Author Topic: V7III Helmet Latch and Underseat Storage  (Read 4490 times)
della moto
« on: August 12, 2021, 12:48:24 AM »
I just got a V7iii and am a little shocked that it doesn't have those basic features. I'm trying to figure out how to lock a helmet to it and what to do to solve the no-storage issue. At a minimum, I want to carry my registration, insurance, gloves, shoe guard thing, and a tire pressure gauge. What do you all do?
Re: V7III Helmet Latch and Underseat Storage
« Reply #1 on: August 12, 2021, 01:59:28 AM »
Under the seat
If your helmets have a D ring hook it to something under the seat and close it.
Offline Dimitri_Harkov
« Reply #2 on: August 12, 2021, 03:16:16 AM »
Yeah, there really is a surprising amount of space under the seat.
Good enough for an extra T-shirt, a small first aid kit, brake disc lock, a cargo net and a few tools in my case.
A very good idea, Kiwi_Roy. Never thought of that.
I guess one could easily adapt the USB port mounting point to attach some sort of helmet strap holder there.
Cheers,
D.
2020 V7 III Stone Night Pack
Offline Davida56
Previous
1968 Wards Riverside Benelli 125
1975 Honda 750 - stolen
1978 Yamaha XS650 Special
1979 Honda XL185
1984 Honda Nighthawk 700
1987 BMW R80 - should have kept it
2000 Harley FLSTF
2002 Harley Sportster 883/1200
2015 Vespa Primavera 125
Current
2018 Moto Guzzi Carbon Shine
Offline Davida56
Previous
1979 Honda XL185
2000 Harley FLSTF
Current
Offline egschade
« Reply #5 on: August 12, 2021, 06:35:51 AM »
Or get a helmet lock - $10 on fleabay.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline sickora
« Reply #6 on: August 12, 2021, 07:27:22 AM »
For my V7III, I went with the fancy Sato helmet lock you can get for ~$60.   Don't make the same mistake I did. Because of the plastic side panels that extend,  It was never an easy time to get the D ring in the lock, and after a year, the lock broke anyway. (It's spring loaded and the spring went).   I then went with a $10 gun cable lock.  I can hook it around the frame and the D ring or strap, put the key on my keychain, and not worry about it anymore.
« Reply #7 on: August 12, 2021, 09:13:56 AM »
I took a heat gun to the fender under the seat and made it about 20% deeper, just got it toasty warm then pushed it down with a block of wood.
I carry the manual, or at least the English portion, threw the French half away, the toolkit supplemented by a full set of Allen wrenches and additional ring/open ended wrenches, the longer ones I cut to length, a USB charger, test light and a few spare bolts.
The 3 lights, one for each relay, a diagnostic aid.
I carry my insurance in a little metal pocket screwed to the underside of the seat using some of the threaded fittings there.
I think I posted a little barrier I fitted to stop things moving around.
Under the left hand side cover is my Bluetooth heated gear controller, there's quite a bit of space under the side covers for additional tools but I don't have the need for that at the moment. Perhaps a wheel wrench carved out of 1/4" aluminium
« Last Edit: August 12, 2021, 09:29:06 AM by Kiwi_Roy »
Offline Bulldog9
« Reply #8 on: August 12, 2021, 09:20:55 AM »
If riding without side cases (only on the Griso), I use a Tank Bag. I have a tank ring Givi on the Griso and a nice small magnetic Givi I use on the Mello Yello Stornello.  In the rare cases I am riding and feel the need to lock up my helmet, I'll use the stub that sticks off the frame (visible when you remove the seat) and put the D ring  through it (if that helmet has one), and put the seat back on. I also keep a small cable bike lock in the tank bag. As I have a dozen gun cable locks, that is a great idea. I have almost ZERO underseat storage on the Stornello, and less on the Griso.
My grandfather (NYC Cop who was also a MC Cop) Used to laugh at me when I would lock my helmet. He would say "Two kindsa people in the world, those who wear MC helmets and those who don't. Those who wear would never steal one, those who dont, have no need to." Generally I will only lock up my helmet if leaving the bike all day in an unsecure location. 25+ years in the NYC, and 10 in the DC area, and I've never had one stolen 'YET'.
MGNOC#23231
« Reply #9 on: August 12, 2021, 09:35:43 AM »
The low life around here will steal a worn out helmet if it's left in a back street, ask me how I know, going to the supermarket or out in the open I just hook it over the handlebar.
della moto
« Reply #10 on: August 13, 2021, 07:40:06 PM »
Under the seat
That's the point... My helmet has a D-ring, but I don't see anything to hook it to.
« Last Edit: August 13, 2021, 07:47:09 PM by della moto »
della moto
« Reply #11 on: August 13, 2021, 07:42:14 PM »
Thanks for the product review. I appreciate it. As for the gun cable-lock workaround, the no-storage issue comes into play.
« Last Edit: August 13, 2021, 08:15:57 PM by della moto »
della moto
« Reply #12 on: August 13, 2021, 07:46:31 PM »
or here - https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiXg_nfoKvyAhUWVc0KHTJIB44QFnoECAYQAQ&url=https%3A%2F%2Fwildguzzi.com%2Fforum%2Findex.php%3Ftopic%3D110907.0&usg=AOvVaw2Cr7OX1dvjUpNcMtmLTdU0
Thanks. I had seen that before. How did you fabricate that piece? Also, it seems like that hole with the threads at least a half inch below that bar of the frame. Did you put some sort of spacer there, or the bolt and the piece you've fabricated are on an angle?
della moto
« Reply #13 on: August 13, 2021, 08:03:08 PM »
Not locking the helmet to the bike is not an option for me. Until I figure out a solution for the helmet and the few things I need to secure in the bike, it's going to limit my ability to go out and do stuff on it.
My other ride is a sportbike which has plenty of storage under the passenger seat, two helmet latches, and a toolkit! This is nuts, ha.
« Last Edit: August 13, 2021, 08:05:50 PM by della moto »
della moto
« Reply #14 on: August 13, 2021, 08:10:39 PM »
Cheers,
D.
Cheers, D., but are we talking about the same bike? You fit that stuff under the seat of a V7III? Where? How?
« Last Edit: August 13, 2021, 08:12:39 PM by della moto »
della moto
« Reply #15 on: August 13, 2021, 08:14:24 PM »
By the way, is there a way to multi-quote? I appreciate the replies. I just haven't figured out yet how to quote and respond to more than one at a time.
« Reply #16 on: August 14, 2021, 03:43:59 AM »
Just put it below your seat. No trick.
The seat's lower side is more or less hollow for most of it's length, so you can easily 'pile up' things down there.
Just make sure you put the 'harder' stuff near the air intake and no cloth or plastic sheets as not to block it.
Cheers,
D.
« Reply #17 on: August 14, 2021, 04:20:37 AM »
1/8" aluminium plate is great for making little brackets or hooks but you need a vice to clamp it while you cut with a hacksaw or my favourite fine tooth coping saw.
you can also use extruded bar but it tends to be brittle if you bend it sharply. Aluminium polishes nicely with a buffing wheel and holds a nice shine.
I used 1/4" for the two Top Box side rails and borrowed a band saw to cut them out.
I never drill holes in my bikes but any spare threaded holes are there for the use of.
« Last Edit: August 14, 2021, 04:53:32 AM by Kiwi_Roy »
Offline sickora
« Reply #18 on: August 14, 2021, 07:58:30 AM »
You can absolutely put a cable lock under the seat. I've got two small cable locks, and a larger bicycle lock I use to lock up my jacket if I don't want to wear it when I go someplace. I've got a 2019 V7III stone, so we have the same amount of storage. It is certainly not much, but you can definitely fit a few small things.
della moto
« Reply #19 on: August 14, 2021, 10:26:10 AM »
You're right. As Dimitri pointed out, there is the hollow space in the underside of the seat to smash stuff down. When I took the seat off and saw the fuses, airbox, the rear fender, and no sort of tray or whatnot, that wasn't my first instinct, but I guess you gotta do what you gotta do. Thanks.
« Last Edit: August 14, 2021, 10:33:03 AM by della moto »
della moto
« Reply #20 on: August 14, 2021, 10:30:58 AM »
Nice work, Roy.
