I’ve always used the mid-grade for my 2013 and can’t remember why even though it’s worked well.Do I need to?
Yeah and the manual also said it takes 2 liters of oil a lot of which showed up in the air box until I started putting in 1.7 liters .
Notwithstanding anyone else's empirical experience, I avoid e10 at all costs unless no other alternative exists.Time spent in a professional shop watching techs clean/rebuild dozens of fuel delivery systems is all I needed to see.When away from home I carry single use pre-measured Yamaha engine Rx for E10 fuel. One per fill-up and at least I can avoid any long term exposure to E10. It's a fun challenge to arrive back from a ride-away with JUST enough left in the tank to get into the garage.I know, I know; "I've used E10, never did anything, and had no issues since, well, ever." Good for you. Carry on. I've seen otherwise so many times.............. ................... .....I don't expect this to be universal.
E10's probably the reason that Goldwing didn't make it over the bridge.
E10 works ok if used within a few months. If a machine is going to sit idle for months, non-ethanol gas does make a difference. Non-ethanol gas for the last tank before winter is a good thing for a motorcycle.Non-ethanol gas is good for mowers, snow blowers, and any other engine you start every once in a while.
I'm in the no issues from E-10 camp and even when E-Free is available I typically skip it as its typically much more expensive I have to wonder if the turnover is there. I'll take fresh E-10 over old E-free and I'll take either over pushing the bike because it ran out of gas. Now onto fuel treatment AKA magic in a can. Does it actually do anything other than lighten your wallet? My favorite is Startron "enzyme" fuel treatment. I use it on cheap cuts of meat (one ounce to 1 pound) to tenderized them. Since there are no proteins in gasoline (the only thing enzymes break down) having enzymes in a "fuel treatment" are about as worthless a wiping before you poop. Stabil is another favorite. A mixture of Napata and kerosene dyed red used at a 1 ounce to stabilize 321 ounces of fuel it mitigates the effects of up to 32 ounces of ethanol. Now that is some powerful I mean powdered unicorn horn powerful stuff. Heck it borderline Sham-Wow amazing in its claimed abilities . You know the as seen on TZV towel that could soak up 3 billion times it own weight in liquid.
The lowest grade of fuel that does not ping/knock is the right grade fuel for your engine.
