Author Topic: NGC: Tool Measure Please  (Read 1412 times)
Offline pehayes
« on: November 28, 2021, 11:19:58 AM »
I need to buy a "flare wrench" but it might not work so I don't want to blow the investment.
Does anyone have a 7/8" flare wrench available?  I need to know the opening width dimension to confirm if it will fit my application.
I have flare wrenches, but not one that large.
Offline lucian
Re: NGC: Tool Measure Please
« Reply #1 on: November 28, 2021, 11:31:45 AM »
In Inches
« Last Edit: November 28, 2021, 11:41:57 AM by lucian »
Offline lucian
« Reply #2 on: November 28, 2021, 11:41:07 AM »
In MM.  Wrench is a craftsman
« Last Edit: November 28, 2021, 11:42:30 AM by lucian »
Offline pehayes
« Reply #3 on: November 28, 2021, 11:50:05 AM »
Thanks.  That will fit.  I'll order the wrench.
Offline guzziart
« Reply #4 on: November 28, 2021, 02:48:19 PM »
FWIW and you want to go "thrifty".
https://www.amazon.com/DURATECH-3-piece-Vanadium-Organizer-Included/dp/B08F9VJ27W/ref=pd_day0_2/143-4534112-8266760?pd_rd_w=3Szo4&pf_rd_p=8ca997d7-1ea0-4c8f-9e14-a6d756b83e30&pf_rd_r=5D8JQ3ANSY04AYRCM0WF&pd_rd_r=53bbf9da-5422-497e-872e-270bc198a5f5&pd_rd_wg=YiUya&pd_rd_i=B08F9VJ27W&th=1
Also, whatever you order may not have been manufactured to the same "open" specs as the pic in an earlier post but a little work with a cut-off wheel or die grinder woud do the trick.
« Last Edit: November 28, 2021, 05:09:50 PM by guzziart »
