Please post up your "bringing it back to life" steps and success!
Fully expect the clutch to be “stuck” after sitting that long….start in neutral ( of course ) but even with clutch lever pulled in when engaging first she’ll try to take off in a run. Many suggested ways to break ‘er loose…. I’ve come to like the pulling up to a brick wall trick. Not an issue once freed up.
Thanks,good advice. If the clutch is stuck, would spraying something through the inspection hole, or with the starter off be recommended?
Yes, average life span is 7 years. Big Crank is Deka with a different sticker.
It's looking good, John.
Great news! Sounds like it wasn't too hard to get it going again. Hopefully you don't end up with several leaking seals.
I have successfully repaired broken seat pans with epoxy fiberglass. (e-glass)Regular polyester fiberglass would probably work on top of initial epoxy to save money if additional strength and build-up was desired. Regular fiberglass resin may stick fine, but I did not try that. The criss-cross pattern in the patch was disposable perforated aluminum barbecue grills to form a sub matrix in gaping holes.It looks better when covered up and has held up fine for a year. Before trying this, I would have judged the solo police seat pan for Tonti to be beyond restoration. It won't win at the concourse, but seems to be good and serviceable.
