For what it is worth (I have no solutions to provide yet), my 2021 V85TT is doing the same thing. Cruise control works, but can't be changed up or down by using the toggle like it did before. Yes, this feature did work before, but since I had the first service done recently at the dealer, I believe they re-flashed the ECU and now it doesn't work. Another odd thing that is happening since the service is that the check engine light rapidly flashes when I reach 5500 RPM every time, and then stays on until I shut the bike off. Upon restart, the check engine light is out, and will stay out until I hit 5500 RPM, and then stay on until the bike is shut down. I have no solutions yet, but suspect it has something to do with the re-flash that was done. I am hoping to get the bike back in very soon for them to check it out and will provide updates.
UPDATE as promised!Today I went to the dealer for an update.Apparently the Italians forgot to put some things in the update before.I noticed severall things after the update I got earlier:- Bad pickup during warm weather 30°C and up- Less difference between Sport and Rain mode feeling- HIGH mileage 3,8L /100km mixed use but it felt like I lost 20 horsepower- Cruise up/down set/resume not working anymore- Engine running not smooth- very unsteady on the gasToday I got a new update and all those things are solved. It runs even better than before the earlier update now.It seems that the engine was running realy lean to the point it was not healthy anymore. Also fixed by the update.I'm happy again
I have a 2020 V85TT and found the CC to be finicky at first. Starting point read the owners manual on CC operation. In my manual it starts on page 100. The only long hold on the CC button is to enable or disable the CC. As an example once engaged and the speed is set and the clutch or brake is hit the CC is disengaged. Now to resume press up on the button for no more than 0.6 seconds, this will resume. A long hold will not do anything. The same is true for the accelerate and decelerate. A short bump up or down, not a long hold. Just like to set your speed a short central bump will do the trick a long hold will turn the CC off.
Luap, you might try resetting the throttle as Huzo describes in reply #18.
Yep. Tried that too. Thanks.
