Author Topic: 75W-90 or 75W-140 ???  (Read 2346 times)
Online kballowe
  • - Kevin the Great -
« on: April 05, 2022, 10:52:29 AM »
While reviewing maintenance logs for the last six or eight Moto Guzzi's - it appears that the transmission/rear pumpkin lubrication recommendations are different.
The most recent comparison is that our 2020 Eldorado 1400 specs 75W-90 for both.
This new V7 850 specs 75W-140 for both.
Past rear drive pumpkin specs were for 80-90 GL4.
Online Guzzistajohn
Re: 75W-90 or 75W-140 ???
« Reply #1 on: April 05, 2022, 11:44:30 AM »
That Kevin, always trying to start a fight!  :sad:
Online bad Chad
« Reply #2 on: April 05, 2022, 11:47:02 AM »
I would stick with spec, there must be a reason for it.   And on the off chance something went south in the pumpkin, and you had non spec fluid, well, that might not work out so well.
Offline Old Jock
« Reply #3 on: April 05, 2022, 12:40:24 PM »
I'm not familiar with the latest Guzzis, my knowledge stop pre carc
In general though I don't think the difference in viscosities on the multigrades is as critical as an engine oil.
The gearbox and transmission run way cooler than the engine, so although there will be a difference in the viscosities at running temp between the 2 different specs mentioned, it's probably not as much as most people think.
« Reply #4 on: April 05, 2022, 12:51:21 PM »
Mussent be good ridin weather today.
Online kballowe
« Reply #5 on: April 05, 2022, 03:01:13 PM »
How about this one ?
Ya'all just drop by.  We'll just change ya out.  I have a 50 year supply.
« Last Edit: April 05, 2022, 03:06:29 PM by kballowe »
Offline Chatmanx
« Reply #6 on: April 05, 2022, 03:28:28 PM »
Let me know if I have this wrong.
They are the same base 75 weight. They differ in modifiers that keep them from breaking down at higher temperatures. So, if the temperatures are the same in a V9 or Eldorado then both will behave as if they are 75-90. However, if there is something different about the V bikes and the V bikes operate at much higher temperatures, then it will be helpful for them to behave as if they were heavier weights up to 140.
Offline pressureangle
« Reply #7 on: April 05, 2022, 03:56:30 PM »
I just did a deep dive into gear oils, found a couple things;
Sulphur and Molybdenum Disulphide (Moly) create acids under high heat, which deteriorates the base oil, and perhaps the metals in use. Boron based EP additives have no such issue. I'll be using Chevron Delo ESI 80w90, after a lot of navel-gazing. They have a 85w140, but Chevron says follow the manufacturer's recommendation for viscosity. Delo ESI meets the harshest manufacturer's criteria, including Meritor and Mack 500,000 mile service intervals.
I did not try to discover if the usual suspects were Sulphur or Boron. IIRC Bel-Ray also uses boron EP additives. I've used Redline in the past and been happy with it; don't know that the Chevron is any easier to source.
https://www.chevronlubricants.com/en_us/home/products/delo-gear-esi-80w-90.html
Online kballowe
« Reply #8 on: April 05, 2022, 04:39:21 PM »
A friend of mine bought a case of this Genuine Honda shaft drive oil - and then decided on a different product.  It's been sitting on the shelf here for a couple of years.  It says that it is recommended for Gold Wings.
A little shaft drive oil goes a long way.
[/img]
Online lucian
« Reply #9 on: April 05, 2022, 05:11:30 PM »
Oil thread with no WARNING .  moderator , we need a ruling.
Offline Chatmanx
« Reply #10 on: April 05, 2022, 05:30:48 PM »
Before we are canceled, fun fact is that 80 weight differential oil is really 40 weight. 75 is 30 weight. They used a much higher number to discourage people from confusing the two.
« Reply #11 on: April 05, 2022, 08:32:28 PM »
Fortnine says the W means Winter, not weight.  As in 75W(inter) - 90.
Online jrt
« Reply #12 on: April 05, 2022, 10:48:50 PM »
Hey! Watch your language- I have kids! :police:
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline Huzo
« Reply #13 on: April 05, 2022, 11:46:21 PM »
Well, you didn’t need telling then... :wink:
Online kballowe
« Reply #14 on: April 06, 2022, 06:02:06 AM »
It's only a matter of  :clock:
 :boozing: :boozing: :boozing:
Offline chuck peterson
« Reply #15 on: April 06, 2022, 06:05:07 AM »
BB vs SB difference
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Online kballowe
« Reply #16 on: April 06, 2022, 06:25:03 AM »
BB vs SB difference
You may have something there......
Offline Vagrant
« Reply #17 on: April 06, 2022, 10:07:33 AM »
They put an oil pump in the V7Iii tranny and cut the quantities in 1/2. V85 doesn't have one. Don't know about the V7-850. How much does the tranny hold?
Online kballowe
« Reply #18 on: April 06, 2022, 10:22:26 AM »
1,750 CC engine oil
500   CC transmission lube
180   CC rear drive pumpkin
« Last Edit: April 06, 2022, 10:24:11 AM by kballowe »
Online kballowe
« Reply #19 on: April 06, 2022, 07:18:35 PM »
Offline Vagrant
« Reply #20 on: April 06, 2022, 07:24:11 PM »
I bet they put a pump in it
« Reply #21 on: April 07, 2022, 04:50:23 AM »
First difference I noticed moving to a SB is the rear “pumpkin” change in viscosity per spec
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #22 on: April 07, 2022, 07:46:47 AM »
[/img]
if it has been sitting on the shelf for a couple years, check the expiration date!!   :wink:
I recently found some stuff in the refrigerator that expired a couple years ago!
2019 Beta EVO 250
