Author Topic: V85TT gas cap lever stuck  (Read 2162 times)
Offline dave1068
« on: July 31, 2021, 03:02:09 PM »
It wouldnt be a MG w/out little problems, got gas today and the lever on the gas cap would go down, I unlocked it and played around with it a bit and it loosened up but once in the locked position, it would not pivot down.
Has anyone else experienced this? Basically it binds and wont freely close.
Thanks-
Dave
-2022 Moto Guzzi V85tt
-2024 BMW R1300gs
Offline Bisbonian
  • Living the Dream
Re: V85TT gas cap lever stuck
« Reply #1 on: July 31, 2021, 03:43:00 PM »
I saw someone else had this happen on the Facebook group a few weeks ago. They ended up buying a keyless cap from AliExpress or some place like that.
Offline slopokes
« Reply #2 on: July 31, 2021, 03:48:25 PM »
I am still good—— but the Italians believe in Murphy’s law…..
« Reply #3 on: July 31, 2021, 08:46:07 PM »
Thanks-
Do you mean the little cover over the keyhole, or the entire cap?
Offline dave1068
« Reply #4 on: July 31, 2021, 10:15:26 PM »
Yes, just the little hinged cover
Dave
-2024 BMW R1300gs
Offline egschade
« Reply #5 on: August 01, 2021, 06:42:58 AM »
Did you make any attempts to clean or lube it? Thinking a little WD40 or dry lube might help...
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline DH8a
« Reply #6 on: August 02, 2021, 12:31:41 AM »
I bought my bike second hand at 1,700km and this was already broken and getting stuck in the up position. I think the cast aluminium part has a small tab that retains the spring backed ball bearing from popping out too far. This tab is broken and the ball jams the lever. You can wriggle it side to side and gently coax the lever down. I put some lube on it and it’s mostly good but the dealer has a new one coming on warranty (so should be here about July next year).
2013 1200 Sport 8V
2020 V85tt
Offline egschade
« Reply #7 on: January 31, 2022, 04:51:20 PM »
My gas cap just did the same thing. Key cover stuck in the up position (better than down at least). Any updates on a fix or is replacement the only option?
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline Huzo
« Reply #8 on: February 01, 2022, 01:08:26 AM »
Just a bit of WD 40.
Mine needs doing every 67 days... :rolleyes:
Offline egschade
« Reply #9 on: February 01, 2022, 08:05:09 AM »
Thanks. Have never done mine since buying the bike (plus I've gotten it dirty a few times). If every 67 days is the magic number I'll have to apply the WD-40 roughly 5.7x before it will work.
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
« Reply #10 on: February 01, 2022, 08:09:42 AM »
Or a shot of ACF50 so it lasts.
