Author Topic: V7 vs V9  (Read 7159 times)
Offline Redblur
V7 vs V9
« on: September 27, 2021, 01:32:59 PM »
 I can’t figure out  the differences between the V7 and the V9. The MG web site is full of pretty pictures that make me want want want, but digging through it’s confusing UI has left me more co fused than when I started. I haven’t found a good reference on the web that explains the differences either. Special vs Stone is pretty clear, but 7 vs 9 is cloudy.
Can anyone fill me in?
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: V7 vs V9
« Reply #1 on: September 27, 2021, 01:35:52 PM »
The brand new ones (E5 850CC), or the previous models (V7 III and V9)?
Current: ‘16 Guzzi V7 II Stone, ‘78 BMW R80/7
Previous: ‘15 Ural Gear Up, ‘77 Kawasaki KZ400 Special, ‘78 Honda CX500S, ‘80 Honda CX500D, ‘11 Suzuki TU250X
Offline Redblur
Re: V7 vs V9
« Reply #2 on: September 27, 2021, 02:02:47 PM »
Sorry, I meant to add 2022 MY to the topic. Which raises another puzzle - are the 2022s v7III or not? I’m so confused!
Online bad Chad
Re: V7 vs V9
« Reply #3 on: September 27, 2021, 02:04:26 PM »
It's just stylistic.  The 2021s are all 850cc, but the v7 is considered a Standard.  Standards look like what most people think of when they think of a M/C
V9s are a bit more Cruiser looking.  Different gas tank, slightly more raked out forks, and big fat front tire.   They are mechanically the same, it just comes down to what floats your boat.
2016 CSC 250TT Zongshen
Re: V7 vs V9
Online bad Chad
Re: V7 vs V9
« Reply #4 on: September 27, 2021, 02:06:17 PM »
I don't believe there are any MY22 out yet, just 21.   The v7III, is a MY 20 and earlier, it has a somewhat smaller 750cc motor.
Online Dirk_S
Re: V7 vs V9
« Reply #5 on: September 27, 2021, 02:07:12 PM »
The brand new V7 is not the V7III--that was the previous model variant, and the last of the 750cc V7s.
In addition to Bad Chad's trigger-finger response (beat me to it with these notes!), the new V7 and V9 also have slight frame differences (rear frame rail on the V9 sticks back horizontally, whereas the V7's rear frame rail angles up a bit). I imagine the motors may be tuned differently, too.
« Last Edit: September 27, 2021, 02:09:58 PM by Dirk_S »
Re: V7 vs V9
« Reply #6 on: September 27, 2021, 02:12:48 PM »
The V7III and V9 had some engine differences in power and feel.
I can't say about the NEW EU V ones. I sorta expect the motors will be more similar now. Especially since they differ a bit from the old V7 at least with the oil pump setup which I assume they both now share with the V85. At least that's one of the first mechanical differences I've noted about the new V7 850.
I have no idea what other components in the V7 or V9 motors have changed.
Online Dirk_S
Re: V7 vs V9
« Reply #7 on: September 27, 2021, 02:13:56 PM »
...but digging through it’s confusing UI has left me more co fused than when I started.
Yeah, you're not wrong there. You'd think they'd hire fluent-English-speaking web-builders to supplement the primary. Or if they are, then they might want to upgrade, ha.
« Last Edit: September 27, 2021, 02:22:16 PM by Dirk_S »
Offline Redblur
Re: V7 vs V9
« Reply #8 on: September 27, 2021, 02:21:09 PM »
This is all hugely helpful. I’m a standard type of rider, so the V7 is Indeed the bike I want. Thanks!
Online Dirk_S
Re: V7 vs V9
« Reply #9 on: September 27, 2021, 02:25:23 PM »
Chad might disagree, but the V9 is more of a standard compared to an American cruiser with regards to the seated position and controls, so I'd make sure to sit on both when you go for a test ride :)
Re: V7 vs V9
« Reply #10 on: September 27, 2021, 02:28:08 PM »
I think the term "standard" might be misplaced here if it's a point of differentiation between the two.
The ergos of both are pretty much the same.
There are small bar and seat differences, but the frame/controls etc are pretty much identical*
*Since the first year only V9 in North America.
Online bad Chad
Re: V7 vs V9
« Reply #11 on: September 27, 2021, 02:59:04 PM »
I agree with you Dirk.   The v9 looks kinda cruiser like, but it's really sits and feels like a standard when on it.
Redblur do this if you haven't.  Google v7 850cc and then click on  Images, you will get hundreds upon hundreds of pics, many of which will be very helpful.  Then do the same for Moto Guzzi V9
Note, you can only get the v9 Bobber here in the US as a current model.  The v9 Roamer available else where only came to the US as a 16/17, which is to bad, as I think its the better looking of the two.
