Author Topic: Cylinder search  (Read 1545 times)
Offline wymple
Cylinder search
« on: March 06, 2022, 10:51:14 PM »
I need another cylinder for my 84 Cal 2. Looking at the old one, it looks as if the only difference between right & left side is a slot for clearance at the bottom of the bore. If I find one for the other side it looks to me like all I need do is add another slot 180* off? Other than the slot they look identical to me & I don't see the harm in adding a slot...??  Or am I looking at it wrong?
« Last Edit: March 06, 2022, 11:03:05 PM by wymple »
Re: Cylinder search
« Reply #1 on: March 07, 2022, 12:09:30 PM »
I think he means the cutout for the rod.
Online John A
Re: Cylinder search
« Reply #2 on: March 07, 2022, 12:53:35 PM »
I might have a serviceable cylinder, it’s 88mm isn’t it? I’ll start looking…
Offline TOMB
Re: Cylinder search
« Reply #3 on: March 07, 2022, 12:59:38 PM »
If the cyl is for the right side make sure it has the cutout to fit around the distributer on the bottom left of the cyl as you look down
The slots ar the same , as others have said its for the con rod.
Earlier versions of the engine round barrel the cyl would fit either side , then came square cyl so now there is a different cyl. for each  side .
TOMB
« Last Edit: March 07, 2022, 01:03:05 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline wymple
Re: Cylinder search
« Reply #4 on: March 07, 2022, 01:07:49 PM »
Standard  California @, 1984. I think that is 88 mm. I'm looking for the right side. I see them around, but cannot judge the cylinder walls from pictures they post. And most of what I see are for some reason, left side. I just thought a left cylinder might be altered a touch for use on the right.
Offline brider
Re: Cylinder search
« Reply #5 on: March 08, 2022, 06:53:34 PM »
Just for the fun factor, has anyone put a round fin and square fin on the same engine?
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Offline TOMB
Re: Cylinder search
« Reply #6 on: March 08, 2022, 08:25:10 PM »
I haven't but i thing the stud spacing is a different dimensional spread, others will chime in .
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
Offline dxhall
Offline wymple
Re: Cylinder search
« Reply #8 on: March 09, 2022, 01:46:11 PM »
No. Those are the earlier round fin cylinders.
