Author Topic: New build thoughts  (Read 5580 times)
Offline Scout63
New build thoughts
« on: October 22, 2021, 12:11:07 PM »
So I’m thinking out a new build for the ‘79 SP I bought from Tom in NC through the forum.  I finished my G5/T3 project and it needs a little sorting but is pretty much done.
For the next project I want to build something lighter looking, more aggressive and just for, well, annoying the tourists around here.  I’m thinking a budget Kaffeemaschine build with softer ergonomics.  I also would like to try assembling the motor for more performance, really just to see if I can do it.
I would like to send the crank, rods, cylinders and heads to Ed Milich for some balancing and light breathing.  I just read all of his books and his writing alone puts me squarely in his debt.  I’ve already bought a P3 cam from Stein Dinse and ordered chrome LaFranconi up pipes from MG Cycle.  I have a pair of 36 PHMs on the shelf.  I like the Sachse EI since it has selectable curves and worked well on the v50. So the engine side of it I think I know what I want.
I’m going to keep the cast wheels, probably install a new smaller Brembo front master cylinder and replace the brake lines with ss, keeping them linked. I may well keep the switches, and instead of rewiring myself order new harnesses from Greg Bender.  I have a Motogadget tach in black so I could instead install with an M-unit.  The learning curve was pretty steep but I have a lot of left over stuff.  Or maybe refit the stock gauges with T3/Lemans holders.  I like that look.
Where I’m really at a loss is bodywork and bars.  I don’t really want clip-ons or rearsets.  I like the v7 sport dual seat and tank.  Would it be ok to source those and install superbike type bars? Should I lean toward a polished aluminum tank? What to do with sidecovers?  I don’t really want to deal with opening up the center.
I really want all opinions on all aspects, and even pictures.  Not having a clear vision stinks.  I’ll start a build thread when I get the bike and start disassembling.
Thanks - Ben
Ben Zehnder - Orleans, MA USA
Offline Scout63
Re: New build thoughts
« Reply #1 on: October 22, 2021, 03:36:13 PM »
I'd also lighten the flywheel and dual plug the heads add in 2:1:2 exhaust with 14" reverse cone mufflers otta make the tourists take notice.
Of course - the flywheel. Is dual plugging worth it?
Offline radguzzi
« Reply #2 on: October 22, 2021, 03:38:32 PM »
Did you happen to see this SP that TOMB posted for us to gaze at on B a T...?
https://bringatrailer.com/listing/1980-moto-guzzi-1000sp/
rad__
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline Scout63
« Reply #3 on: October 22, 2021, 03:48:56 PM »
I did.  It kind of shows me what I don’t want.  The tank, seat and sidecovers don’t work together, and the finish isn’t great.  I love the Bubs though.
Offline John Croucher
« Reply #4 on: October 22, 2021, 04:37:26 PM »
Finding someone who can and will actually don't is the problem. Some say they can, but won't.  I have set a set of heads to 4 places only to get them back not done.
I am going to do them myself. There are a couple of ways to do it.  One way does not require any welding.
Offline Scout63
« Reply #5 on: October 23, 2021, 01:51:16 AM »
Thanks John. I’m not sure that I want to dual plug. I’ll re-read Guzziology on the point and talk it over with Ed. If I remember correctly there’s not a lot of head to work with.
Offline Turin
« Reply #6 on: October 23, 2021, 06:06:04 PM »
My 2 cents; the cafe thing has been done to death. Kudos for wanting to hop up the motor and not building another sheep in wolves clothing. I went the easy route with my 850T and am pretty happy with the results. (tank and seat were rusted through when I bought her as a project in 2004. back then the repop tanks were about half the price they are now. seat came from Cosmopolitan Motors)
Upgrades:
Megacycle X9 cam from E-bay
Delorto 36 carbs
Lemans flywheel - mildly lightened - came with my parts stash
ported heads with stock sized stainless valves from ferracci.
Gilardoni cylinder kit. Copper head and base gaskets made to set the squish at 40 thousandths and bump compression up.
Mistral exhaust with bub mufflers
EBC rotors with 4 piston calipers on stock master cylinder
Fac Dampners with wirth springs and longer Ikon Dial a ride shocks for a lemans 1000.
1985 Sidlow Guzzi
« Reply #7 on: October 23, 2021, 06:38:15 PM »
Attaboy.. :thumb: That is a nice scooter, Turin.
Offline Michael Moore
    • Euro Spares
« Reply #8 on: October 23, 2021, 06:49:20 PM »
That's the first I've seen mention of needing to do welding to add the second spark plug.  When I did mine an angle plate and milling machine were all that was needed, other than swapping to a modified SHCS instead of the nut and stud.  It looks like I used a 7/8" end mill to make room for the smaller plug.
Offline Frenchfrog
« Reply #9 on: October 24, 2021, 02:51:37 AM »
The square fin heads need to have the oiling path changed so they need welding up...
Offline Turin
« Reply #10 on: October 24, 2021, 04:25:17 AM »
Thanks Chuck !
I'm pretty pleased with the end result after 15+ years of playing with it. I share my engine recipe because it makes for a nice ride without going crazy with aftermarket race parts.
1985 Sidlow Guzzi
Offline huub
« Reply #11 on: October 24, 2021, 06:52:19 AM »
Personally i think the whole cafe racer thing is getting boring.
I like the sp for what it is,
I would do a 1000sp restomod, upgrading engine, modern suspension, brakes and wheels.
Get a nice exhaust system ,  and own a unique 1000SP instead of another cafe racer clone.
« Reply #12 on: October 24, 2021, 07:21:08 AM »
Turin,
Yes, very nice bike. Where did you source that front fender?
Offline Turin
« Reply #13 on: October 24, 2021, 11:09:05 AM »
It's a generic aluminum fender I found browsing years ago, don't remember where. probably E-bay. The rear fender is from a laverda I bought from Wolfgang Haerter and cut down to fit. The bikini fairing is an second hand bit also from E-bay (The bodywork was trashed when I bought this T and the seat pan crumbled to rusty dust. no good parts were discarded in the building of this bike).
1985 Sidlow Guzzi
Online Matteo
« Reply #14 on: October 24, 2021, 11:29:13 AM »
Upgrades:
Delorto 36 carbs
A real Beauty!
Rough Edge racing
« Reply #15 on: October 24, 2021, 11:31:55 AM »
Try for a tight squish band around the piston circumference with .035  clearance. you may need to reduce cylinder height..It's worth the work and will lower octane requirements by a faster burn and less overall timing, sharper throttle response and better fuel mileage. I have experience doing this on hemi head Triumphs and wedge head auto engines...
Offline Turin
« Reply #16 on: October 24, 2021, 02:26:50 PM »
Mike Rich recommends setting the squish at .040 -.045 , I went to .040
1985 Sidlow Guzzi
    • Euro Spares
« Reply #17 on: October 24, 2021, 03:02:07 PM »
What I've seen for decades is 1mm/ .040" as the top end for the squish being effective.  The chosen squish dimension will also depend on the intended RPM and the condition of the crankshaft components as a flexy crank and stretchy rods will need more clearance so things don't crash.     With Carrillo rods and a reasonable red line on the street a few more thou can probably be taken out.  The turbulence from squish and velocity of the moving mixture will vary with the size of the squish band; if there's a lot of area around the edge of the bore (as on a 1L Guzzi) with what are nominally 850cc chambers in the heads) then there's a lot of mixture that needs to be forced out of that area, and I suspect that a slightly wider clearance will probably work OK.  Do make sure that at worst the head and matching piston surfaces are parallel, and better is probably to have them slightly divergent, opening up towards the center of the bore.  You don't want them tapered in the wrong direction so that gases are trapped at the edge of the combustion chamber.  You want to encourage the gases to move to the center of the bore and away from the edges.
Offline Scout63
« Reply #18 on: October 25, 2021, 07:48:19 AM »
Upgrades:
Delorto 36 carbs
That’s a great looking bike and pretty close to what I want.  I like the SP look but already have my G5/T3 with stock engine and floorboards for cruising.  Maybe move towards a sporty standard like yours.  The Bub pipes look great also.  This whole project may be a little silly since I don’t really ride very fast, and two full build v1000s in the garage next to each other isn’t the best use of my time and money. I am a little lost in this discussion about squish bands but will get up to speed.
Offline Scout63
« Reply #19 on: October 25, 2021, 04:49:36 PM »
Ok Turin.  Your bike is so pretty that it changed my thoughts.  I just found a Bub exhaust on eBay and now want to blatantly copy your build.
Offline Turin
« Reply #20 on: October 26, 2021, 12:18:51 AM »
I started by trying to blatantly copy George Dockrays 850T, so go for it! Budget constraints de-railed things and this is where I ended up. The Omars fairing was a second hand E-bay score, as was the seat and seat foam.
George Dockrays T-
https://www.bike-urious.com/1975-moto-guzzi-850t-custom/
« Last Edit: October 26, 2021, 12:22:48 AM by Turin »
1985 Sidlow Guzzi
