Author Topic: PHM40 mysteries and magic  (Read 17820 times)
Offline wirespokes
Re: PHM40 mysteries and magic
« Reply #60 on: August 15, 2024, 11:44:52 AM »
True - however I am still interested in knowing if the problem ever got sorted out and what it was after reading through the whole thread.
Offline guzziart
« Reply #61 on: August 20, 2024, 08:11:05 AM »
Me too, just curious.
My PHM40's need going through again, apparently the float bowl gaskets/orings only lasted 14 years :laugh:  Luckily the bike isn't exhibiting any other issues than the faint smell of raw fuel and damp float bowl exterior surfaces.  The only problem for me, as I see it, is figuring out where all those other teeny tiny orings that come in the rebuild kit go??!!  Somehow between 2010 and now I got severely inept and feel it will be a supreme challenge.  Oh well.
Offline wirespokes
« Reply #62 on: August 21, 2024, 09:05:22 AM »
I've been sorting out a 79 T5 for the last two months and finally got it running right. The last hurdle was particularly tricky.
The timing marks on this bike were missing - only the D and S present. At least they were in the right spot, though it's a guess where exact TDC might be. So I guessed and scratched a mark just above for TDC, then  figured about a 1/2 tooth above that for 2 degrees. (the distance from the crest of one tooth to the crest of the next is 3.75 degrees)
The bike popped and spit at almost-closed throttle openings, but fine otherwise. It idled and started fine. I found and corrected problems in the ignition and carbs and somehow retorquing the heads helped momentarily. But the problem persisted.
Checking timing with the timing light, it was dead-on, but saw that revving the engine didn't change the timing. The popping would happen right as the throttle opened, but the mark didn't move.
Pulled the distributor and cleaned/lubed the advance mechanism. It made a little difference.
I'd read the section in Guzziology about advance springs several times over the years, but never really totally understood it. I figured I needed new advance springs so pulled out the reference to determine which springs I needed.
This time I got it. Close inspection of Dave's graph of distributor advance curves made sense. All of the tonti distributors from this era are identical but for the advance springs. The high compression (high performance) bikes got a different set of springs and their advance curves are different. But the low compression curve starts early - about 500 RPM. That means that at idle speed the timing should already be several degrees advanced from static.
Coupled with that, Richardson said he was always curious why the low compression bikes wouldn't advance to 33 degrees full advance, only about 28.
So, as a guess, I figured a conservative estimate would put static at 5 degrees to help reach closer to 33 full advance. Compensating for the advance already advancing at 500 RPM would make about 8 degrees at idle speed.
This cured the popping and spitting at very low throttle opening, but I'm still going to replace the advance springs with the lighter ones for the performance machines. Mark at Moto Classics said he always replaces them with the performance springs, and now I understand why.
I've always heard that the important timing mark is the full advance, so I checked and I'm hitting it. It's 8.8 teeth above TDC - I had to make a mark there also of course.
I've also heard that the way to time an engine is to advance until pinging, then back off a little. With the timing advanced as it now is from the stock setting there's no indication at all of pinging.
I hope this helps others since it's taken me a month or two to work through this one.
Offline Frenchfrog
« Reply #63 on: August 21, 2024, 10:36:13 AM »
Putting the "fast " bike springs in the dizzi on my T3 also worked for me
Offline Moparnut72
« Reply #64 on: August 21, 2024, 11:18:27 AM »
When I raced an older 4 cylinder modified Mercury outboard we would joke that the timing had to be set into next week.  :wink:
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
