Author Topic: V85TT Rear wheel travel  (Read 4973 times)
Offline Sye
  • Be nice, feel good
« on: August 03, 2021, 01:26:24 PM »
Forgive the question but I'm having a bit of a senior moment I think 🤔
Rear shock travel is 102mm or just over 4", so to achieve 30% static sag the shock needs to compress 30.6mm. Simple so far, but...
The shock is mounted at an angle, so the rear wheel travel is not 102mm? So, measuring sag to the rear spindle means nothing unless someone knows what the rear wheel travel is.
A long shot I know but does anyone know the rear wheel travel on a V85tt please?
TIA, Sye
Re: V85TT Rear wheel travel
« Reply #1 on: August 03, 2021, 01:38:24 PM »
TIA, Sye
No Sye I don’t, but does it matter ?
Just set your sag @ 30% of full shock travel and you will have 30% of wheel travel won’t you ?
Offline Sye
« Reply #2 on: August 03, 2021, 01:46:05 PM »
You are right of course Huzo but I don't have a second pair of hands to measure the shock length. I use a sag tool to get it right but this measures vertical wheel travel. I would guess that 45mm will be about right but that's 15mm over 30% of shock length.
You can tell me if I'm being dim, I won't mind. 😁
Edit, just had a thought, thanks Huzo. I can set up the sag tool at the same attitude as the shock, then use 30% of shock compression.
« Last Edit: August 03, 2021, 01:50:17 PM by Sye »
« Reply #3 on: August 03, 2021, 01:58:33 PM »
Just before the geometry and math professors train their guns on me...
I’ll admit that the relationship between shock compression and swingarm rotation is not linear. As the angle between the shock and the swingarm increases upon compression, you will get less shock compression for each degree of swingarm rotation.
But the rate of change in the relationship will be indiscernible I’ll cautiously  suggest.
Online Moparnut72
« Reply #4 on: August 03, 2021, 04:28:22 PM »
Sounds like a related rates question to me. That was the toughest part of the calculus course I took in college, so I can be of no help.    :evil:
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Caffeineo
  • Guzzi B00b
« Reply #5 on: August 03, 2021, 06:30:08 PM »
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Offline egschade
« Reply #6 on: August 03, 2021, 06:47:36 PM »
With the shock fully extended put a twist tie on the shaft and slide it down to the shock body. Lift the bike off the stand carefully so you don't bounce the suspension. Put it back up on the stand and measure how far the twistie moved. Can do the same with the forks...
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline Sye
« Reply #7 on: August 04, 2021, 01:28:56 AM »
Rear Travel (in/mm)    6.7 / 170
Found on https://www.motorcycle.com/specs/moto-guzzi/touring/2020/v85/tt-adventure/detail.html
That's exactly what I needed, thanks Caffeineo  :thumb:
Rear wheel travel 170mm, static sag 51mm or 2".
Offline Vagrant
« Reply #8 on: August 04, 2021, 03:18:56 PM »
Frame and suspensions
FRAME
Specification Desc./Quantity
Type High strength steel tube
Steering rake 25.7°
Trail 128.3 mm (5.05 in)
SUSPENSIONS
Front hydraulic telescopic fork diam. 41 mm (1.61 in)
Stroke 168 mm (6.61 in)
Rear Swingarm in die-cast light alloy with 1 shock absorber with adjustable spring pre-load and rebound damping.
Stroke 102 mm (4.02 in)
This is from the on line shop book. I think it's wrong! I set mine at 2" but it took 7-10000 miles to get that much.
Offline Sye
« Reply #9 on: August 05, 2021, 08:45:40 AM »
FRAME
Steering rake 25.7°
SUSPENSIONS
That's correct information Vagrant. The shock stroke is 102mm but because it's at an angle, the wheel travel is 170mm, so the sag needs to be 50 - 60mm.
