Author Topic: 98 EV Tuneup setting TPS question  (Read 4659 times)
Offline bigbikerrick
Re: 98 EV Tuneup setting TPS question
« Reply #30 on: May 05, 2022, 10:06:41 AM »
Phil, That is one of the nicest V 11 sports I have ever seen. Congratulations on a fantastic build!  I would like to let the group know, I am currently running a tps from CA  Cycleworks  that Patrick Hayes recommended, and it made a huge difference in the bikes performance. They sent the paper printout from when  the unit was tested, which is good to know. I set the MV at around 450, and its running great, idles smoothly, and the plugs electrodes look a nice light brown color. I think I needed the extra MV due to the fact that I have an H pipe, K&N filter, and open mufflers.  I have been getting about 35-37 mpg. I am very happy with the way my EV is running,
  Thanks again, to Patrick, Phil, and the rest of the group, for all the help in getting this bikes FI sorted.
Rick Duarte
Online scra99tch
« Reply #31 on: May 05, 2022, 12:37:59 PM »
You using Guzzidiag by chance for your voltage, if not use the pigtail with a voltmeter for more accurate results.
2007 California Vintage
« Reply #32 on: May 05, 2022, 04:17:52 PM »
I use a pigtail , that I made,from the tps connector where I plug in my multimeter. I had a Guzzidiag cable from Lonelec but gave it away with my Griso.
Rick.
