Author Topic: Tire pressure  (Read 3922 times)
Offline rudyr
Tire pressure
« on: May 12, 2022, 05:28:03 AM »
My Harley friend that bough a new V85, told me that my  2021 V85  model ( I think it’s travler)has tire pressure monitor, question dose it?Rudy
Offline Caffeineo
  • Guzzi B00b
Re: Tire pressure
« Reply #1 on: May 12, 2022, 10:57:44 AM »
No. I just got a cheap one off eBay for my 2022 and having a challenge getting it to work. :(
https://www.ebay.com/itm/234531730163
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Online Vagrant
Re: Tire pressure
« Reply #2 on: May 12, 2022, 11:44:17 AM »
That's why I always suggest a US seller with a good rep and return policy, and lots of them sold.
Offline egschade
Re: Tire pressure
« Reply #3 on: May 12, 2022, 11:44:50 AM »
I bought this on on Amazon and after 6 months it's still working well. I run 40 PSI in the rear tire and 36 PSI in the front.
https://www.amazon.com/gp/product/B08MKV76LS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline Chatmanx
Re: Tire pressure
« Reply #4 on: May 12, 2022, 01:03:10 PM »
I bought the Steelmate version. STEEL MATE Motorcycle Tire Pressure Monitoring System - Universal TPMS for Motorcycle Oversized LCD Screen with Display Time in Real Time and Tire Pressure Reading System
I like the large numbers, simple hose clamp attachment to the handlebars (won't break), the use of 2 aaa batteries that are easy to replace, and the time display comes in handy.
Offline Caffeineo
  • Guzzi B00b
Re: Tire pressure
« Reply #5 on: May 12, 2022, 03:53:30 PM »
I've bought two of the solar units (one off Amazon the other off eBay). Both were no issue to get operational. basically screw the tire sensors on the valve stem and the display, displayed the current tire pressure. It took a bit to figure out the the different settings because the direction are in Martian and about 0.0023 font.
Not sure there is much of a challenge. Either they do or do not work?
Reading the Google translate directions....I need to scroll through the menu and get to the screen where it syncs with the front monitor and then syncs with the rear monitor. Both are synced but the rear reads 00 and the warning blinks and beeps???? USA seller and he asked for a video that I just sent. I do like the idea now that I have seen them in use. Beats checking the pressure monthly. ;)
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Offline Gino
Re: Tire pressure
« Reply #6 on: May 12, 2022, 04:07:13 PM »
I just bought a 2022 travel , I does have tyre pressure monitoring as standard (in the uk )
Gino
Online Bulldog9
Re: Tire pressure
« Reply #7 on: May 14, 2022, 07:57:41 AM »
I have had 3 of these (Stornello, MGX, 1200 Sport), the oldest is on the Stornello, 4 years and works perfectly. Batteries in the wheel sensors last 2 years. Really like being able to see my tire pressure while riding.
https://www.amazon.com/dp/B07BFH9WZ7/ref=redir_mobile_desktop?_encoding=UTF8&aaxitk=c01d833f8784e1dc8809b725e2baa63f&hsa_cr_id=2707845720201&pd_rd_plhdr=t&pd_rd_r=3d4c4eb7-f730-4cbb-9e11-56fe34ea597d&pd_rd_w=f0rT3&pd_rd_wg=0o6i9&ref_=sbx_be_s_sparkle_mcd_asin_0_title
« Last Edit: May 14, 2022, 08:12:04 AM by Bulldog9 »
MGNOC#23231
Offline Chatmanx
Re: Tire pressure
« Reply #8 on: May 14, 2022, 09:32:48 AM »
Caffeineo,
the directions may not be the same at all but when doing mine, the section about recognizing and setting f & r pressures clearly said to do the f, then the r and then enter. NO. You have to enter the front before doing the rear. Don't mean to hyjack but I had the same problem and got the same results as you when following the instructions. Also, the part about losing air pressure at the valve until recognized was odd.
Good luck
Offline Caffeineo
  • Guzzi B00b
Re: Tire pressure
« Reply #9 on: May 14, 2022, 11:09:17 AM »
Caffeineo,
Good luck
Thanks. Think I will see if I can reset or clear all the entries and give it another go before returning it. Could easily be something not quite translated properly by Google.
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Re: Tire pressure
« Reply #10 on: May 14, 2022, 11:25:46 AM »
I was in the dealership yesterday looking at the V85 TT, the salesman told me to wait for a V85 TT Traveler, said they have slightly smaller bags, no top box heated grips and upgraded electrical package so maybe the tire pressure monitor is part of that. Bluetooth to your cellphone perhaps?
I looked at several spec sheets for the Traveller but I have no confidence in them.
Do you have your Traveler yet?
Perhaps list just the special features it has.
Never mind, I see Gino cleared that up a few posts back.
« Last Edit: May 14, 2022, 11:53:03 AM by Kiwi_Roy »
Offline Caffeineo
  • Guzzi B00b
Re: Tire pressure
« Reply #11 on: May 18, 2022, 08:12:07 PM »
The seller asked me to check the battery voltage on the rear wheel sensor. Battery is good and I think that reset it as it started working. All is good now.  :thumb:
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Offline egschade
Re: Tire pressure
« Reply #12 on: May 19, 2022, 07:20:40 AM »
Using my TPMS I notice a 10% rise in rear tire pressure during a ride. It goes from 40 PSI cold to 44. The front is less, going from 36 to 38.
I've read that this is normal for tube tires. Have others experienced the same thing?
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Online Vagrant
Re: Tire pressure
« Reply #13 on: May 19, 2022, 07:49:26 AM »
I've run these for 15 years and 300,000 miles. Smartest thing to do is just ignore anything but low pressure.
The fronts will run 6-10% higher when hot and the rears run 10-20% higher. It all depends on type or brand of tire, speed, road surface and outside temps.
Now what will really drive you nuts is when you leave on an overnight trip at 9am and 70 degrees out and you are at 36 front and 42 rear. You wake up the next morning at 6000 feet and 30 degrees out and you're at 26 & 32.
Re: Tire pressure
« Reply #14 on: May 19, 2022, 12:43:28 PM »
Yeah. The 10% rule says that you may have a little too much pressure in the front. Whether it has a tube or not doesn't matter, AFAIK.
Offline Gino
Re: Tire pressure
« Reply #15 on: May 20, 2022, 05:53:13 PM »
:grin: :grin:
Online Bulldog9
Re: Tire pressure
« Reply #16 on: May 20, 2022, 06:26:31 PM »
Did about 150 miles today in 95f temps, running 60-70mph.  Front went from cold 38 to 42, and rear went from 39 to 45 while on a hot stretch of new black asphalt at 70+ mph. I think 10%  front, and 20% rear is a normal/safe increase. The stock Golden Tyre and tube on the Stornello was 4lbs / 10%, but the new heavy IRC tube and Shinko 705 is 6lbs and closer to 20% made me nervous at first, but has yet to go above 46lbs.
Sometimes knowledge is misery, not power. I like having real time pressure updates, and it helps eliminate worry when road conditions make you question tire pressure, but the #'s can also cause concern..... oh well
MGNOC#23231
Offline smsw
Re: Tire pressure
« Reply #17 on: May 20, 2022, 07:05:06 PM »
Pressures in car and bike tires have gone up as tires heat up due to rolling and flexing friction for as long as tires have been on bikes and cars.  As long as your tires are inflated per the mfr's recommendatons (and under the maximum pressure on the side of the tire) you will be fine.
Offline jacksonracingcomau
Re: Tire pressure
« Reply #18 on: May 21, 2022, 07:22:57 AM »
Brilliant, I’d always thought these things a touch unnecessary, never ever thought of the educational value.
Reading this could help
https://www.mcnews.com.au/dorna-respond-to-motogp-tyre-pressure-controversy/
Online Cam3512
Re: Tire pressure
« Reply #19 on: May 21, 2022, 08:11:10 AM »
Thanks Steve, you just talked me into spending more money!  On its way…
Cam
Online Bulldog9
Re: Tire pressure
« Reply #20 on: May 21, 2022, 02:18:01 PM »
Cam
Here for you brother............ .
MGNOC#23231
Online Vagrant
Re: Tire pressure
« Reply #21 on: May 21, 2022, 04:28:15 PM »
Now, if you want to drive yourself to drink start looking at the temperatures!
