Author Topic: rubber glue? some GC  (Read 1761 times)
« on: December 16, 2021, 12:47:42 PM »
I just drug the MZ out of hibernation after 2 years (!!) of sitting in SoCal. Amazingly enough to me, the lead acid battery that was on a battery tender is still up.  :shocked:
Here's the question. It uses the same turnsignals as the guzzi spine frames, and 3 of them are hanging by the wiring. Naturlly, I'd like to repair them (moreGuzzi content) and am wondering what kind of adhesive would be most likely to do the job.
Offline RinkRat II
  • Lake Powell AZ
Re: rubber glue? some GC
« Reply #1 on: December 16, 2021, 01:24:11 PM »
     When I shortened my KLR signals, after cutting down  the hard rubber they're made from I drilled some 1/16" diameter holes 1/8" deep on both flat areas in a star pattern and JB Welded them back together. I wrapped tape around the seam for strength and let them cure for 24 hours. Been fine for 12 years. My $.02
      Paul B  :boozing:
Offline normzone
« Reply #2 on: December 16, 2021, 02:03:41 PM »
If you find yourself down this way I'm looking for an excuse to ride ...
« Reply #3 on: December 16, 2021, 02:36:40 PM »
Thanks, Paul. .JB in my hand.  :smiley: Hiya Norman most likely won't make the journey. .
Offline Ncdan
« Reply #4 on: December 16, 2021, 02:43:28 PM »
I went through this with all four signals on my 02 Stone.
Once the rubber has deteriorated to the point they brake off just by hitting bumps, for the most part they are finished and the rubber part will need replacing. I found they can be matched and mismatched with other models of MG bikes. New ones can also be found.
I found glueing to only be a temporary fix.
Dan
« Last Edit: December 16, 2021, 02:45:16 PM by Ncdan »
Online LowRyter
« Reply #5 on: December 16, 2021, 06:35:30 PM »
I've had some luck with my EV signals using epoxy and heavy rubber bands for clamps.  Not sure from description whether it's plastic/rubber on metal or plastic on plastic.  That might give a hint for the type of adhesive.  I think whether JB or generic it's all epoxy but matched different materials.  In my case I needed the rubber/plastic epoxy.  Careful to rough up the surface for the resin to nest.
Regarding the rubber band, I hooked it over the light and the flange, keeping the rubber band parallel to the stalk.  Let it set overnight.
Offline Guzzidad
« Reply #6 on: December 16, 2021, 07:19:43 PM »
   I suspect they are similar to the signals on my Triumph Sprint. My local Triumph dealer had just the stalks in stock for $5 each. Easy fix. I think AF1 Racing used to stock them as well. My dealer is Motorcycle Enthusiasts in Spring Hill FL.
Offline bad Chad
« Reply #7 on: December 16, 2021, 07:40:51 PM »
Duh!  Call the OEM, order the parts, install
Really, you slay me chuck, it’s 2021, it’s not like you can’t get parts.  :afro:
Offline 80CX100
« Reply #8 on: December 16, 2021, 08:23:39 PM »
      I don't know much about MZ's, but my impression was, it's not that simple with that brand, fwiw idk.
      Re the glue, if they're rubber, possibly auto weatherstripping adhesive,,, if they're plastic, I've used Fletchtite (archery supply store) similar to old fashioned model airplane glue.
      For turn signal stalks bouncing around with the vibration, is it something that you could mcgyver a big piece of heat shrink tubing with adhesive onto it to help support the repair?
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
« Reply #9 on: December 17, 2021, 08:04:20 AM »
Hmmmm.. heat shrink tubing That's thinking out of the box. I like it. :smiley:
Online John A
« Reply #10 on: December 17, 2021, 11:12:53 AM »
3M makes thick walled heat shrink with heat activated glue on the inside that may be perfect.
Offline guzzista
« Reply #12 on: December 17, 2021, 03:58:50 PM »
Chuck: If you want new signals, I have a pair of "generic" (not CEV) signals of that style and will send them to you for the cost of postage.
« Reply #13 on: December 17, 2021, 05:53:48 PM »
That's very kind of you, Charlie. I'll keep that in mind. "Assuming" I get the MZ going, I'll hang out at Mark's and maybe buy some. I'm doing some orthdontia and glue on these 3 as we speak. Sitting 2 blocks from the ocean for 2 years is not a nice thing to do to a motorcycle, btw..  :smiley: One of the instrument cluster shock mounts has gone to rubber heaven, too.
