Author Topic: 1980 1000 SP tail light gasket  (Read 823 times)
Offline hiddenyeti
« on: August 08, 2021, 07:40:23 PM »
I’ve been scouring the the web but I can’t seem to find a replacement stick tail light gasket for my SP - it doesn’t even show in the parts book.
I don’t suppose anyone here has a pattern to make my own?   The old one just crumbled and isn’t a good template.
Offline nc43bsa
Re: 1980 1000 SP tail light gasket
« Reply #1 on: August 08, 2021, 08:43:57 PM »
I had the same problem with my MilleGT taillight.  I ordered some self-stick 1/8" Neoprene foam gasket material.
What does your lens look like?  Can you trace out the gasket shape from your lens?
1990 MilleGT
« Reply #2 on: August 08, 2021, 09:05:28 PM »
Offline berniebee
« Reply #3 on: August 09, 2021, 10:49:38 AM »
I just had a look at the tail lens gasket on my SP project- it's looking a little tattered too. If you can't find the gasket:
Buy some (thicker) engine gasket material, trace the pattern using the tail light lens. With a pair of scissors and a set of leather punches (Cheap at Harbor Freight) to make the screw and dimple holes and to cut inside corners, it's pretty easy to make one.  Probably quicker than ordering one too.
Offline hiddenyeti
« Reply #4 on: August 10, 2021, 06:53:40 PM »
It sounds like you are going down the path i am - tracing and making my own.
Of course, mom never let me play with scissors so this will be interesting...
