Author Topic: v7 850 suspension  (Read 1195 times)
Offline guinzomoto
v7 850 suspension
« on: December 04, 2021, 08:39:19 AM »
2021 v7 850 suspension was mediocre especially rear.  Too much compression damping not enough rebound damping. Pogo stick effect Could not find any listings yet for the rear shocks for the bike so did some digging.  V7 II has 390mm long shocks, V7III has 350mm shocks, V7 E5 has 380mm.  Checked shock bushings and called Ktech suspension and they looked into it and said they all thought I was right.  Ordered Ktech razor shocks and yes they fit fine and with ride height adjustment, compression damping, rebound damping and spring preload they are easy to dial in.  No more pogo stick.  Front is easy since any cartridge from V7II on will fit
