Author Topic: Whats in my Coils?  (Read 2544 times)
Whats in my Coils?
« on: December 04, 2021, 09:53:25 PM »
I thought some of you might be interested in seeing what's inside a coil
This was taken off my Convert, missing badly on one cylinder
The only thing I found was the case has bulged out at the end, note how the replacement is concave but this ones convex.
[/url]
I initially thought it had lost all the oil so I weighed it carefully, it compared favourably. One thing I did notice was hairline cracks in the top, perhaps its leaking to ground.
 I cut through the case with a hacksaw and dropped the parts into a plastic container
The coils can be separated quite easily, the primary is on the outside, Secondary inside, it connects to the bottom of the soft iron core which
is insulated from the case by the ceramic part you can see bottom right. The core connects to the top terminal via a Z shaped piece of steel.
The primary coil is wound from 22 BSWG, the secondary is probably the finest wire I have seen 33 BSWG (British Standard Wire Gauge)
« Last Edit: December 04, 2021, 10:45:32 PM by Kiwi_Roy »
Offline jrt
Re: Whats in my Coils?
« Reply #1 on: December 04, 2021, 10:09:04 PM »
I had always assumed that they are just step-up coils.  Is the visible (big) coil the primary?  I would think that would be the secondary.
What are dozen or so pieces of white metal?  Looks like aluminum (aluminum)- are the spacers?
Thanks for posting- this is interesting.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
« Reply #2 on: December 04, 2021, 10:28:27 PM »
Yes the big coil is Primary
The metal pieces are Stalloy I believe Wikipedia says soft iron. they use thin strips of iron rather than a solid piece or the eddy currents would damp it down. Similar to transformers and electric motors
The only spacer is the white ceramic one at the bottom of the can, the top of the coils rest on the 4 knife edges you can see under the top.
https://www.google.ca/search?q=what+metal+is+used+for+the+core+in+transformers&sxsrf=AOaemvJIQyREuCae46uQjnFUkHCZCVMugg%3A1638679577868&ei=GUSsYb2_NLzW0PEPyqWxqAM&ved=0ahUKEwj9r46R7cv0AhU8KzQIHcpSDDUQ4dUDCA0&uact=5&oq=what+metal+is+used+for+the+core+in+transformers&gs_lcp=Cgdnd3Mtd2l6EAMyCAghEBYQHRAeMggIIRAWEB0QHjoHCAAQRxCwAzoHCCMQsQIQJzoECAAQCjoHCAAQgAQQCjoFCAAQgAQ6BAgjECc6CAgAEIAEELEDOgsIABCABBCxAxCDAToFCAAQkQI6CAgAEIAEEMkDOggILhCABBCxAzoFCC4QgAQ6BQgAEJIDOgUIABCxAzoGCAAQFhAeSgQIQRgAUIMNWN-tAWDFtAFoAXABeACAAfMBiAHVHpIBBjUwLjIuMZgBAKABAcgBCMABAQ&sclient=gws-wiz
« Last Edit: December 04, 2021, 10:49:40 PM by Kiwi_Roy »
Offline moto-uno
« Reply #3 on: December 05, 2021, 04:05:07 PM »
  So when are you going to wind a few of your own ? :evil: . Peter
Offline SED
« Reply #4 on: December 05, 2021, 10:36:29 PM »
Cool post Roy  :thumb:  Thank you for the pictures and explanation.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Rough Edge racing
« Reply #5 on: December 06, 2021, 11:27:09 AM »
Kettering ignition system coils are DC and not really step up transformers like  used on AC...
Offline Alfetta
« Reply #6 on: December 06, 2021, 01:30:37 PM »
Well..  there it is... The coil failed due to Lucas wiring !!!
Online Groover
    • Scooteropolis
« Reply #7 on: December 06, 2021, 02:20:14 PM »
Thanks for sharing this post and photos. This saves me from opening one myself that was on my list of things to do!  :azn:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
