Author Topic: Lovely Norton  (Read 6828 times)
Offline Scout63
Lovely Norton
« on: November 27, 2021, 07:19:06 PM »
Ben Zehnder - Orleans, MA USA
Online JJ
Re: Lovely Norton
« Reply #1 on: November 27, 2021, 07:51:07 PM »
I’ve always liked this model:
https://bringatrailer.com/listing/1971-norton-norton-commando-ss/
I believe everyone loves a vintage / classic Norton like this...
Offline huub
Re: Lovely Norton
« Reply #2 on: November 28, 2021, 12:03:38 PM »
everbody who did not own one at the time.
i've still got mine ,it will probably be a retirement project.
i had it as daily transport for years, keeping on top of te repairs and maintenance was a nightmare.
I bought a V65TT to use during winter, to keep my nice norton clean.
after finding out you can ride a bike witout spending your weekends spannering, i never looked back.
currently own 6 guzzi's...and a norton.
Offline Scout63
Re: Lovely Norton
« Reply #3 on: November 28, 2021, 02:16:21 PM »
I love my Norton. It’s the bike I take when I want to show off a little.  I was running the carbs dry this afternoon and loving how raspy and loud and snarly it is.
Offline lucky phil
Re: Lovely Norton
« Reply #4 on: November 28, 2021, 04:14:46 PM »
Well you'd be wrong :grin: All I see when I look at any Commando or it's derivatives is a crankshaft with the rigidity of wet spaghetti, (so bad it needs barrel shaped main bearing rollers to accommodate all the flex) Amal carbs that are worn out before the first service mileage, Lucas electrics and fiddly high maintenance "Isolastic" engine mounting system designed to keep the whole vibrating, oil leaking lump of a mechanical mess in the frame without the rider losing their fillings. Nortons final insult to the British motorcycle buyer.
Ciao
« Last Edit: November 28, 2021, 04:17:04 PM by lucky phil »
Offline Cal3Me
Re: Lovely Norton
« Reply #5 on: November 28, 2021, 07:58:54 PM »
I'd ride any one of my Norton's anywhere ..except for my 1948 350 Manx.... I can't bump start it without help ...... so what if i have to keep a rag in my pocket to wipe off my boot once in awhile ..
I just think Phil is jealous ,,,,, he's not living up to his tag line , living on the edge
TMS
Offline lucky phil
Re: Lovely Norton
« Reply #6 on: November 28, 2021, 10:11:47 PM »
Probably need to review that tag line. Maybe "the mild one" is more suitable now  :grin:
Ciao
LesP
Re: Lovely Norton
« Reply #7 on: November 29, 2021, 12:41:25 AM »
Ciao
If you knew anything about Commando's you would know they never had barrel shaped roller bearings.
Offline lucky phil
Re: Lovely Norton
« Reply #8 on: November 29, 2021, 12:51:30 AM »
They did after you had to rebuild them when they destroyed the std bearings due to crank flex. Any decent engine builder for a Commando that knows his stuff uses the "Superblend" mains with the barrel rollers to accommodate the crank flex. Same as the gearbox upgrade to roller bearings from bushes. As a matter of fact if my memory serves me from 40 years ago Norton used them in the later Combat engines after all the earlier ones started blowing up, so they did indeed at one point come with Superblends. I have been inside a commando engine and transmission.
EDIT.....I did some research.
https://www.real-classic.co.uk/2018/02/15/classic-techniques-superblend-bearings-part-one/
https://www.real-classic.co.uk/2018/03/16/classic-techniques-superblend-bearings-part-two/
Ciao
« Last Edit: November 29, 2021, 01:04:27 AM by lucky phil »
Offline huub
Re: Lovely Norton
« Reply #9 on: November 29, 2021, 03:19:18 AM »
When did walking beside a bike with a blown engine started being considered living on the edge?
Offline rustygman
Re: Lovely Norton
« Reply #10 on: November 29, 2021, 03:36:05 AM »
That depends on where exactly you break down.
Back on a Guzzi again. 1100i Cali.
Offline Scout63
Re: Lovely Norton
« Reply #11 on: November 29, 2021, 06:59:44 AM »
I’ve only walked home three times due to breakdowns in all 45 years of riding, and none were on the Norton:
1. /5 electrical problem
2. K75 caught fire under me
3. SR500 threw a rear drive chain circlip and unrolled the chain.
I chalk all up to careless maintenance.  Now, I always carry a big roll of tools and a big first aid kit to ward off the demons.
Re: Lovely Norton
« Reply #12 on: November 29, 2021, 07:54:41 AM »
Super blends installed on the right, original oil pump on the left which has to be replaced some day.  Even though the Norton has been rebuilt, it still leaks some oil but I’ve pretty much eliminated most of those issues. The Daytona has a weird oil weep from the right head which I can’t find, thought it was a porous valve cover but that isn’t it, so it shares an issue with the Norton. My 07 NORGE dodged the bad oil pumps which led to some engine’s going bad or at least had to have the oil pump,changed. My CX engine started clanking right before I made it to the garage, bad crank shell so the engine was rebuilt. Then I found out there were a few bad batches of shells installed at the factory and I got one of those engines. I never owned a hydraulic Guzzi engine but those were an issue, then the Carc equipped bad roller issues…….
Norton’s had their problems which can be fixed, but so has MG.
Online Tkelly
Re: Lovely Norton
« Reply #13 on: November 29, 2021, 08:15:06 AM »
Like Harley’s before the evo motors these bikes are antiquated,I would guess that pre vtwinGuzzis werejust as fragile ..
Rough Edge racing
Re: Lovely Norton
« Reply #14 on: November 29, 2021, 08:34:38 AM »
 Norton Superbend bearings are barrel shaped? I have never examined one but some Norton restorers say the are a normal shaped roller with the ends rounded off slightly....
Offline huub
Re: Lovely Norton
« Reply #15 on: November 29, 2021, 08:39:37 AM »
the difference is MG managed to fix the issues, the norton factory didn't
during the years i ran my norton 25.000 km/year, my girlfriend ran a V7sport.
both 1972 , both same mileage.
That V7sport was stupidly reliable in comparison.
Re: Lovely Norton
« Reply #16 on: November 29, 2021, 12:47:54 PM »
I can't argue with you on that one.
MG is certainly a better bike in terms of reliability but there are cases where they were lacking and the factory did nothing.  Stelvio owner's never got a fix for the flood lights which left people stranded unless they knew what to look for. The battery wiring on the Carc bikes is a known problem but to my knowledge, the factory never addressed that issue for the entire run of the Carc bikes.
Norton did recall the frames for the early 68 Fastbacks like my bike, unfortunately mine wasn't fixed so I had the frame fixed before it snapped.
Offline lucky phil
Re: Lovely Norton
« Reply #17 on: November 29, 2021, 01:34:29 PM »
Exactly, or in parlance of the time "barrel shaped" for want of a better description. As opposed to "normal but". Even the name "superblend" is a bit of hazy thing but the identifier of the time used by everyone. The technical point is the ends of the rollers needed to be a reduced dia to stop the point contact from crank flex destroying them.
Ciao
« Last Edit: November 29, 2021, 01:36:15 PM by lucky phil »
Offline lucky phil
Re: Lovely Norton
« Reply #18 on: November 29, 2021, 01:37:36 PM »
I can tell you where your Daytona head is leaking and how to fix it.
Ciao
Offline Scout63
Re: Lovely Norton
« Reply #19 on: November 29, 2021, 01:49:07 PM »
I would much rather work on a Guzzi than a Norton. I feel less like a carpenter and more like a mechanic.
Re: Lovely Norton
« Reply #20 on: November 29, 2021, 01:52:11 PM »
Ciao
Cool, the hose is not the source. Where do you think it's leaking?
Offline lucky phil
Re: Lovely Norton
« Reply #21 on: November 29, 2021, 04:12:52 PM »
Have a read through this thread I made and let me know if you have any questions. Try the rocker cover retaining screw holes in the head first if it gets oil on the outer head fins. If it's from somewhere at the front cam drive area it will be the cam bearing support block. All assuming it's not something obvious like a weeping head gasket.
https://www.v11lemans.com/forums/index.php?/topic/22369-porosity-a-retrospective/
Also this on the last page. The cam bearing support.
https://www.v11lemans.com/forums/index.php?/topic/20664-v11-daytona-project/page/26/#comment-254707
Ciao
« Last Edit: November 29, 2021, 04:15:14 PM by lucky phil »
LesP
Re: Lovely Norton
« Reply #22 on: November 29, 2021, 05:02:14 PM »
The 1968 to 1971 20M3 and 20M3S 750 Commando followed on from the Norton Atlas with a ball bearing on the timing side of the engine and a roller bearing on the drive side which worked fine unless they were over revved.
For 1972 the engine case was changed which included a revision to the dry sump scavenge pick location (which reverted back to the pre 1972 location for the 1973 850)
That 1972 engine also got a revised breather system with an outlet at the rear wall of the engine case replacing the cam shaft breather of the earlier engine that had a hose running off the end of the cam on the left hand side of the engine back to the oil tank.
Why do a lot of British motorcycle engines leak, because of poor crankcase evacuation.
I bought two of these reed evacuators for my Commando's from Jim Comstock. These replace the large plug under the engine so maintain the gauze scavenge pick up as per stock and the case evacuates via the tower with a hose return to the oil tank.
That fixes two problems straight away.
That reed valve breather fits all 850 Commando's and the 1971 750, it will not fit pre 1971 Commando's due to the lower frame loop cross tube being rearward (moved in 1971 forward) or the 1972/1973 engine case as there is no provision to fit it.
Stock, oil passes from the floor of the engine case through the gauze and back to the scavenge side of the oil pump.
The 1972 case did not have this.
I elected to machine a copy of sorts for my Eldorado (That would be the bike folk lower the oil level on so it does not exit via the poor breather system)
Being a wet sump engine it has an internally baffled engine case port to feed it and the breather has a reed valve with separator and case return.
As far as the 1972 Commando I do not know what the bearing set up was for the first bikes produced, ball and roller or dual roller (Combat was just a performance spec that could be added to the standard bike for that year)
Why did the crankshaft bearings start to fail is speculation at best, even with the higher compression on the Combat spec a sensible rev limit would have seemed prudent especially with a 19T front drive chain sprocket.
There was talk of cavitation, the new breather not being better than the previous method, the new small un gauzed oil pick up could allow free passage of small debris back to the oil pump.
The high compression (and low geared) Combat seemed to have the problems so the recall was for the Superblend bearing which was a R&M bearing (or RHP) with revised roller ends on the parallel roller.
The barrel roller myth of near 50 years started there.
Obviously anyone who actually works on Commando engines or knows bearings would know a barrel shaped roller on a flat race would have no stability or load carrying ability (and would not repeat or copy that)
That early MRJA30 bearing had the hand scribed /6, the FAG NJ306E even if used in later part of 1972 is more so associated with the new for 1973 850 engine (imho)
Any failing with the gearbox layshaft ball bearing came down to the cage material which was known to fail on the so called Portuguese bearing in the
 1973 on 850, it could start to fail (The kick start lever would start to pivot giving a warning something was wrong being on the end of that same shaft) Failure could lead to a locked rear wheel.
There are two replacements, a roller bearing or an upgraded ball bearing with better cage, I elected to put rollers in both my Commando's with the shafts shimmed for maximum engagement in first gear.   ​
I found this which is bearing related to the Commando and shows the clipped profile of the so called 'superblend parallel roller.
https://www.nortonownersclub.org/sites/default/files/Main-Bearings-v1.1.compressed.pdf
I have no real loyalty to any marque but look at them independently for what they good and bad and a lot of the bad can be rectified with time, patience and money.
The Commando in general (imo) needs a lot of specialised tools to work on, without them it will soon become a chore or risk of a bodge.
I would rather have a Triumph TR5T Trophy Trail over a 1971 SS as per the thread.
Offline lucky phil
Re: Lovely Norton
« Reply #23 on: November 29, 2021, 05:44:00 PM »
Thats massively interesting info there esp with regards to the detailed main bearing info in the link which I've saved. I'm aware that the terminology "barrel shaped" isn't totally accurate as the Superblend bearings were never a true "barrel" shape but it's a convenient and descriptive if somewhat technically inaccurate way of describing the modified style of std roller bearing but to the non engineering people and layman was common parlance at the time to describe the "superblend" bearing. Like Guzzi having OHC on their Daytona rocker covers when in fact its a "high cam" engine, not an OHC design. A distinctly different thing to engineering people but all too complicated for the average person to care about so it gets called an OHC. I have no particular affinity to any brand my affinity is governed by sound engineering and design.
Ciao
« Last Edit: November 29, 2021, 05:50:31 PM by lucky phil »
Rough Edge racing
Re: Lovely Norton
« Reply #24 on: November 29, 2021, 06:10:57 PM »
The link provided by LesP above says what I said previously the rollers are not barrel shaped, the are flat across the majority of the surface with the ends tapered or stepped....
Offline Scout63
Re: Lovely Norton
« Reply #25 on: November 29, 2021, 07:33:23 PM »
Great information LesP.  The second thing I learned about my Combat, after the new shift pattern, was that the crank bearings were going to have to be replaced.  I bought all those specialized tools and never looked back. That bike taught me that motorcycle engines and gearboxes aren’t mysterious. Nortons may not be easy to keep in form, but they are simple, the factory manual is wonderful and parts are easily available. Every garage needs a German, an Italian and a British air cooled twin.
Offline jacksonracingcomau
Re: Lovely Norton
« Reply #26 on: November 30, 2021, 04:22:26 AM »
Ciao
Thanks, 50 odd years, I’v e just.said Superblend
Offline huub
Re: Lovely Norton
« Reply #27 on: November 30, 2021, 06:11:03 AM »
i'm doing fine , with at least a dozen  italian twins, a britisch twin, even a japanese one... ( my first bike ever!)
Not sure about the german twins, the ones i sampled were seriously lacking character.
may be if i retire, and the italians become too much to handle ?
Offline tazio
Re: Lovely Norton
« Reply #28 on: November 30, 2021, 06:54:00 AM »
THAT'S a garage I'd like to hang out in. :thumb:
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
Re: Lovely Norton
« Reply #29 on: November 30, 2021, 09:02:53 AM »
Ciao
Phil, thanks for that information. I’ll have to investigate that head on my bike, quite frankly it’s quite impressive that you discovered the source, but given your background I’d expect nothing less.
T
