Author Topic: Refreshing motorcycle plastics  (Read 3573 times)
« on: August 02, 2021, 07:25:55 PM »
I was servicing a good friends KLR650 this week taking care of routine maintenance, tires etc but the plastic on his 2005 green machine was very faded and stained.
I recently bought an air powered mini polishing kit from NAPA with two different sponge mops and a polishing mop. I picked up a medium and super fine bottle of compound. I didn’t take pictures but the solid green plastic was very tired and dirt and greases stained it in many places.
The use of the rougher sponge mop and mid course compound followed by the finer sponge mop and fine compound, used with plenty of water to wet the plastic transformed the pieces. I finished with a paste wax and the polishing mop.
The fairing piece was very rough, I started with 400 grit on an air operated random orbital sander with constant water applied to cut the worst of the plastic down then used the the three steps of polishing to finish.
If you have solid colour modes plastic pieces in need of a refresh give this a try, the results are quite impressive.
Offline Ncdan
Re: Refreshing motorcycle plastics
« Reply #1 on: August 02, 2021, 08:00:51 PM »
Thanks for sharing 👍
Offline evank
  • 2021 V85TT
« Reply #2 on: August 02, 2021, 08:23:11 PM »
That is good info.  Restoring unpainted plastic is very difficult.
« Reply #3 on: August 02, 2021, 08:58:06 PM »
  :thumb: I wonder if all those guys riding around on pink KLRs know about this.   :thumb:  I didn't know they had the lime green KLR in '05.  It was an '06 bike here in the states.  The only color of the Gen 1 bikes I would care to own.
I have to refresh the headlights on my wife's '08 truck periodically.  It takes time to do it right but the end result is better visibility so it is worth it.
Offline 80CX100
« Reply #4 on: August 02, 2021, 10:59:38 PM »
    Tks for that timely info.
     I have 2 sheets of 40 yr old plexiglass from the bottom of 2 skylight chases that I want to rejuvenate. The plexiglass hasn't yellowed, but it is dull and cloudy, I've heard it can be buffed out clear again, I'm wondering if your product and procedure would work on it?
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
« Reply #5 on: August 03, 2021, 10:09:50 AM »
Probably, I think with clouded plastic it’s best to wet sand the worst of it out, plexiglass scratches easily and I would start with a  1500 or 2000 wet paper first in a small area to try it out.
I hope it works for you!
Jim
Offline 80CX100
« Reply #6 on: August 03, 2021, 10:15:53 AM »
Jim
Tks Jim  :thumb:
2003 V11 Lemans
« Reply #7 on: August 03, 2021, 10:40:07 AM »
I had a vintage Malcolm Smith tank on my '77 XT500. When I bought it it was a chalky off-white, so I used a single-edge razor blade to carefully scrape away the chalkiness, then my heat gun set on low to "melt" it back to it's original yellow color. I did the same with the Acerbis front fender I later installed.
Online Perazzimx14
« Reply #8 on: August 03, 2021, 11:26:58 AM »
The old heat gun or torch truck works great. Also that’s white marks out of fenders that have been bent too far.
« Last Edit: August 03, 2021, 01:25:38 PM by Perazzimx14 »
Offline nc43bsa
« Reply #9 on: August 03, 2021, 11:54:15 AM »
Also that’s white marks out of genders that have been bent too far.
 :shocked:   :grin:
1990 MilleGT
Offline bettythebear
« Reply #10 on: August 03, 2021, 12:52:39 PM »
those tupperware pieces on the klr's are notorious for fading. My red one turned pick within months, so I took all the pieces of and rhino lined them.
2011 v7 Classic
Online Perazzimx14
« Reply #11 on: August 03, 2021, 01:27:11 PM »
Wait, what? I thought being a KLR owner you'd have just brushed them with some leftover latex wall/ceiling paint in the garage.
« Reply #12 on: August 04, 2021, 08:05:27 AM »
 :boozing:
That is what I was thinking reading this. Geez, it is a KLR.  :boozing:
« Reply #13 on: August 04, 2021, 08:53:06 AM »
hahaha. I did the budget brand bedliner in a can because every time it got a chip in it, I would just touch it up, and nobody could ever tell.
I think I had this bike back from '06-'11. It was bulletproof.
2011 v7 Classic
Offline RinkRat II
  • Lake Powell AZ
« Reply #14 on: August 04, 2021, 09:22:55 AM »
      Youse guy's  are crackin' me up! I've always used Pledge once a month and still looking good.  Old sprint car trick to keep the clay and mud from sticking.
       Paul B :boozing:
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #15 on: August 04, 2021, 04:06:33 PM »
Good advice Charlie, for those of us who with less hand-eye coordiation, wet sanding works well to remove the chalky coating, or existing paint/glue.
Recently learned that the silver front fender on my 76 KE 175 is really a translucent (I think you can still use that word these days and not insult anyone's gender), white-ish (oops, that's definitely insulting someone) fender that was painted silver.
After learning this, I thought, yeah, not a good application, but probably not much of a market for fender that are silver impregnated (not assuming the fender's gender at all, just a technical term).
2002 MZ Skorpion
1994 DR Skorpion
« Reply #16 on: August 04, 2021, 08:26:11 PM »
Man that is so true! I wanted to spray my buddies KLR plastic with black bed liner but he balked at that so I went for the polishing just to see how it would turn out.
Offline Groover
    • Scooteropolis
« Reply #17 on: August 05, 2021, 08:22:49 PM »
Just saw a video of someone restoring faded black jeep 4x4 fenders with a propane torch. He went over them like a spray paint can. Worked great. Lost the video, can't find it, but guessing there are other videos out there like it. Probably a bad idea anyway  :grin:
« Last Edit: August 06, 2021, 09:35:57 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline jbell
  • Some progress
« Reply #18 on: August 05, 2021, 08:59:54 PM »
Twowheel, Meguaires (at WalMart)  will greatly lengthen the time between polishings.  I've also used RustOLeum clear UV resistant spray for plastic that worked but did have some application problems with it (alligatoring).
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
