Author Topic: Chinese carbs on G5 - need info  (Read 2310 times)
Offline crabbymoto
    • Empire Classics
« on: July 11, 2021, 09:38:53 PM »
My carbs are the original 30's and worn out.  I've searched and found references to people having good luck with some of the Chinese knock off carbs but only references not which ones and which manifolds.  I'd love to put new dellorto's on, but the funds don't allow right now.
Anyone have good recommendations for carbs and where to get manifolds to properly install?
It's a bone stock 1980 G5 V1000.  See pics for carbs and manifolds.
Thanks for any help!!!!
Offline Scout63
Re: Chinese carbs on G5 - need info
« Reply #1 on: July 11, 2021, 10:31:23 PM »
Those carbs look pretty good.  Are the slide housings worn?  Vapor blasting and new floats,  jets and gaskets and maybe you are in business.  Then again all of that from Dellorto might cost more than new carbs.  I would avoid knockoffs. Best of luck.
Ben Zehnder - Orleans, MA USA
« Reply #2 on: July 11, 2021, 10:31:56 PM »
You could contact SUDCO - the Mikuni carb supplier and ask if they can reccommend a type of Mikuni and the reccommended jetting.
I have a Moto Morini 500 that the prevous owner fitted with new Mikuni carbs from SUDCO, he gave them the motorcycle make and model and motor type (V twin, air cooled), the displacement, bore and stroke, claimed horsepower and they provided complete carbs jetted, and they worked very well out of the box, I had to change pilot jets due to my location / altitude, carbs were set up for sea level.
sudco@sudco.com
Offline cliffrod
« Reply #3 on: July 12, 2021, 07:32:45 AM »
All i can say is that pay for what you get.
China carbs might work ok as shipped.  Good luck. You might only have to spend 2-3 hrs per carb to make it possible to install real Dellorto or mikuni jets & such to make it actually operate better than the worn out carbs you have.  Btdt.  If you are only having tuning issues with your dellortos and cannot sort them, odds are that the China carbs are probably going to be just as if not more trouble.   If they wear out prematurely, oh well...  And when you sell the bike (or keep it forever) you'll have lots of opportunities to explain to either buyers or peanut gallery members why you ditched good carbs for those non-original parts that won't help resale value.
A pair of dellortos or real Mikunis from Sudco will be much better money spent imho.
« Reply #4 on: July 12, 2021, 07:51:07 AM »
How many miles on bike 200,000, I can't believe they are shot.
Charlie at Antietam Classic Cycle has the info you need on the Chinese ones.
« Reply #5 on: July 12, 2021, 08:33:35 AM »
I would not replace the floats - all that's available (unless NOS) are the crappy white ones. Unless the original floats are filling with gas, keep running them. I also would not vapor blast - the media (however fine) may plug vital passages. Soda blast, maybe.
Agreed. What is "worn out" about them?
"Credit where credit is due."
mtiberio installed a set of Keihin PWK copies to his Eldo using manifolds from an Eldo originally equipped with Amals and these carbs (or a similar set) meant for a Triumph. Paul Linn did the same on a California II.
« Last Edit: July 12, 2021, 08:36:51 AM by Antietam Classic Cycle »
« Reply #6 on: July 12, 2021, 08:53:33 AM »
Thanks Charlie, I was thinking it was you, Mike may be racing. I can't keep all this info strait anymore, should have done a search. BUT I knew you know about it.
« Reply #7 on: July 12, 2021, 09:49:48 AM »
Offline crabbymoto
    • Empire Classics
« Reply #8 on: July 12, 2021, 12:17:48 PM »
Thanks everyone so far, to try and address different questions.
Bike has over 80,000 miles on it.  Are they fully worn out, could they be rebuilt?  Probably.  But I'd like to go to a larger carb anyways.  I have a good friend/mc mechanic who has used the Chinese knockoffs on other type bikes, Triumph 650 and Evo Sportster, and had success with them.
It's also a chance to somewhat inexpensively see what larger carbs can do. (I know there are arguments on both sides about the performance gain from a larger carb, but I'm willing to try.  Not looking for a drag bike but a little more oomph is always good)
 I'll check with sudco, but my feeling was those mikuni's would get up toward the cost of dellorto's, and not be as pretty :). I'll check with them anyways.
Was hoping to find a "get these carbs and this manifold" but sounds like it's more exploring and figuring it out.  Which is totally fine too!
Offline huub
« Reply #9 on: July 12, 2021, 02:26:48 PM »
i run chinese Vm34 mikuni's on my v65 lario,
those work just fine.
of course you will spend some time jetting them.
if you find manifolds for a guzzi with PHF carbs the mikuni's will simply fit.
i never tried with the solid manifolds of the G5, so that might, or might not work
Offline Gliderjohn
« Reply #10 on: July 12, 2021, 02:33:24 PM »
Have you looked for a good used set? Should be some out there.
Back in central KS
Offline Scout63
« Reply #11 on: July 12, 2021, 10:38:57 PM »
I have a brand new pair of PHF 36s whispering to me from the shelf, and Guzziology gently but firmly telling me to keep them away from the G5. Now maybe if I had some Lemans heads and a B10 cam...
« Reply #12 on: July 13, 2021, 08:43:10 AM »
Yeah, I don't see the point of putting larger carbs on the small valve engine.. and Shirley  :grin: 80000 mile carbs just need freshened up..
jwinwi
« Reply #13 on: July 13, 2021, 08:48:13 AM »
Your VHBs may need new needle jets; they get hogged out by the needle after a while and the result is a too rich mixture. BTDT...
Is this what you are experiencing?
Offline Tony F
« Reply #14 on: July 13, 2021, 06:13:42 PM »
The 36mm carbs can be made to work just fine on your G5 with a bit of work to open the inlets to match le mans manifolds and careful jetting. But be aware that at 80,000km the valves and guides might be due some attention. According to P Roper the shape of the back of the small inlet valves is very conducive to gas flow and these heads can be made to flow very nicely.
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
Offline crabbymoto
    • Empire Classics
« Reply #15 on: July 17, 2021, 09:46:25 AM »
Thanks for the info!
Offline crabbymoto
    • Empire Classics
« Reply #16 on: July 17, 2021, 09:53:58 AM »
Maybe. the bike just feels a little sluggish off the line and at low revs. when giving it gas.  But feels like there's more there and ready- it's just not getting what it needs, if you know what I mean.
I know it's a 41yo rather heavy bike, but I think the carbs/throttle response can be better.
