Author Topic: 2020 California Heated Grips  (Read 2258 times)
Offline ff73148
« on: July 22, 2021, 10:20:30 AM »
The 2020 California has a switch on the handlebar for the heated grips. Is there a part number for the heated grip kit? The dealer is telling me that MG never produced the heated grip kit?
Frank Ferrante
2024 BMW R12
2022 Can Am Spyder RT Limited
Re: 2020 California Heated Grips
« Reply #1 on: July 22, 2021, 12:04:35 PM »
Find your plug-in wires & look at the connectors, might be the same as a Norge heated grip kit. I don't have a Cali14 nor have I worked on one since 2016. I do think they make a set that works.
motorcop
« Reply #2 on: July 22, 2021, 04:33:30 PM »
MG has a heated grip kit for the California but its only up to maybe 2015 or 2016? Whenever Guzzi updated the ride by wire and did away the throttle cables.
Online aklawok
« Reply #3 on: July 23, 2021, 05:27:20 AM »
can anyone recommend the MG grip kit? I have been looking at it but on the fence...my cal-vin came with some nice aftermarket grips with a twist cruise control.
2007 california vintage
motorcop
« Reply #4 on: July 23, 2021, 08:35:34 AM »
I installed a set on my 2014 Touring. They are truly plug and play. They work very well with 3 settings.
motorcop
« Reply #5 on: July 23, 2021, 09:16:07 AM »
Sorry, best picture I can get at the moment. These are the second set i have installed. I put a set on a 2013 Touring too.
Offline Dave_NWTrophy
« Reply #6 on: July 23, 2021, 02:13:00 PM »
No factory heated grip kit for the 2017+ California.  The controller and wiring are there, but they never made a grip kit for the new throttle control, and there are no bosses drilled in the handlebar for the clutch side grip.  You can modify an Oxford kit to use the factory controller by using 2 pin Molex connectors on each grip to plug into the harness.  It is documented over on the Guzzitech site.
Dave
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #7 on: July 23, 2021, 04:49:02 PM »
An alternative is the Koso Apollo heated grips.
https://www.revzilla.com/motorcycle/koso-apollo-heated-grips?sku_id=1176958
The heat control is in the left hand grip so a separate controller is unnecessary.
I have a set fitted to my Indian FTR1200S, they work well.
Offline mmcwhitehead
« Reply #8 on: July 23, 2021, 07:20:30 PM »
Ditto- my experience exactly with my '14 California Touring. Love them when starts getting chilly.
2014 California Touring
1973 Eldorado w/ Velorex Sidecar
Offline DougG
« Reply #9 on: July 23, 2021, 08:56:42 PM »
Hi all,        7-23-21
Ditto on Kiwi Dave.  I installed Koso heated grips on my 2017 Cali 1400 Tour.  Completely satisfied!  I also have wind deflectors on the grips and controls.  Together they give control over wind and cold.
Be well, stay well,
DougG
