Author Topic: Wondering if this saddle will fit seamlessly onto a 2010 V7 Classic  (Read 3088 times)
Offline sstone14
https://www.af1racing.com/OEM-Moto-Guzzi-Saddle-Rough-Black-2B004968000C1
Total newbie here, just fyi. It seems like it will, based on the language of the listing, but I just wanted to double check here with y'all before making the purchase.
Thanks!
'10 V7 Classic
Re: Wondering if this saddle will fit seamlessly onto a 2010 V7 Classic
« Reply #1 on: June 15, 2021, 09:08:48 AM »
Thanks!
It says it fits the v7 classic, I dont doubt AF1, they are probably the biggest seller of new OEM stuff in the USA
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #2 on: June 15, 2021, 09:11:09 AM »
Keep scrolling down on that page and you’ll have your answer—which is a ‘yes’ - all modern small block V7s have the same frame (aside from a couple differences like rear shock mounts) and seat mechanism, although not sure about the new 850 version.
« Last Edit: June 15, 2021, 09:12:48 AM by Dirk_S »
Online Dirk_S
« Reply #3 on: June 15, 2021, 09:15:48 AM »
Also - welcome to the forum! Don’t be afraid to introduce yourself over on the dedicated thread and share a location in your profile—never know when you might have a nearby Guzzisti around the corner willing to help ya out!
« Reply #4 on: June 15, 2021, 09:26:41 AM »
I've had about let's see, carry the one... uhhh 6 different seats on my two smallblocks so far (MK I and MKIII).
The ONLY fitment problem I've run into was the Corbin is too narrow at the rear to fit on the V7III Dark, because it's a model with the smaller chopped rear fender which means it also has a sub-frame attached to the frame right behind the shock/fender mounts. The mounting bolts for the sub-frame interfere with the Corbin seat pan.
That's the only thing I've found to look for so far, and it's probably limited to Corbin and the late-model bikes without the full rear fender.
Can't say about the 850 yet.
Offline sstone14
« Reply #5 on: June 15, 2021, 10:42:55 AM »
Thanks! Yeah, I did see that, I just wasn't sure about the precise meaning of the language "can be fitted as an accessory to"--i.e. if that meant it was ready to just snap right in, or if some additional work "fitting" it would be required before being able to attach it to the bike.
'10 V7 Classic
Offline dirtiegirtie
« Reply #6 on: June 15, 2021, 10:51:33 AM »
Just an FYI - I asked AF1 about another seat not long ago.
My question was, "Hi - I'm interested in the "OEM Moto Guzzi V7 Racer Saddle - 898178". I have a 2015 V7 (I'm in the USA, so it is NOT a V7 ii); will this seat fit my bike?"
Within 24 hours I received, "Yes, all classic, I, II, and III seats are interchangeable with each other.  Lots of styles thru all those years. Only the new 2021 V7 850 is a different seat fitment."
Excellent customer service. I'm still waiting for it to come back in stock, but pretty sure I'll end up with that seat.
« Reply #7 on: June 15, 2021, 07:15:55 PM »
Fit, yes.  Fit as well as the seat that came on the bike?  Maybe.  The racer seat I have on my bike doesn't fit up at the tank as nicely as the seat that came with the bike.  Only the most critical eye would notice, but if you are even slightly OCD you will definitely notice.
« Reply #8 on: June 16, 2021, 07:46:56 AM »
If I understand your comment correctly, I think your comment is more about the quality (precision fitment) of a specific seat vs fit of a seat across years/models.
I've only ever had Stock, Corbin, and Mustang seats on my bikes... all of which are high quality... so I never thought about 'sloppy' fitment. I think my CDO would bother me just as much as you... good to know!
*I have CDO - It's like OCD, but the letters are in proper alphabetical order.
« Reply #9 on: June 16, 2021, 08:01:48 AM »
FYI - I think my Corbin has more of a gap than stock on my MKI Stone.
Offline Ncdan
« Reply #10 on: June 16, 2021, 11:40:50 AM »
What Dirk said👍
« Reply #11 on: June 17, 2021, 06:08:33 AM »
OP! take a look at TWA's thread on the front page today... you can see how "mismatched" his seat it! LOL Looks sharp as hell
« Reply #12 on: June 19, 2021, 06:27:25 AM »
Looks good, but doesn't full mate up to the tank the same way the Carbon seat does.
