Author Topic: 77 convert  (Read 12201 times)
Offline twodogs
77 convert
« on: June 08, 2021, 01:04:10 PM »
Well I started to play with the new to me convert, so far everything is looking pretty good to me even though I'm not sure of a lot of it, I have a can of deoxit and will clean up everything with the wiring but so far what I've played with has been clean. I have all the gaskets and crush washers and fluids except trans fluid, I'm not sure what works the best since simple Dexron is no more, any help there would be of a great help.I sold the g5 that I had for a little bit to a member here and it sounds like he has had to build it from the ground up and I thought the bike was fine if that tells you anything  :violent1: so I'm open to any suggestions. Thanks ahead of time.
Bruce
« Last Edit: June 08, 2021, 02:16:54 PM by twodogs »
1983 Honda CB1100F
2024Triumph 400 Speed x2
Offline TOMB
Re: 77 convert
« Reply #1 on: June 08, 2021, 01:21:53 PM »
My convert is a 1977 I've been using the Napa ATF in the picture below over 40,000 miles I plan at the end of the year to change it over to the ATF from Valvoline the max life give it a try other people will chime in from what they've used suggest don't do that it'll blow up and leave your parts all over the road you should use  your good judgment and go forward from there.
Besides you don't know if it has ever been changed so that's one item to consider and if it has been changed and you have no history you really don't know what's in there to begin with you should good judgment things will work out and others will chime in
TOMB
« Last Edit: June 08, 2021, 01:27:12 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline twodogs
Re: 77 convert
« Reply #2 on: June 08, 2021, 02:23:18 PM »
Thanks TOMB, the po told me that he had changed all the hoses and seals? But he also said he put type F back in it, I was told it would be ok but it don't sound right to me so I'm going to flush the system, where is this mesh screen that is supposed to be cleaned?
Bruce
1983 Honda CB1100F
Re: 77 convert
« Reply #3 on: June 08, 2021, 04:08:18 PM »
I've been using the same thing as TOMB - the NAPA or similar Dex III/Mercon. I have some Redline D4 ATF that I plan to try soon. Not sure I'd use Type F.
The screen to clean is part of the largest/lowest hex plug on the tank.
Offline twodogs
Re: 77 convert
« Reply #4 on: June 08, 2021, 04:35:15 PM »
Thanks Charlie, I'll get some of  it tomorrow, I hate to ask you or TOMB but what earl are you 2 running, I don't want to start a thread. I have the 7100 motul 10w60 but was told not to run full syn.
Bruce
1983 Honda CB1100F
Offline spmoto
Re: 77 convert
« Reply #5 on: June 08, 2021, 05:04:55 PM »
Hey Bruce,
I can't speak to the ATF question, but as far as earl goes I've been using Mobil One, stem to stern, for decades based on the recommendation of Manfred Hecht at of Raceco fame. This includes many Guzzi's of similar vintage to yours.
Steve M
Offline twodogs
Re: 77 convert
« Reply #6 on: June 08, 2021, 05:39:48 PM »
Thanks Steve, that's all I ever run in my Harleys when I had them, I know some here have been running Guzzi for alot of miles and I figured I would follow suit  :boozing:
1983 Honda CB1100F
Offline TOMB
Re: 77 convert
« Reply #7 on: June 08, 2021, 06:27:23 PM »
@twodogs
For oil usage
Engine Mobil 1 15-50 syn  (Walmart)
Gearbox Mobil 1 75-90 syn (Walmart- Auto zone Etc.) DONT OVERFILL
Rear end Diff Mobil 1 75-90 syn (same as above)
ATF usage see my response above
For your own piece of mind  (CHECK TO SEE IF YOUR BIKE HAS THE NEWER TYPE OF FLYWHEEL) YOU'LL BE HAPPY IF IT DOES.
the earlier flywheel was prone to disintegrating.
Look in my signature below for the bikes and mileages , Mobil 1 products was used in every one .
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
Offline twodogs
Re: 77 convert
« Reply #8 on: June 08, 2021, 07:40:38 PM »
Thanks TOMB, next question, how much do each hold? Notice a pattern here, no manual  :violent1:
Thanks.
Bruce
1983 Honda CB1100F
Offline Cal3Me
Re: 77 convert
« Reply #9 on: June 08, 2021, 10:01:46 PM »
Bruce needs to get a copy of Guzziolgy for all his info on his new bike ............ :boozing:
TMS
Re: 77 convert
« Reply #10 on: June 08, 2021, 10:24:59 PM »
I just use Rotella T4 in the engine, Bel-Ray Gear Saver in the transmission and rear drive. Capacities are in the owner's manual:
https://www.thisoldtractor.com/mg_manuals/owners_manual_v1000-i-convert_1975-06_en.pdf
Offline twodogs
Re: 77 convert
« Reply #11 on: June 09, 2021, 04:53:33 AM »
Doh! Thanks for the reminder, I totally forgot I had guzziology, now I have to remember where I stored it.
1983 Honda CB1100F
Offline chuck peterson
Re: 77 convert
« Reply #12 on: June 09, 2021, 09:40:10 AM »
I’d suggest…. :popcorn:
Wait on the atf fluid change. Spec is once every 16k, or some such. It’s not an immediate concern if you’re moto-tating down the road and it’s a good looking red. The older trans fluids worked better, it seemed to me. My 2nd vert w new fluids ranged 32-35 mpg, while my first was a solid 42mpg all the time
However, someone recently posted about checking for water in the atf tank. Great idea. H2O is heavier. Never considered this as a possibility
It’s possible whatz in there now could be working better than new fluids
Ymmv…my experience was 10 years ago, not with these two newish fluids
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline ozarquebus
  • Grand Canyon Pack Rat
  • Riding since 1979
Re: 77 convert
« Reply #13 on: June 09, 2021, 10:02:29 AM »
This question has probably been asked before. Has anyone ever experimented with adding pure silicone oil to the ATF in a Convert?
 Convert Hangar Queen
Offline twodogs
Re: 77 convert
« Reply #14 on: June 09, 2021, 10:33:28 AM »
I already have the rottela t4 and just picked up the valvoine max atf, never heard anything about running the silicon. After I finish up on the wiring clean up I'm going to start on the fluids, everything looks good so far. I went to title the bike and it got flagged, they say it has been purged from the system, so now I wait just like the 76 they have to make sure it's a motorcycle  :violent1:
Bruce
1983 Honda CB1100F
Offline twodogs
Re: 77 convert
« Reply #15 on: June 09, 2021, 11:12:34 AM »
Well I pulled the front cover and everything to me looks good, what do you guys think? I talked to the PO and he said he had it all serviced and went through the air filter box with a new filter, I'm still going to change the fluids though  :boozing:
1983 Honda CB1100F
Offline twodogs
Re: 77 convert
« Reply #16 on: June 09, 2021, 11:51:09 AM »
Inspection plug out, is this good or bad?
Sorry, I'm trying to take pics with a iPad.
Bruce
1983 Honda CB1100F
Offline TOMB
Re: 77 convert
« Reply #17 on: June 09, 2021, 02:47:54 PM »
@twodogs
Looking at your pictures i would say you have the later flywheel
It one of the three types that i know of
1. Heavy with a separate bolt on starter ring. I believe this is what you have. Good
2. Heavy flywheel with the starter ring (teeth ) machined directly to the flywheel.   .This is the version that I'm using. Good
3. The original version. This is the one you don't want.  Bad
Ohers may disagree but that's my 2cts.
TOMB
« Last Edit: June 09, 2021, 02:49:56 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
Offline twodogs
Re: 77 convert
« Reply #18 on: June 09, 2021, 05:41:20 PM »
Thanks TOMB, that's good to know, plus I found my guzziology book, I put it away after I got it because it was not really for the newer models but now it is starting to make sense  :bike-037:
Bruce
1983 Honda CB1100F
Offline twodogs
Re: 77 convert
« Reply #19 on: June 10, 2021, 03:14:32 PM »
Well I buttoned everything back up and went down the street and back a few times and it did not seem like it was charging, so I'm trying to put the meter on it and rev it up by myself and only got 12.7 so I went back in and unplugged the 3 wire connection which I should have done the first time but it looked so good, and I found the whole back side melted, so I replaced the ends and wala it is charging at 14.7 at a higher rev.now I'm just waiting on dot to give me a plate for it so I can give it a proper test ride.  :boozing:
Bruce
1983 Honda CB1100F
Offline jguzzi
  • 1971 Ambassador, MGNOC# 11324
Re: 77 convert
« Reply #20 on: June 10, 2021, 03:39:55 PM »
This is a great thread for us Convert owners. Pics are really helpful.  Twodogs can you tell me where your 2 throttle cables enter under the tank area.....I can see they are zip tied on the spine but I am wondering if they enter at the front of the tank in the open area near where the key/ignition is or under the tank on the side.  Also, TOMB can you tell me what you looked at to determine the flywheel?  Mine is 1978 so I assume it is the latter one.....can you tell by looking in the inspection hole?
Re: 77 convert
« Reply #21 on: June 10, 2021, 03:52:14 PM »
I too believe you have the heavy FW. This is the one with ring as part of the FW
The early light flywheel has a narrower edge, seen here, ignore the tabs, I put those on to trigger the FW sensor when I put it on an EV 1100 motor to build the SPEVert.
SPEVert,
Offline twodogs
Re: 77 convert
« Reply #22 on: June 10, 2021, 04:21:16 PM »
Hi jguzzi, the po had it set up like this and then split under the tank, nice foto, love that look.
Bruce
1983 Honda CB1100F
Offline twodogs
Re: 77 convert
« Reply #23 on: June 13, 2021, 11:48:22 AM »
Well I had this windshield laying around for about 8 or 9 years that I took off the wife's sportster when I sold it and the kid that bought it didn't want it, so I pulled it off and kept it, well today I was wondering what it would look like on the convert, the bottom is blacked out so it kinda hides the breadbox in front.I think it was a Memphis shade but I can't remember, so what do you folks think  :boozing:
Bruce
1983 Honda CB1100F
Offline brider
Re: 77 convert
« Reply #24 on: June 14, 2021, 12:04:15 PM »
Notice the additional non-factory brazing around the center mounting boss, at the juncture between the ~2-in diameter boss and the flywheel pan. This is what I did on my '77 Convert, in an effort to still use the lighter failure-prone flywheel. People said you could feel the difference between the lighter flywheel and one of the heavier later versions, but I couldn't. It is really amazing that MG let the lighter flywheels leave the factory without this critical reinforcement. Seems to me it would have been MUCH cheaper production-wise to just add this bit of reinforcement, rather than commit to machined-aluminum flywheels.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Offline Don G
Re: 77 convert
« Reply #25 on: June 14, 2021, 12:19:07 PM »
Guzzi is famous for letting half baked stuff out the door, just be glad that they finally rectified the flywheel problem, now for the Hokey pump drive.........   DonG
Re: 77 convert
« Reply #26 on: June 14, 2021, 12:46:32 PM »
On the shield.
The question is....Do YOU like it??
Looks fine to me. I'd go with it. I'm pretty sure Memphis Shades. They do a lot of shields with the colored lower section.
Online Bulldog9
Re: 77 convert
« Reply #27 on: June 14, 2021, 08:10:50 PM »
Looks great!
I concur that you have the heavy drive plate. I have a 76 which has the thin plate, but AFAIK, it is the original and unmolested w/ 45K miles now. Some believe that the center plate tears out when the unit is not perfectly aligned. Dave R (Guzziology) reported about a few that lasted the life of the bike.  I have an heavy unit on the shelf if I ever need, or end up tearing the bike down.
I also have a small bar mounted windscreen I recycled out of my 'boxoparts' I like how the darker section bridges the gap from the headlight to the gauge.
If you (or anyone else) are interested I have a windjammer, king/queen seat and rear luggage rack with the lollipop turn signals gathering dust. I'm keeping the DB Bags and Bench seat, but won't use the Fairing, rack or K/Q seat. Fairing has the wire harness.
Some pics of the items mounted before I removed.
MGNOC#23231
Offline twodogs
Re: 77 convert
« Reply #28 on: June 15, 2021, 08:37:30 AM »
I won't know if I like the shield till I ride it, I'm still waiting on the plate from dot. I think I'll drop it down closer to the headlight bucket like on yours bulldog, I like your bags better, mine are about the size of a kids lunch box. :boozing:
Bruce
1983 Honda CB1100F
Offline twodogs
Re: 77 convert
« Reply #29 on: June 19, 2021, 12:44:25 PM »
Ok, so I forgot to post when I was changing the fluids the transmission where the clutch is had a bit of metal on the magnetic fill plug and when I drained it there was a bit more in my container, is this something to be concerned about? All the fluids I drained looked like everything had just been done and looked real clean except for some metal swarf, what do you folks think?
Bruce
1983 Honda CB1100F
