Author Topic: Convert speedo cable  (Read 5040 times)
Offline twodogs
« on: July 22, 2021, 09:40:45 AM »
Ok I thought this was a simple fix but the speedometer cable broke on yesterday's ride, it is the new to me 77convert, I took the cable off the speedometer and removed the knurled? nut off the trans, move the rear wheel and it will spin there but not up top, so somewhere in the housing it broke, my question is how to remove it at the transmission? Is there a trick to it? I have not touched the nut that goes into the trans, sorry for the long question but I could not find anything about this that seemed so simple to replace and I don't want to remove that nut and something goes wrong. Thanks for any advice.
Bruce
« Last Edit: July 22, 2021, 10:31:59 AM by twodogs »
1983 Honda CB1100F
2024Triumph 400 Speed x2
Re: Convert speedo cable
« Reply #1 on: July 22, 2021, 12:12:19 PM »
It should come strait up after loosing cable hold down and the tightening bush, might be rusted in place. Pull up hard w/pliers. It's just like a G5 or 5spd.
« Reply #2 on: July 22, 2021, 12:12:56 PM »
Bruce
I would not remove that "nut" (speedometer drive body) - a hardened washer could come adrift and drop into the transmission. Unscrew the knurled nut, pull the cable up and out.
Perhaps it wasn't fully engaged at both ends?
Offline twodogs
« Reply #3 on: July 22, 2021, 01:59:08 PM »
Thanks guys, I tugged on it but I did not want to hamfist it till I was sure, the cable broke about half way in the housing,I shot some kroil in it and after a while I'll give it a tug. Thanks again.
Bruce
1983 Honda CB1100F
« Reply #4 on: July 22, 2021, 02:10:25 PM »
When my Bro put his 5 speed back together he left out the ball bearing that engages the drive cog on the output shaft, the speedo wouldn't always work after that.
If your inner cable has chewed off you should be able to source a repair kit.
Offline chuck peterson
« Reply #5 on: July 22, 2021, 03:13:17 PM »
Try giving the knurled nut and extra 1/2 turn with your tongue sticking out …I’ve fixed a broken vert speedometer that way…just check before purchasing a new one
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline yogidozer
« Reply #6 on: July 22, 2021, 03:33:58 PM »
Chuck is a big Rolling Stones fan
Offline twodogs
« Reply #7 on: July 22, 2021, 05:13:40 PM »
Thanks guys, I got the ends off but the one on the trans I wasn't sure about since I read about a washer dropping down, I pulled the cable from the speedometer end to make sure it was the cable and pulled it out of the housing to make sure it was broke, I got a new cable coming so everything should be good.  :boozing:
Bruce
1983 Honda CB1100F
Offline twodogs
« Reply #8 on: July 23, 2021, 12:59:24 PM »
Ok so I've had the cable soaking in aero kroil for a day or better and grabbed my pliers and gave it a tug and nothing so I gave a little harder tug and nothing, so I gave it a almighty tug and it let loose and I almost smacked my face with the pliers. LOL  :boozing:
Bruce
1983 Honda CB1100F
« Reply #9 on: July 23, 2021, 01:04:48 PM »
That's usually how it works :laugh:
Offline guzzimatic
« Reply #10 on: July 24, 2021, 09:33:28 AM »
When you are putting it back together connect to the speedometer then the transmission,seat the inner cable then raise it up a bit so it has room to grow and not bind up.Ron Tinkham taught me this trick years ago…
big Jim Walker bikes:'08 Norge,02'DR650,'84LeMans III,,'78 honda cb750k,'78 BMW R100S,'77 Ducati 860GT ES,'77honda XR75, '76 GUZZI convert,'75 850T cafe[project],'75 RD350 yamaha,'74 NORTON commando,'72 750 Norton flattrack replica,'72 250 Rickman-Montesa,'72 XL250 Honda Mosport[first bike
Offline twodogs
« Reply #11 on: July 24, 2021, 11:48:16 AM »
Sounds like a plan, never thought of doing it that way before but thanks for the help  :boozing:
Bruce
1983 Honda CB1100F
« Reply #12 on: July 24, 2021, 02:03:14 PM »
Bruce
Old crusty ,rusty, stuff I worked on when dealers wouldn't & now stuff I bought new is almost there. Sometimes you have to use force.
I always coat new ones w/anti-seize. Longest lasting thing for winter type riding.
« Last Edit: July 24, 2021, 03:40:43 PM by guzzisteve »
Offline twodogs
« Reply #13 on: August 02, 2021, 04:55:38 PM »
Well I finally got the cable in and put it on and it works like it should, no more bouncing around 5mph back and forth, I adjusted the neck bearings and no more head shake at 65 plus, now I'm going to replace the old Dunlop 404s .I think I have a keeper  :boozing:
Bruce
1983 Honda CB1100F
« Reply #14 on: August 02, 2021, 04:59:47 PM »
That's worth  :boozing: :boozing:
Offline nc43bsa
« Reply #15 on: August 03, 2021, 12:42:33 AM »
Bruce
1990 MilleGT
