I don’t know whether to blame John or the forum generally. I just ordered a P3 from Stein Dinse. $460.00 shipped. It’s going to go on the special part of the shelf that has the PHM’s.
My LeMans SE has a Norris RR3 cam (megacycle X8) . It's streetable and makes big power. I like this cam for the big valve motor.
I'm suspicious in the specifications of what bikes that it fits it says it fits a convert if that's the only can they're making that will not work and a convert the picture shown has a tach-drive, but doesn't have a tach Plus on the convert where the tach-drive is shown on the in the picture that would be removed and the front of the camshaft would be broached to install a keyway to the pump in the transmission and the front cover not likely there's going to be sold a lot for a convert but just by my take on it unless they make it totally separate cam for the convert which I think would be very cost-prohibitive just my two centsTOMB
I've got a P3 in a mid valve le mans roundhead with 36 mm carbs...runs really strong everywhere.I've experienced no loss of power low down ...if anything the P3 is better there too.
No issues what so ever.New followers.I fitted heavier springs but afterwards heard that that is only necessary if your revving the engine out...(I'm rarely above 6,000 )that could be BS but came from a good ,reliable source.I spent time clearanceing the whole lot, especially the valves ,valve guide to spring keepers and piston to valves.I also blended the heads to the delrin 36 mm manifolds.I think all of this is important.Now , when it comes to detonation/pinging I have had issues but that only happened when the temperatures rose above 30 C and I was running far too lean on my idle jets initially. By fattening up those yo 60's and increasing the atomizer to a 268 she runs good at high temperatures now without air filters and Mistral silencers with the DB killers in. I'm certain I could get improvements in the carburation but that kind of fine tuning is a bit beyond me without an air /fuel ratio set up or dyno runs, neither of which are at hand at the moment.
I must add that we only started to have to use 98 octane with 5 % ethanol recently and this probably makes the detonation worse.I really don't think it has much if anything to do with the cam itself.
I will be installing the P3 in my next build starting this Fall and will report on the process. I plan on having the heads ported and matched to 36 PHM's. Although I've assembled and timed a big block and a small block successfully, I've never gone into non-stock territory. I like the note I saw somewhere about building a motor "from the bottom up." I hope that someone else is doing a build at the same time.
I wonder if there would be some interest if I'd started a thread sharing my findings concerning the 'overhaul story'?
I’m sure out and out objective performance is the goal of anybody tuning an old Guzzi. It’s just fun! You wouldn’t want to know how much I’ve spent transforming my old Yamaha R5 from 30hp to a whopping 55hp! But I dare you to not ride it and either swear off motorcycles or laugh hysterically!Plus I just like the old bike!
So I’m likely to try the HMB cam as it’s somewhat unchartered territory and is only about $100 more than a p3. I plan on doing springs, followers, etc. I’ll keep the VHBs for now.
