Author Topic: V100 Mandello Merged Threadfest  (Read 763828 times)
Offline guzziboy66
Re: V100 Mandello Merged Threadfest
« Reply #450 on: November 26, 2021, 08:58:35 AM »
https://youtu.be/Y00X5f3PtVU
I like the black painted pipes of the pre-production ones in the videos.
The wheels are beautiful.  The aftermarket is likely to offer wheels for it.
The rear disc brake seems unusally large to me.
The rear brake resevoir is accessible - Thank you MG.
The video linked above insicates an accessory caalog and, if I heard correctly, mentions luggage.
Frenchtown, NJ
'25 Stelvio Duecente Tributo
'98 Ducati 900 SS FE
« Reply #451 on: November 26, 2021, 01:41:01 PM »
I don't recall seeing the "front to back" measurement. Shorter means height to me, not length. Maybe I got it wrong too.
As I understand it, the engine/transmission assembly is 4-inches shorter in length than than the V85 small block.
That has allowed a longer swingarm, plus the new transmission has a lower output shaft, allowing a lower swingarm pivot point, doing away with the need for a floating bevel box.
Offline ToddK
« Reply #452 on: November 26, 2021, 02:59:25 PM »
Thanks gang!
That green looks pretty durn sweet. 💚
« Reply #453 on: November 26, 2021, 03:15:50 PM »
What do the winglets actually do ?
Seems a bit lame to me. I do know one thing for sure, a facelift thread on a V100 would not run nine pages... :popcorn:
Offline lucky phil
« Reply #454 on: November 26, 2021, 03:47:15 PM »
You guys have to quit guesssing about the prices! They priced the V85 very well but if they get that high on a V1000 it will sell like turds on a hot day.
The Yamaha Tracer 9GT is $149999. They usually have parts and they have a real dealer network and it's a proven product. It might be the best comparisome to the V000 there is.
https://youtu.be/OadAsF5NB6Q
Wow, one hundred and forty nine thousand nine hundred and ninety nine dollars. That is an expensive Yamaha.
Ciao
Offline lucky phil
« Reply #455 on: November 26, 2021, 03:51:17 PM »
Wasn’t the statement that the V100 was 4” shorter (front to back), not top to bottom ?
I may have mis interpreted the comment.
I read it as shorter front to back which makes sense if you move the gearbox to below the crank centreline as opposed to behind the flywheel.
Ciao
Offline Griso8V
« Reply #456 on: November 26, 2021, 04:52:26 PM »
I really like the looks of the bike and I am glad that it does not look like an insect...
I am looking forward to checking it out "in person", but it looks very appealing to me from the pictures.
My prediction cost wise will be between $18K to $20K.  Reality, welcome to the real world...
Tony C
« Reply #457 on: November 26, 2021, 05:11:50 PM »
Ciao
Hell yeah..
25% of an M1
« Reply #458 on: November 26, 2021, 06:22:19 PM »
Guzzi claims a 22% reduction of wind to the rider and I believe they are triggered by a set speed.
« Reply #459 on: November 26, 2021, 06:42:56 PM »
I believe the idea for the winglets is to avoid having to bolt a barn-door size windscreen to an otherwise gorgeous bike (IMHBDHO) by having the winglets divert airflow around the rider at speed?
I could be wrong, my  :thewife: is certain it happens all the time.
Offline lucky phil
« Reply #460 on: November 26, 2021, 06:51:39 PM »
I've seen these before when I worked on McDonald Douglas A4G Skyhawks. Deployed from the aft fuselage sides, worked off a switch on the thrust lever but they were called "speed brakes" LOL.
Ciao
« Reply #461 on: November 26, 2021, 07:01:42 PM »
As I stated in my post, this observation was rooted In My Brain Dead Hippie Opinon: YMMV
Offline LongRanger
« Reply #462 on: November 27, 2021, 12:27:15 PM »
Very much looking forward to seeing this bike. I swore off MG’s years ago due to local dealership incompetence and lack of support, but if I can manage to fit on this one (6’6”, 36” inseam), it’ll likely end up in my garage. Beautiful bike.
« Last Edit: November 27, 2021, 04:01:55 PM by LongRanger »
2012 BMW R1200R Classic
« Reply #463 on: November 27, 2021, 01:53:18 PM »
« Reply #464 on: November 27, 2021, 06:59:18 PM »
LoneRanger,
At your size I'd suspect you need to mod almost any motorcycle you own.  Is that correct?  Your miles outside of the standard most OEM's use.
Online Bulldog9
« Reply #465 on: November 27, 2021, 08:30:25 PM »
That's how I am reading it. Looking forward to seeing one in the 'flesh'
MGNOC#23231
Offline LongRanger
« Reply #466 on: November 28, 2021, 12:21:13 AM »
It depends on the bike. My RT with lowered foot pegs fits like a glove, but other bikes that I’d enjoy owning, like a V7 850, are simply too cramped. And my days of enjoying sport-bike ergos are behind me.
Offline egschade
« Reply #467 on: November 28, 2021, 11:57:04 AM »
I found my V7 III cramped until I put longer shocks and stiffer fork springs in. That improved things considerably but the V85TT is even better. The higher seat height means I need to horse mount it (use the footpeg) because of my back to get my leg over but that's a minor inconvenience.
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline ScepticalScotty
    • South East Massive
« Reply #468 on: November 29, 2021, 02:17:51 AM »
If it was all about spec sheets x cost we'd all be riding around on 4 cylinder Japanese 1000s..... There's a significant proportion of the world wide motorcycle riding population that doesn't give a hoot about the numbers. Look at the sales of Royal Enfield 650s....here in the UK (a very mature and affluent market) they are either the second most, or number one bike over 500cc sold. And the number one is the GS1250 - which itself is not a spec sheet leader by any means.
Maybe the US market is different, but the love of outright power and speed passed a few years ago here, same in mainland Europe.
Scotty
Thomas Paine
« Reply #469 on: November 29, 2021, 08:51:53 AM »
Yes, but BMW's R1250RS makes more torque from just above idle (3,000rpm) than the Guzzi does at maximum (..this rising to 143 Nm / 105 lb-ft  @ 6,250rpm).  Absolute power is higher too: 136hp @ only 7,750rpm.  Unless it's substantially lighter the Guzzi is likely to trail the BMW in the inevitable comparison tests, and because these bikes are pitched at the very same customers, any 'newbies' to the marque could be hard won.
Riding the 1200RS, they do get it.  They approach sportbike power.  But it's also 200cc bigger.  That can give more useable power with little sacrifice other than perhaps lost agility due  to additional weight, stiffness and wider tires to contain the torque.
« Last Edit: November 29, 2021, 08:53:58 AM by LowRyter »
jwinwi
« Reply #470 on: November 29, 2021, 09:09:54 AM »
Tony C
Yup, the higher-spec Ohlins-suspended version will have an MSRP of at least $19,995.00. Several years ago the MGX21's MSRP was very close to that number and it was not a clean sheet design ($$$).
Hoping that the standard version is a bit less but MG has never been the cheapest - compared to the competition.
« Reply #471 on: November 29, 2021, 09:32:46 AM »
No way in hell it will be $20k+
They wont sell 3 at that price....  I have a deposit down on one already, but that will quickly be withdrawn and turned into a new Speed Twin if the V100 costs that much.
Online bad Chad
« Reply #472 on: November 29, 2021, 09:40:52 AM »
A similarly equipped 1250rs is starts north of $22,000, I don’t see Guzzi going there.
1988 YX600 Radian
Offline Nick
« Reply #473 on: November 29, 2021, 12:52:08 PM »
15 years ago the MSRP for the Norge was $15K. Yep, 20K for the "premium" V100 could be a possibility  :bike-037:
Online bad Chad
« Reply #474 on: November 29, 2021, 01:17:47 PM »
It's possible, but I don't think Guzzi  has the cachet right now to ask that kind of money, and they know it.  Guzzi is not BMW, even if they make a bike that turns out to be better than anything in it field, they still will be somewhat ham strung by their perceived short comings.
1988 YX600 Radian
Offline vintage53
« Reply #475 on: November 29, 2021, 03:21:12 PM »
Just to add to Nick's comment,
I believe a 2003 V11 Lemans Rosso Corsa with the Ohlin's' had a MSRP of $ 13,900 +
??? we shall see.
1977 Lemans
2004 V11 Coppa Italia
2010 California Vintage
Offline sidecarnutz
« Reply #476 on: November 29, 2021, 03:33:01 PM »
A minor hijack here.  For EICMA Moto Guzzi developed a special version of the V85 for the Cuirassiers of Italy’s Presidential Honor Guard, which presents quite elegantly in black graphics with white accents:
My bad, I saw this was posted earlier.
What happened to its B&W "skunk" seat? ;-) This could be the next California!
2002 Kawasaki ZR7S
Online Luap McKeever
  • Owner, WildGuzzi.com
  • Administrator
    • Wildgoose Chase Moto Guzzi
« Reply #477 on: November 29, 2021, 03:43:21 PM »
$13,000 in 2003 would be roughly $19,000 today according to my math with compounded and current inflation rates.
2021 V85TT Centenario E5
2001 California Special
2001 California EV
2007 Honda Goldwing GL1800
jwinwi
« Reply #478 on: November 29, 2021, 03:51:25 PM »
Hmm... :popcorn:
Offline lucky phil
« Reply #479 on: November 29, 2021, 03:56:10 PM »
Minus income tax on interest earned on savings included?
Ciao
