Author Topic: Redline 10W-60  (Read 8541 times)
Rough Edge racing
Re: Redline 10W-60
« Reply #30 on: June 07, 2021, 05:14:29 AM »
 the lifter directly lifts the pushrod...With a cam mechanism the tappets or lifters are also known as followers...But generally a follower has roller acting on the cam.
Offline sib
Re: Redline 10W-60
« Reply #31 on: June 07, 2021, 08:23:50 AM »
And yet, in spite of that, it is Guzzi's recommendation.  Hmmm I wonder why that is?
Note that MG's full recommendation is not just any Castrol 10W60 but Castrol 10W60 API SG.  That implies that it is a high-ZDDP oil.
« Last Edit: June 07, 2021, 08:24:19 AM by sib »
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Two Checks
Re: Redline 10W-60
« Reply #32 on: June 08, 2021, 02:31:51 AM »
Quote from: moto-uno on June 06, 2021, 12:19:30 PM
As long as there is clearance (anywhere) in a valve train the term tappet ( it is a tapping sound after all ) seems appropriate .
Most roller lifter valve trains are hydraulic and by nature maintain zero lash , so no tappey tappey :) . Peter
Matters not if solid or hydraulic, if they are flat people call them tappets.
1987 1000 SPII "Il Duce' II"
Offline Two Checks
Re: Redline 10W-60
« Reply #33 on: June 08, 2021, 02:44:03 AM »
Quote from: Rough Edge racing on June 06, 2021, 06:12:53 PM
The big deal about ZDDP comes from hot rodders and racers running older tech OHV V8's. Open valve spring pressures can be 250 pounds or as much as 750 pounds...How much sping pressure is in a stock pushrod non high performance Guzzi? Generally a guy rebuilding a stock flat tappet engines used a High ZDDP break in oil and then a better mineral oil, nothing special...But proceed at your own risk...
 Oh, flat tappets are not flat and the damn things are lifters  :azn:
And how many problems did Guzzi have with hydraulic lifters?
People have had problems with stock non hi perf engines upon break in due to lack of zinc in oil.
In fact, on engines with high lift/high ramp rate cams they usually have dual valve springs. It is recommended break in is done with only one spring installed.
Offline berniebee
Re: Redline 10W-60
« Reply #34 on: June 08, 2021, 07:57:51 AM »
I always thought they were called tappets because Gork the alien from the planet Gesundheidt called them tappets .
Nah, that's a rumour started by Awchooo, the Gesundheit leader. Tappets were invented on the planet KlickshueThreeFour by Phred Azzstare.
(Tap it. Click shoe...Never mind.)
