Author Topic: V7 Sport (road rash)  (Read 56743 times)
czakky82
« on: November 27, 2021, 09:20:48 AM »
Looks like my last attempt to document my rebuild was deleted.
I’ll try again.
Frame is stripped and I’ve got both engines pre-inspected now. I’ve all but decided to run the original engine.
Now for the bad news… looks like the frame is tweaked a bit. At least I think it is. It won’t sit flat, the left front is about 2mm off the ground. Is this a lot? It’s not detectable by sighting it down anywhere.
Offline cliffrod
Re: V7 Sport (road rash)
« Reply #1 on: November 27, 2021, 10:14:17 AM »
2mm may not be that significant, depending upon the reason.  Is one of the down tubes bent, neck twisted, ? or is the lug at the bottom of the tube  The lower frame rails bolt in place and it isn't a press or precision fit.  Have you bolted the lowers in place to see how all aligns at that point?
I understand these frames are prone to cracking where the bottom of the front down tubes attach to the lugs.   If the 2mm doesn't pull the frame out of shape when lowers are installed and tightened, that's lots better than having to have cracks properly serviced.  One of my down tubes was welded/repaired & not pretty when I got the bike.  I've never fixed the repair.  Maybe someday.
czakky82
« Reply #2 on: November 27, 2021, 04:28:46 PM »
Good points. The lower rails were loosely bolted up originally. I put them into place and the left side lined up perfect. The right side was close but not perfect. I was able to get everything bolted up no problem but the holes didn’t line up absolutely perfect on that side.
I’m leaning towards running it as is.
czakky82
« Reply #3 on: December 12, 2021, 07:07:15 PM »
Engine stripped and getting ready for vapor honing.
The head and cylinder are empty, I’m not using either the heads or cylinders just there to protect the mating surfaces. Probably unnecessary but I’m trying to seal it up somewhat to make clean up easier.
Crank is going to the machine shop to see if it will polish up.
Rod bearings and main bearings are pretty rough.
« Reply #4 on: December 12, 2021, 07:40:55 PM »
Vapour honing will not damage mating surfaces, it is safe on aluminum, steel, brass and most plastic. The glass media / water slurry is very gentle but it gets through the thinnest joints so better to send parts completely disassembled into individual pieces for vapour honing.
Shells and mains look pretty worn. Have you measured the crank bearing surfaces to determine if you will need a regrind and oversized shells and bearings? Every non filter GUZZI big twin I have rebuilt needed oversized bearings, damn chrome flakes and poorly filtered oil causes all kinds of grief. Looking at those bearings I would expect the oil pump to be worn out as well.
Glad to see you saving a rare bike! 👍
czakky82
« Reply #5 on: December 12, 2021, 08:39:48 PM »
Sounds like I can get by without protecting the mating surfaces with vapor honing. Can threads get damaged?
I haven’t had the crank measured yet. Fingers crossed I can get away with just fresh bearings.
A fresh oil pump is in the budget.
« Reply #6 on: December 12, 2021, 09:31:04 PM »
Vapour honing will not damage threads but blind holes can be hard to clear of media, when I can, I thread in an old bolt into the threaded hole before I vapour hone. Regardless of plugging holes or not, I chase out all threaded holes before reassembly.
Vapour honing with fine glass bead is very safe, the bead does not fracture on impact like dry blast so no tiny shards of glass bead get embedded in the porous surface of the casting. I pull all ball bearings and races out of all castings before blasting, near impossible to get the media out of a bearing. After honing I rinse and with compressed air blow dry the part then rinse and dry again. After you finish assembling the engine spray it down with brake cleaner followed with a spray and wipe of ACF-50.
Vapour honing only pulls off oxidation, it does not damage the base metal.
Offline Scout63
« Reply #7 on: December 12, 2021, 10:16:03 PM »
Czakky you should expect to run a tap through every threaded hole in the case as the media will soften up threads.  Especially vulnerable are the front timing chest and sump holes and the cylinder head rocker cover screw holes.  The result is so worth it though. More pictures please.
Ben Zehnder - Orleans, MA USA
Offline cliffrod
« Reply #8 on: December 13, 2021, 07:01:34 AM »
I understand that people prefer not to have to turn these crankshafts, but do what you need to do and move forward.  If it needs turning, it doesn't look like it will need much.  Glad to see it's not badly gouged or grooved.  fwiw, my crankshaft had to be turned, so it was.  Many happy trouble-free miles since...
czakky82
« Reply #9 on: December 13, 2021, 07:29:36 AM »
@Canuck, I think I will go through with my original plan to seal up the cases. Should be less clean up when done I hope. I think the trans should be pretty well sealed up hopefully saving me from having to replace all the blind bearings inside…?
@Cliffrod: I keep going back and forth between fitting an oil filter conversion or not… Maybe I can see what the machine shop will charge for drilling.
Other news, it looks like I’ve got an 850t rear drive with a slightly shorter gear ratio that I’ll be using.
« Reply #10 on: December 13, 2021, 08:51:12 AM »
I have been asked by many folks to vapour hone their motorcycle parts for them and regularly do so. Some folks have asked to try and blast parts with blind bearing and races left in, carefully blanking off all openings. In every case the media found it’s way in. The blast cabinet runs at 90 psi pressure, trust me the slurry finds its way in. If you blast the transmission case you have to get the bearings out of the case, there is space, tiny as it is, under the bearing races. I have had my Vapour Honing cabinet for over five years now and it gets used most every day, it takes a little prep work but it is worth it.
The Vapour Honing process will not remove paint unless there is corrosion under the surface and it does not like grease or dirt, parts need to be washed before blasting.
« Reply #11 on: December 13, 2021, 08:55:07 AM »
Cleaning very thoroughly is super important no matter the method or media. The last Morini 3 1/2 engine build I did for a customer had been vapor blasted by him and media was packed in bolt holes and crevices like concrete. Very hard to remove - for M6 bolt holes I ended up using a .22 caliber rifle cleaning brush!
Not all dry blasting machines are created equal. The machine shop that cleans my cases has a shot peening machine made by Blast-It-All which they run at 15 psi. The blast media (Potters Ballotini) does not fracture at such low pressure so there is zero chance of any of it being embedded. They plug all bolt holes and oil galleries, mask most gasket surfaces and clean the part three times.
https://blast-it-all.com/abc-shot-peener/?v=2e5df5aa3470
https://www.milessupply.com/product/ballotini-glass-bead-abrasive/
Offline cliffrod
« Reply #12 on: December 13, 2021, 09:35:28 AM »
^^^^I'll add my recommendation for and complete confidence in product & services offered by Miles Supply.  I've used them as my primary go-to supplier for decades, both via Barre, VT and Elberton, GA, for all kinds of products and tools used in my granite work.  Absolute top notch, industry-professional-level company.
czakky82
« Reply #13 on: January 11, 2022, 07:19:19 PM »
Engine and trans cases back from vapor blast. They turned out really nice. I’ve been cleaning gasket surfaces and chasing all threads with a tap. I will clean everything out with brake cleaner tomorrow give it wash in the slop sink and blow dry with compressed air. I’m waiting on the verdict on my crank at the machine shop. Then MG cycle will have a big order headed there way.
Im on the look out for a good stainless hardware set when I’m ready for assembly.
damaged smileys
« Reply #14 on: January 13, 2022, 06:34:06 PM »
Lovely!  :thumb:
czakky82
« Reply #15 on: January 19, 2022, 05:14:13 AM »
One of my mechanically weak points is gears and transmissions. I’m scared to death of bevel gears! It’s a totally dark art to me.
Before I start reassembling the trans on this bike I’d like opinions on condition. I’m going to replace any dogs available and bearings. Sorry my photos aren’t great.
Thoughts?
« Reply #16 on: January 19, 2022, 08:44:04 AM »
Thoughts?
Those dogs are rounded off worse than any I've seen.  :shocked: The cost of 5 spd. parts adds up very quickly. You might consider buying these: https://wildguzzi.com/forum/index.php?topic=113723.0 You might be $$ ahead in the long run.
czakky82
« Reply #17 on: January 19, 2022, 09:14:03 AM »
Thanks Charlie, I’ll do some research on gear ratios and get a hold of seller. :cry:
jwinwi
« Reply #18 on: January 19, 2022, 01:34:10 PM »
Price on the 5 dog guts seems good...
Charlie, if Bill's shift drum is the old V7 Sport, 1 up 4 down, it can be re-used right?
czakky82
« Reply #19 on: January 19, 2022, 03:42:14 PM »
Thanks John, another great point… I kept wavering between doing a LH or RH shift on this bike and was about to settle on RH… Oy! This might push me back to a LH conversion.
This project is fighting me a bit!
jwinwi
« Reply #20 on: January 19, 2022, 04:28:16 PM »
As one of the smartest guys on WG has been known to say: 'It's testing you to make sure you are worthy of owning it'   :thumb:
I don't know why modern 5 dog guts would not work with the original shift drum. Totally different than 'It will work' :laugh:
« Reply #21 on: January 19, 2022, 08:45:06 PM »
Yes, he should be able to reuse it.
czakky82
« Reply #22 on: January 29, 2022, 09:22:04 AM »
Powder coater called and said my parts were ready :drool:. I’ll be able to pick them up on Monday.
In the meantime I’ve got a shipment coming from HMB on its way with a bunch of cool parts that will get me closer to completing my engine.
Heads are at the machine shop along with my crank and rods. There was basically no good news. From wrist pin bushings down to the crank everything must be re-ground. They are going 1st under on the crank and fabbing up new small end bushings…. Also, k-lining valve guides. 1st under rear mains are nowhere to be found so they are going to give the 2nd under acquired from Harpers a haircut.
In the meantime I’ll be rebuilding the trans with all new bearings, seals and gaskets.
I’ve got a question about the console color. What color is a good match for the gauge surround and idiot light holder?
Thanks for any input
« Reply #23 on: January 29, 2022, 07:17:23 PM »
Wrinkle black. I had my powder coater do it.
czakky82
« Reply #24 on: January 30, 2022, 07:25:50 AM »
Is that what the Sports were originally?
« Reply #25 on: January 30, 2022, 08:47:20 AM »
In my experience, yes. Every original V7 Sport I've worked on has had wrinkle black there.
czakky82
« Reply #26 on: February 13, 2022, 10:20:33 AM »
Pushing forward, slowly. I’ve got the triples assembled but can’t get the play out of the top triple. I’m pretty sure it’s not supposed to have this much play.
Bearings are seated all the way I’ve tried both ways with the steering lock. I’ve got all parts installed from the schematic.
Is that the way these are?
« Reply #27 on: February 13, 2022, 02:43:36 PM »
Normal in the first photo. The top stem nut will protrude like that. It's really just locking the lower nut into place and won't turn once the pinch bolt is tightened.
« Last Edit: February 13, 2022, 02:45:31 PM by Antietam Classic Cycle »
czakky82
« Reply #28 on: February 13, 2022, 04:33:39 PM »
Thanks for the vote of confidence.  :thumb:
Offline cliffrod
« Reply #29 on: February 13, 2022, 06:50:21 PM »
yup- another positive vote for what you're showing,  top nut looks like mine  wrinkle paint looks good & dash should match the triple tree clamps.
