Author Topic: *** WARNING - OIL THREAD ***  (Read 4597 times)
Offline kballowe
  • - Kevin the Great -
Re: *** WARNING - OIL THREAD ***
« Reply #30 on: April 01, 2022, 04:48:48 PM »
  Eni or Silkolene  10/60  New crush aluminum if I have one if not a light wipe of three bond on both sides.  Best to stay with aluminum crush on an aluminum pan. I do like the fancy ones with the rubber ring in them.
That Silkolene is red.  Yes?
Offline lucky phil
« Reply #31 on: April 02, 2022, 01:58:37 AM »
Motul 10w60 7100 sg rated Kev  :boozing:
I refuse to use Motul oils because I can't find a proper spec sheet for them. Lots of advertising junk but no detailed spec sheet with ZDDP numbers for example.
Ciao
Offline Old Jock
« Reply #32 on: April 02, 2022, 03:49:04 AM »
Re JJ's comments on the Centauro all the HiCams recommended 20/50, not to mention all the 2 V/V models as well.
It should be noted that 10/60 was not available at the time these bikes were manufactured AFAIK.
Some of the stage C HiCams run hot others less so and I have no idea why.
Monitoring temp and pressure I found 15/50 too thin to handle the higher temps on my engine.
I only move to a different grade though if I have evidence that the engine requires it.
It's not a huge job to put on a couple of gauges (temporary or permanent) and check what pressure and temp are, but few bother.
Re Phil's comment, that's why I moved away from Motul as well.
I want to know what's in the oil I'm putting into the bike and plan to either to stick with the Penrite or perhaps try Royal Purple.
« Reply #33 on: April 02, 2022, 05:10:59 AM »
OK, who is using 10W-60 motor oil in their late model Moto Guzzi ?
Yes.
Norge and V85.
« Reply #34 on: April 02, 2022, 05:15:38 AM »
For those of you using Motul.....
WHICH Motul ?
Motul 10 W 60 full synthetic and 90 in the gearbox and bevels.
Penrite 140 for the V85 bevels.
The ONLY time it gets something else is the intermediate change @ 10,000 k in Italy at Agostini’s.
« Last Edit: April 02, 2022, 05:17:42 AM by Huzo »
Offline kballowe
« Reply #35 on: April 02, 2022, 08:49:54 AM »
Yes, but Motul :
5100 ?
7100 ?
8100?
other ?
« Reply #36 on: April 02, 2022, 09:02:04 AM »
Yes, but Motul :
5100 ?
7100 ?
8100?
other ?
Always was 5100. Now 7100,
duplicate email finder
 the 5100 stopped being available.
I don’t know the difference.
My Norge now has 197,000 km and uses less than a litre every 10,000 k.
So it’s not doing it any harm.
« Reply #37 on: April 02, 2022, 09:45:01 AM »
Note that Guzzi issued a tech bulletin quite a while ago super-seeding the old 1100 oil recommendation from the old spec to 10w-60 except for the hydro motors.
I've posted a pic of the spec sheet but it's not on my new computer anymore, so there's that.
Offline 9fingers
« Reply #38 on: April 02, 2022, 10:37:42 AM »
I do. Castrol Edge Supercar in my 2020 V7III Special. She seems happy.
Scott
Current bikes:
V7 Corsa - Athena
Suzuki V Strom 650 - Rita
Beta Rev 3 270
Honda TLR200 custom
Honda TL250 custom
TL250 stock
Honda TL125
Yamaha TY350
Online Caffeineo
  • Guzzi B00b
« Reply #39 on: April 02, 2022, 10:50:18 AM »
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Offline bad Chad
« Reply #40 on: April 02, 2022, 04:42:36 PM »
Any quality 100%ester 10w60 will meet warranty requirements. Mogul 7100 is such oil made for street bikes.
The fun thing about synthetic oil is they can be made in any color and sent.   Have you ever smelled Motul 7100?  It smells hand soap or body lotion!
Offline lucian
« Reply #41 on: April 02, 2022, 04:49:37 PM »
 Never smelled Motul 7100 but I've smelled their 5100 and it smells like pine cones
Offline lucian
« Reply #42 on: April 02, 2022, 04:53:41 PM »
 Dunno its always black when I drain it
Offline lucky phil
« Reply #43 on: April 02, 2022, 05:04:32 PM »
As can mineral oils, even glow in the dark with an ultraviolet light to track oil leaks. It's only a dye additive.
Ciao
« Reply #44 on: April 02, 2022, 06:08:05 PM »
Just for FUN... :cool: :boozing: :thumb: :bow: :wink:...a few vintage Motor Oil signs...
Offline kballowe
« Reply #45 on: April 03, 2022, 06:56:52 AM »
I dunno.
I'm not convinced.
These are Italian motorcycles.  Surely, there is something more appropriate.....
Offline lucian
« Reply #46 on: April 03, 2022, 07:53:41 AM »
Does that come in 10/60 or 85/90?
Offline kballowe
« Reply #47 on: April 03, 2022, 08:15:57 AM »
It works for everything.  Crankcase, bevel box, gear box, fish, eggs, chicken, pork chops..........
Offline bad Chad
« Reply #48 on: April 03, 2022, 08:38:52 AM »
If I only collected a $100 bill every time someone made the olive oil joke on this board, I would have enough for a really fat down payment on a new Mandelo V100!
« Reply #49 on: April 03, 2022, 11:49:40 AM »
No Italian worth their their salt would ever use olive oil labeled "extra lite" or some sense nonsense.
My Sicilian family would have you whacked if they saw that in a family members kitchen.
« Reply #50 on: April 03, 2022, 12:15:41 PM »
Agree with that one...100% EXTRA VIRGIN Olive Oil or nothing!! :laugh: :grin: :wink:
Offline old head
« Reply #51 on: April 03, 2022, 02:15:05 PM »
First oil change, I went with mobil 1 15w50.  MPH did some warranty work and they put in 10w40 Amzoil, then I went back to 15w50 Mobile 1.  One very hot day in stop and go traffic the oil light came one.  too be fair, the oil temp switch had been weeping so, was it the oil or sensor?  Don't know.
never had another oil light come on after I changed the switch, and switched to 20w60.  I suspect w50 is probably ok, as the w60 probably breaks down pretty fast with that wide weight range.  However, the difference in price isn't that big and if the factory recommends w60, who am I to out think the engineers who designed the engine.
doesn't get very cold here in the swamp, but it does get hot and very humid in the summer.
I bought a case of redline 20w60 and used it till now.  I used the last bottle last change, so I got some Liqui MOly 10w60 for my next change.
Old Head
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
« Reply #52 on: April 03, 2022, 02:53:19 PM »
C'mon now...vintage oil cans seen at the local Antique Mall - $20-$25 EACH!!
 :rolleyes: :shocked: :huh: :laugh: :grin: :wink: :bow: :thumb: :cool: :boozing:
