Author Topic: Interesting video on oil viscosities...  (Read 1135 times)
« on: March 12, 2022, 09:19:10 AM »
Now that I own vehicles that are using 0w20 and wonder if efficiency is gained at the expense of longevity, I feel better after watching this video.
https://www.youtube.com/watch?v=IKdhgKUZhPA
Offline Huzo
Re: Interesting video on oil viscosities...
« Reply #1 on: March 12, 2022, 01:24:26 PM »
I’ve just watched multiple videos on this topic.
Each one explains it differently.
One of them said that a 10 W 60 oil, relates to the viscosity at low and high temps.
It’s viscosity is a lower number 10 (thinner), at startup and higher number (thicker), at 100 deg C.
So why does the oil drain out better when hot than cold ?
I swear I will NEVER understand this.
Oh and yes...
Another oil thread.
« Last Edit: March 12, 2022, 01:25:59 PM by Huzo »
Offline Huzo
Offline Ncdan
« Reply #3 on: March 12, 2022, 04:06:12 PM »
As long as theses no arguments who cares🤔😂👍
Dan
Offline lucky phil
« Reply #4 on: March 12, 2022, 05:05:12 PM »
Oh and yes...
Another oil thread.
It's the classic misconception Huzo. Think of it this way. Any oil gets thinner as it's temperature rises so a 40,50,60 weight measured at 100 deg C where the SAE measuring point is for engine oils will always be thinner than even a zero weight at room temp or 40 deg C where the low number SAE measuring point is. The upper number is an equivalency measurement or number for the oils viscosity at 100 deg C. So the upper number says "this oil is equivalent to" an 40, 50, 60 weight oil at 100 deg C all of which are thinner than a zero weight at room temp (40 deg C). Two different baseline measurement points. Think of it as two separate viscosity measurements one at 40 deg C (lower or W number)and one at 100 deg C the upper number just put together for convenience of identification.
Ciao
« Last Edit: March 12, 2022, 05:12:32 PM by lucky phil »
Offline Huzo
« Reply #5 on: March 12, 2022, 08:20:52 PM »
Ciao
Ok Phil.
I’ll digest your words.
