Author Topic: V9 max torque  (Read 1950 times)
Offline tris
V9 max torque
« on: March 19, 2022, 01:30:10 AM »
I read somewhere the other day tha the V9 lump delivers peak torque at just 3000 rpm.
Is that right.
If it is,  it goes a long way in explaining why it feels similar to the B1100 I used to own at lower speeds
1993 TW125 "POS" - Resting
Offline chrisfer
Re: V9 max torque
« Reply #1 on: March 19, 2022, 03:57:30 AM »
« Last Edit: March 19, 2022, 03:58:45 AM by chrisfer »
2022 V7 850 Stone - 2019 V7 III Carbon - 2004 V11 RossoCorsa - 2002 V11 Le Mans - 1995 750 Nevada
Offline tris
Re: V9 max torque
« Reply #2 on: March 20, 2022, 02:46:38 AM »
Cheers,  it was a similar article that prompted the question
The similar sized V7iii an V85 seem to have their peak torques at virtually double the RPM with not a massive increase in peak torque
I just find it interesting
Offline chrisfer
Re: V9 max torque
« Reply #3 on: March 20, 2022, 03:49:30 AM »
Having a maximum torque at 6000 rpm does not necessarily mean that there is less at 3000 rpm.
Offline SSGG Geezer
Re: V9 max torque
« Reply #4 on: March 20, 2022, 11:23:48 AM »
I thought that the increase to 59 Ft/Lbs was significant. Even at 5000 RPM on the 21 V85 models.  The curve being fairly flat is the important part, at least to me when I ride. I see no big peaks when twisting the throttle a bit harder than normal.  I may need to test ride a V7 to see if the difference in character s great when combined with a lighter motorcycle.
Offline tris
Re: V9 max torque
« Reply #5 on: March 21, 2022, 05:08:11 AM »
POSSIBLY SOLVED - it's another bit of random Moto Guzzi data /typo
Chart is from Moto Guzzi (blue dotted line is mine) and max torque is clearly not at 3K!
https://www.cycleworld.com/moto-guzzi-v9-motorcycle-engine-history-and-evolution/
« Last Edit: March 21, 2022, 05:23:41 AM by tris »
Re: V9 max torque
« Reply #6 on: March 21, 2022, 06:08:26 AM »
I suspect strongly the error is in the graphic not that data.
It's an issue of resolution/accuracy of the graphic. Multiple separate Dyno reports (including CW in their verbal summary) give peak torque as listed at an rpm around 3k or within a few hundred rpm. It's much more likely that figure is exact from the Dyno summary than the graphic, especially the simplified graphic used in that CW article.
References:
CW: 45.7 lb.-ft. of peak torque at 3,000 rpm
Motorcycle.com: 46.4 ft. lbs. @ 3200 rpm
Rider: 47.3 ft. lbs. @ 3500 rpm
EDIT - that said, as others have noted, the more significant part is the flatness of the curve. But I also think the V9 motor feels different (better) than the V85, as it does in fact come on stronger/lower, and doesn't have the dip the V85 has shown in some curves. I also think I liked the V9 better than the V7III or V7850 when it comes to that feel.
I do know that I felt like I NEEDED to spin the V85 much more than the V9 in the same conditions.
« Last Edit: March 21, 2022, 08:03:44 AM by Kev m »
Offline bad Chad
Re: V9 max torque
« Reply #7 on: March 21, 2022, 06:57:39 AM »
Just shift at 6500, like I do.  :cool:
1988 YX600 Radian
Offline Milosh
Re: V9 max torque
« Reply #8 on: March 21, 2022, 07:28:58 AM »
But the torque "curve" is flat as can be. And it feels that way for sure. :bike-037:
___________________ ___________________ __
β€œAn inconvenience is only an adventure wrongly considered; an adventure is an inconvenience rightly considered.” – G.K. Chesterton
Offline tris
Re: V9 max torque
« Reply #9 on: March 21, 2022, 09:31:56 AM »
A Fair point and I'm happy to concede it Kev!!
The flatness of the curve as Milosh says from 3k makes it great fun!!
Re: V9 max torque
« Reply #10 on: March 21, 2022, 10:16:51 AM »
Cheers.... I still want a V9.... I just don't want to get rid of anything else in the fleet (well, I would get rid of the Duc, but Jenn would skin me alive so that's not an option).
