duty, in every bike for many years and miles with absolutely no issues noted. Find at Wally World (Walmart)
For around 25 bucks for a 5 quart jug👍
Offline egschade
Re: Redline 10W-60
« Reply #10 on: June 03, 2021, 07:55:51 AM »
Been running Motul 8100 X-Power 10W60 in my last 2 Guzzis and plan to use it on the V85TT's first service. Can't find a spec sheet with Z and Ph info though...
ACEA A3 / B4 - API SN / CF (Backwardly compatible with API SJ, SL, SM)
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline Roebling3
Re: Redline 10W-60
« Reply #11 on: June 04, 2021, 11:06:37 AM »
Thank you SS, -and others, for sharing. Seems a very good application for 650cc 4 valve engines   R3~
Offline sib
Re: Redline 10W-60
« Reply #12 on: June 04, 2021, 02:29:06 PM »
That's true, but the spec still calls for API grade SG.  If you believe that the newest grade, SN, supersedes or "includes" SG, then go ahead and use it.  If you suspect that the newer grades strive to minimize catalytic converter poisoning by Zn or P, then you might want to stick with oils of the recommended API grade SG.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Two Checks
Re: Redline 10W-60
« Reply #13 on: June 04, 2021, 07:12:16 PM »
Guzzi recommends Castrol because BP pays for that recommendation.
Why do people call lifters tappets? They don't tap anything and if they do you have a big problem!
1987 1000 SPII "Il Duce' II"
Offline SmithSwede
Re: Redline 10W-60
« Reply #14 on: June 04, 2021, 07:48:02 PM »
The term “tappet” dates back to 1715 as a reference to part of the valve system on the Newcomen steam engine.  The tappets were actuated by the plugtree.  And that way, the poor little boy named Humphrey Potter didn’t have to work the valves manually anymore.
Hey, you asked!  And it that’s good enough for Newcomen, it’s good enough for me.
Offline Two Checks
Re: Redline 10W-60
« Reply #15 on: June 05, 2021, 12:48:43 PM »
Thank you for that. But, that begs these questions:
What part did he call the tappet, and;
Why don't people call roller lifters tappets?
The reason I ask is all the tapping is done at the valve/rocker interface.
Not a criticism, just curiosity.
Online Bulldog9
Re: Redline 10W-60
« Reply #16 on: June 05, 2021, 12:54:45 PM »
Good to know of another high Zinc option. I use Brad Penn or VR1 in my flat tappet motors.
MGNOC#23231
elvisboy77
Re: Redline 10W-60
« Reply #17 on: June 05, 2021, 04:39:36 PM »
Are you saying Guzzi's recommendation is wrong?  Please enlighten me.
Offline SmithSwede
Re: Redline 10W-60
« Reply #18 on: June 05, 2021, 10:24:53 PM »
Two Cheeks.   Why do you hate little Humphrey Potter?  His life was improved by these tappets you denigrate.
 :whip2:
Re: Redline 10W-60
« Reply #19 on: June 06, 2021, 08:24:23 AM »
Not at all. Through automotive history, oil companies have paid manufacturers to "recommend" their products.
Castrol is new for Guzzi.. not too long ago, it needed to be Agip.  :smiley:
Back in 1930, Sinclair paid Monocoupe to recommend their gas and oil. <shrug> I have a Sinclair gas pump in front of the hanger.. :grin:
Online bad Chad
Re: Redline 10W-60
« Reply #20 on: June 06, 2021, 12:09:59 PM »
Of course Chuck is right.  Guzzi like most Mfg recommend a particular brand for the reason the former cow milker just said, but they are just that recommendations, not demands.  Guzzi says as long as it meets the requirements stated, it doesn't matter who's name is one the bottle.
1988 YX600 Radian
Offline moto-uno
Re: Redline 10W-60
« Reply #21 on: June 06, 2021, 12:19:30 PM »
 As long as there is clearance (anywhere) in a valve train the term tappet ( it is a tapping sound after all ) seems appropriate .
Most roller lifter valve trains are hydraulic and by nature maintain zero lash , so no tappey tappey :) . Peter
Rough Edge racing
Re: Redline 10W-60
« Reply #22 on: June 06, 2021, 05:12:36 PM »
Try to get Castrol to tell you how much ZDDP is in their oils...Do they list it on their websites.
Online bad Chad
Re: Redline 10W-60
« Reply #23 on: June 06, 2021, 05:36:22 PM »
Beats me?
1988 YX600 Radian
elvisboy77
Re: Redline 10W-60
« Reply #24 on: June 06, 2021, 05:55:52 PM »
And yet, in spite of that, it is Guzzi's recommendation.  Hmmm I wonder why that is?
Rough Edge racing
Re: Redline 10W-60
« Reply #25 on: June 06, 2021, 06:12:53 PM »
 The big deal about ZDDP comes from hot rodders and racers running older tech OHV V8's. Open valve spring pressures can be 250 pounds or as much as 750 pounds...How much sping pressure is in a stock pushrod non high performance Guzzi? Generally a guy rebuilding a stock flat tappet engines used a High ZDDP break in oil and then a better mineral oil, nothing special...But proceed at your own risk...
 Oh, flat tappets are not flat and the damn things are lifters  :azn:
Online Bulldog9
Re: Redline 10W-60
« Reply #26 on: June 06, 2021, 08:36:52 PM »
It's all semantics. Generally when I refer to a lifter as a flat tappet I'm referring to a solid non roller lifter. Others will just call it a solid lifter. Obviously, flat tablets or solid lifters tend to be harder on the cam then I hydraulic or roller lifter so a high zinc content oil is helpful to protect the camshaft and lifter itself from scoring.
I'm not exactly sure for hydraulic lifters, but I do know that solid lifters or tappets tend to spin in the bore increasing the need for high sink content. Roller lifters obviously do not spin in the bore.
And as everyone knows.. valve tap on a Moto Guzzi is a sign of a healthy motor :-) what's that saying? Loud valves save lives?
MGNOC#23231
Rough Edge racing
Re: Redline 10W-60
« Reply #27 on: June 07, 2021, 02:54:12 AM »
 The crown on the lifter, both solid an hydraulic, the lifter being off set to the cam lobe and the taper of the lobe all contribute to lifter spin...
  The millions of Jeeps on the road with the OHV inline six have so called flat tappets. The engines are noted for very long life...I doubt many owners are concerned with oil additives and just use whatever ....It all depends on the grind of the cam..
Re: Redline 10W-60
« Reply #28 on: June 07, 2021, 03:55:52 AM »
 I always thought they were called tappets because Gork the alien from the planet Gesundheidt called them tappets .
Offline John Warner
  • Growing old is mandatory, growing up is not . . .
    • Stelvio/V85 Owners Group FB
Redline 10W-60
« Reply #29 on: June 07, 2021, 04:05:31 AM »
Tappet
Pronunciation /ˈtapɪt/
NOUN
A moving part in a machine which transmits motion in a straight line between a cam and another part.
They don't 'lift' anything, not directly at least.
Why not call the Push-Rods and the Rockers 'Lifters' as well, and the Cam(s) for that matter?
Doc out . . .
Stelvio Owners Group on FB ~ https://www.facebook.com/groups/888995181188209/?fref=nf
