Resetting ABS
Topic: Resetting ABS (Read 1439 times)
Kiwi_Roy
Resetting ABS
July 30, 2021, 03:14:02 PM »
How would one go about reseting the ABS on a 2014 California?
It's had the fluid changed.
Roy
pauldaytona
Re: Resetting ABS
Reply #1 on:
July 30, 2021, 04:28:11 PM »
You do have air in the system?
If normal bleeding doesn't solve it, there is an option in PADS the dealer can use to get air out. We will be supplying a version of Guzzidiag that can do it but I have no timeline for you. So if needed up to your dealer.
Paul
Daytona 1225, Stelvio 1151
Download Guzzidiag here:
http://www.von-der-salierburg.de/download/GuzziDiag/
lucian
Re: Resetting ABS
Reply #2 on:
July 30, 2021, 07:59:13 PM »
Will really looking forward to this option Paul
pat80flh
Gaggle Mentor
Re: Resetting ABS
Reply #3 on:
July 31, 2021, 03:54:07 AM »
Is the light on? Setting codes? You could try disconnecting battery, jumpering positive and negative cables together for 30 seconds. This should discharge all capacitors, hopefully clear any soft codes, and "reset" system.
00 Bassa
80 FLH (in rehab)
75 850T prject
Kiwi_Roy
Re: Resetting ABS
Reply #4 on:
August 01, 2021, 08:34:14 AM »
Update.
We have a Guzzidiag fault indicating bad rear speed sensor, the owner will proceed in that direction.
Resetting ABS
