Author Topic: Quota For Sale...  (Read 3909 times)
Online SLDMRossi
Quota For Sale...
« on: July 21, 2021, 08:32:41 AM »
jwinwi
Re: Quota For Sale...
« Reply #1 on: July 21, 2021, 11:01:50 AM »
Wow, Nice Quota at a very attractive price.  Always wanted to ride one with a 19" front wheel...
« Reply #2 on: July 21, 2021, 11:34:29 AM »
That is mighty sharp looking, and I think that exhaust solves one of the known issues the Quota has! (cracked crossover? isnt that a thing on these bikes?)
Online Perazzimx14
« Reply #3 on: July 21, 2021, 11:47:56 AM »
Wheels also know to crack at the spoke nipple. Guessing that is why the front is now 19" being relaced??
Offline Alfetta
« Reply #4 on: July 21, 2021, 12:14:08 PM »
This one and the griso just seem very pleasing to my eyes...
jwinwi
« Reply #5 on: July 21, 2021, 12:24:44 PM »
Ummm, no. The rear wheels were *allegedly* prone to cracking. Mine never cracked but there were tool marks around many the spoke nipples that sure looked like they would lead to cracks. My dealer ordered a new rear wheel and it looked exactly like the original one. Oh, and the first replacement wheel that showed up at the dealer was for a Cali... :angry:
Edit: I had a red one with Excel rims F&R. Other Qs came with Sun rims and only the Excel's were prone to cracking, right?
« Last Edit: July 21, 2021, 01:09:58 PM by jwinwi »
Offline bigbikerrick
« Reply #6 on: July 21, 2021, 01:00:17 PM »
Thats a beautiful example! I always like it when I see an old Guzzi with  those rubber covers on the axle nut and fill plugs. Very "OG"!
Rick.
Offline Tim Henry
« Reply #7 on: July 22, 2021, 07:05:38 AM »
The Excell wheels were the crack prone items not the Akront
Supplied on early quotas mine had the excell and were replaced under warranty with Buchanan sun rims. My front crossover also cracked so I cut it out and welded them with blanks made from the pipe.the only thing that left me stranded on the road was a blown ecu lucky Harper's had one in stock back then unfortunately 2 months later it got totalled by a left turner
Offline Yeahoo Whoyah
« Reply #8 on: July 23, 2021, 01:04:58 PM »
CL ad was still there yesterday, but today it shows "deleted by author".  Anyone here purchase this Quota?
Greg Tillitson
El Dorado Hills Calif.
Offline RLQuota
« Reply #9 on: July 26, 2021, 09:28:22 PM »
It answers a long-held interest in Moto Guzzi's, and both the condition & price were good, I bought it.
It is a big and heavy beast, but once rolling, seems quite managable.  It's smooth at highway speed, but jerky at low speeds due to a lot of lash in the drivetrain.  I checked the cush drive in the rear wheel, the wheel to hub splines, the drive shaft splines.  The play seems to be either in the gearbox (in gear) or in the double universal joint.  Does anyone know the ID & OD dimensions of the needle bearing cups in the universal joint, or a part number?
Roger
Offline Scout63
« Reply #10 on: July 26, 2021, 09:32:52 PM »
 Congrats and welcome. Hopefully an answer will be along shortly. Ben
Ben Zehnder - Orleans, MA USA
Offline Caffeineo
  • Guzzi B00b
« Reply #11 on: July 27, 2021, 12:12:14 PM »
Roger
I believe the jerkyness has more to do with the crude FI system. Mine has been reduced with a TB balance (Had a friend do it for me as it is a real PITA) and careful setting of the TPS. I also made sure there was a bit of slack in the throttle cable. Gotta say for having 21 and 18 tires the bike really handles well.
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Offline RLQuota
« Reply #12 on: July 28, 2021, 11:46:04 PM »
With the bike on the center stand, and the transmission in gear (either 1st or 5th), I can rotate the rear wheel 7-cm (about 2 3/4-inches) at the tire contact patch.  As I stated I have confirmed no play in the cush drive, nor in the splined connection to the rear gear box.  There is a slight play in the rear pinion to ring gear contact.  My guess the play isn't in the main gearbox, as the play is the same in 1st gear as in 5th gear (This may be an erroneous assumption).  That leaves drive shaft splines (look & feel OK to me) and the universal joint.  I have seen reports of this joint failing, but don't know what other symptoms to look for, short of pulling the swing arm.
Please suggest the best path.
Roger
jwinwi
« Reply #13 on: July 29, 2021, 06:17:18 AM »
Roger
Sounds normal to me... there is some slack in the transmission between the dogs on the gears and the sliding rings. Sorry, can't think of the correct terminology right now. As others have said, fueling from the ecu is the most likely cause of jerky running. Definitely worth a tune up. Keep the revs above 4,000 whenever possible.
A bad u joint will make rattling/clunking noises when in neutral and rear wheel is spinning. Also will vibrate the RH footpeg although difficult to notice on bike that's new to you.
« Last Edit: July 29, 2021, 10:21:33 AM by jwinwi »
Offline egschade
« Reply #14 on: July 29, 2021, 12:22:05 PM »
Posting deleted so I presume that means it has sold.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
GeorgiaGuzzi
« Reply #15 on: July 29, 2021, 12:52:58 PM »
Roger
Congrats! Mine has Akront wheels with a 19” front. I love my Quota! I do not know what could be causing the extra slop in the drivetrain. If you haven’t already checked it out, Greg Benders “thisoldtractor” website has a lot of really good info. Also there is a very nice Quota thread on advrider. It’s under the beasts section iirc. Something I personally like about my Quota is that it’s unrefined. I also have a 12v Cummins that rattles shakes and just keeps running, in my opinion my Quota is the motorcycle equivalent of my 12 valve!
Here’s to many happy miles!
