Author Topic: Lower footpegs for V7 II  (Read 18294 times)
Offline La Dolce Guzzi
« on: March 12, 2022, 07:25:11 PM »
Hi Guzzi pilots,
What are the options for lowering the footpegs on a  2015 V7 II?
I'm already aware of the Knight Design lowering footpegs...but at $200 a pair it's too rich for my diet!
Any other cheaper options or hacks out there...perhaps footpegs from another bike brand or adventure bike might fit?
Offline Off @ 90
  • Heron Head Heretic.
Re: Lower footpegs for V7 II
« Reply #1 on: March 12, 2022, 08:21:05 PM »
Honda Goldwing 1800 fit straight on and are about 10-12 mm lower . I fitted them to my Stornello to replace the solid ally OEM ones . The Honda ones are long enough to give some leg clearance with the Arrow pipe on RH side very comfy. About $50 on line seem well made . Older Honda CB bike pegs fit straight on too but not as long or wide as the GW pegs.
Duncan
« Reply #2 on: March 12, 2022, 10:18:42 PM »
Thanks Duncan for the solid tip. I wear size 46 (12.5) riding boots so would appreciate a roomier footpeg. I might be able to adjust the shift lever up 10-12mm too for even more room.
Could I ask what year GL1800 your pegs are from? I want to make sure I order the right model. Also, if it's not too much of a bother would you be able to upload a pic?
Offline Bulldog9
« Reply #3 on: March 13, 2022, 04:37:40 AM »
I put these on my Norge and Stornello, they work very well, and are pretty cheap on fleabay.
MGNOC#23231
Offline aproud1
« Reply #4 on: March 13, 2022, 08:45:58 AM »
I have them on my V85TT. Seem to work for most modern Guzzis. Mine were from a 2021 Gold wing (according to the eBay seller). Work great for me and just a little lower. The Knight designs are really nice but yeah $$$$
The Past: ‘76 KZ400S, ‘06 VN750 (pita), ‘18 V7III Milano, '20 V85TT McD, ‘21 W800,  ‘81 CB650C
Offline Off @ 90
« Reply #5 on: March 13, 2022, 02:07:38 PM »
No luck uploading image . They are on EBay  Description - Front Driver Footrest Footpeg Pedals for Honda Goldwing GL1800 2001-2017  dimensions are there too .
Duncan
Offline midnite
« Reply #6 on: March 13, 2022, 02:51:47 PM »
Another vote for KD: spends, but if you’re going to spend time with the bike, we’ll worry it IMO. I have them (1”) on a Griso and V7ii.
Offline Roebling3
« Reply #7 on: March 13, 2022, 04:41:52 PM »
A caution: Be aware of the limited lean angle. Folding pegs for certain.  R3~
« Reply #8 on: March 13, 2022, 05:13:38 PM »
Thanks for giving it a go mate. Appreciate the ebay description which is very helpful.
« Reply #9 on: March 13, 2022, 05:18:41 PM »
Thanks Guzzi pilots for all your comments. I'll be giving the GW ones a go!
Offline toomanybikes
« Reply #10 on: April 15, 2026, 03:29:34 PM »
Going back to an old thread.
Similar to the GL1800, has anyone tried Honda Valkyrie pegs on a V7? Seems like they have even more of a drop than the Goldwings?
Offline Vagrant
« Reply #11 on: April 15, 2026, 04:59:51 PM »
The GL 1800 will fit on a 17 III but not the earlier v7 series. I don't know about the Valkyrie ones.
« Reply #12 on: April 16, 2026, 05:18:46 AM »
Since others have said that Honda CB pegs might also work, I'm assuming Honda mostly uses the same mounting dimensions as Guzzi. If that's not the case, I have a few vintage Honda projects that could also benefit from lower pegs.
« Reply #13 on: April 23, 2026, 08:11:21 AM »
one more data point, the image below shows a V7 peg compared to a V85TT peg with the rubber removed, a one minute job. Looks to lower the foot position by 3/4". Not a big platform like the GL1800's, but another easy option if you can source V85 pegs.
« Reply #14 on: April 27, 2026, 05:53:47 PM »
A detailed question ... did you re-use the guzzi springs and pivot shaft or did your Honda pegs come with their related parts?
I bought some cheapo Chinese GL knock-offs (that didn't come with springs or shafts) and while most of the peg dimensions were compatible with Guzzi, the hole for the pivot shaft was further away from the peg body, making the Guzzi spring unable to contact the peg. Those are going back.
For the time being, I just took teh rubber pad off the Guzzi stock pegs, which effectively lowers them by >1/2"
« Last Edit: April 27, 2026, 05:54:41 PM by toomanybikes »
Offline Vagrant
« Reply #15 on: April 28, 2026, 09:55:44 AM »
I used an old screw off spark plug cap to lengthen my stock springs. A piece of hollow steel tube would work to.
« Reply #16 on: April 29, 2026, 02:59:23 PM »
For posterity, a red electrical paddle connector also works to extend the outboard portion of the spring. It stays in place better than the spark plugs tips, at least on the open ended NGKs I hand on hand.
Now to see how long the Chinesium foot pegs last.
« Last Edit: April 29, 2026, 05:08:18 PM by toomanybikes »
Offline jrt
« Reply #17 on: April 29, 2026, 06:55:13 PM »
I think I have a pair, but they are definitely used and worn a bit.  Yours free for shipping if you want them.  Send me a PM if interested.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline Vagrant
« Reply #18 on: April 30, 2026, 08:46:00 AM »
The Chinese pegs hold up fine but the rubber will wear through in 6-10000 miles. No biggie.
« Reply #19 on: April 30, 2026, 08:53:07 AM »
Thanks, I have MBS (multi-bike syndrome), so it will take me a while to get 6-10K miles on the V7.
