best way to remove brake lever bushings?
Topic: best way to remove brake lever bushings? (Read 1391 times)
ChrisG
Hatchling
June 23, 2021, 11:58:30 AM »
96 Cal 1100. I think I could pry and pound, but that would be easier with a third hand. Also, I have the stock replacement - what's that coating on the inside?
Current: 2022 V7 Stone 850
Gone: 96 California 1100i, 2008 Breva 750, 06 Breva 1100, 2007 Sportster,1971 BMW 75/5, 1969 Triumph Trophy
Forgotten: A couple Hondas, a Yamamaha, ??
Antietam Classic Cycle
Happily stuck in the past.
Re: best way to remove brake lever bushings?
Reply #1 on:
June 23, 2021, 12:17:42 PM »
Hand lever or foot lever? I use sockets - one socket slightly smaller than the o.d. of the bushing and another larger than the o.d. Then either the vise or arbor press to push the bushing out.
ChrisG
Hatchling
Reply #2 on:
June 23, 2021, 12:32:27 PM »
Foot lever. The bushing is really thin - more like a tube of sheet metal, so it's not something i can really push out conventionally . . . . .I think I'll be able to slide the new one in with a couple of washers and a bolt . . . . .
Thanks!
ChrisG
Hatchling
Reply #3 on:
June 23, 2021, 12:35:14 PM »
It's the same deal as on the clutch lever ...
Stevex
Reply #4 on:
June 23, 2021, 01:27:01 PM »
Use a junior hacksaw blade with about 24 tpi and cut a groove in the bush without touching the main assembly.
You shouldn't even need to go all the way through, just close. It should then push out relatively easy.
Matt Story
Flint, MI
Reply #5 on:
June 23, 2021, 03:15:53 PM »
Don't have that bike, but the bushing style sounds like a type we use industrially. The ones I'm thinking of are made in very thin wall steel tubes (butted seam parallel with axis). The most prevalent brand is Glacier Garlock. The linings come in a variety of plat-able plastics, usually some variation of Teflon depending on the application, flooded, type of lube or dry. A fairly universal type by Garlock is the DU series. They are available in a wide range of inch and imperial sizes. These tend to have higher load bearing capacity then traditional bronze bushings and save space.
'75 850T - First & only owner
'77 Honda CB750 Supersport
'02 BMW R1150RT
Flint, MI
ChrisG
Hatchling
Reply #6 on:
June 23, 2021, 05:40:08 PM »
I ended up prying it out. Worked, but messy. Thanks!
larrys
Reply #7 on:
June 24, 2021, 07:34:08 AM »
Ouch! I pressed mine out with a deep socket of a slightly smaller OD. I bought a shifter and a brake pedal to modify, and needed the bushings out so the chrome shop could strip them.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Rich A
Reply #8 on:
June 24, 2021, 08:12:55 AM »
Lee Bruns was making replacement bushings, not sure if he still does.
Rich A
