Author Topic: Sport 1100 Sump removal  (Read 1795 times)
Offline corsajim
« on: July 01, 2021, 09:31:16 AM »
Another problem today, changing the oil and giving it a service, however the sump refuses to budge, all perimeter bolts have been removed. This bike has sat and done very little for at least 8 years so sump may not have been off in that time.
Thks
Jim
1100 Sport Carb
Laverda RGS Corsa
Offline Murray
Re: Sport 1100 Sump removal
« Reply #1 on: July 01, 2021, 09:33:36 AM »
There are four hex head i.e. not cap screws in the "middle" towards the front and rear. If you defiantly got all the screws out and its still be stubborn a block of wood against it and a thump from the side with a hammer (on the block of wood) gets it moving.
« Last Edit: July 01, 2021, 09:35:25 AM by Murray »
Offline corsajim
« Reply #2 on: July 01, 2021, 09:44:45 AM »
Thanks Murray, I've definitely removed all the perimeter bolts, are there bolts on the very bottom of the pan, I'll have another look. Thanks
1100 Sport Carb
Laverda RGS Corsa
jwinwi
« Reply #3 on: July 01, 2021, 09:45:05 AM »
Need to remove 18 bolts, 4 are not around the perimeter.
Here's a manual:  https://guzzitek.org/gb/ma_us_uk/1100/1100SportCarb_Atelier(I_GB).pdf  Thanks to guzzisteve.
« Last Edit: July 01, 2021, 10:07:45 AM by jwinwi »
Offline corsajim
« Reply #4 on: July 01, 2021, 10:07:00 AM »
Thanks guys, just found the 4 missing ones, all good.
Found what looks like a staple in the bottom of the pan
1100 Sport Carb
Laverda RGS Corsa
Offline Murray
« Reply #5 on: July 01, 2021, 10:11:28 AM »
Not anything I recognize if the strainer is clean its likely just what you called it, a staple.
