Author Topic: Broke down in flagstaff  (Read 4737 times)
Online groundhog105
« on: May 13, 2022, 08:44:23 AM »
Is there anyone near Flagstaff Arizona that can assist me with getting my Griso to a temporary place to store while I rent a car to go home and return with a trailer.   The bike was making metallic noise out of the right head then quit running.    Phone is 619-884-7790.   I’m at a motel presently
Offline Road Rocket
Re: Broke down in flagstaff
« Reply #1 on: May 13, 2022, 02:21:43 PM »
Bringing it to the top.....Try a bike shop, maybe they know someone who will haul it for you....Good luck
Rough Edge Racing with a new name but still the same pin head
Online RinkRat II
  • Lake Powell AZ
« Reply #2 on: May 13, 2022, 02:48:25 PM »
 Possible contact....Eurogeek Motorsport  928-226-1068 located there in Flag.
    Paul B :boozing:
« Reply #3 on: May 13, 2022, 03:44:49 PM »
Quit running on both sides but noisy on only the right ?
Offline moto
  • Fear the deer!
« Reply #4 on: May 13, 2022, 04:15:43 PM »
If you have a basic membership in the American Motorcycle Assn your benefits include a free tow to any location within a certain radius, either 25 or 35 miles. It doesn't have to be a repair shop. Good luck.
850 T-3
Griso 1100 corretto
Online Tom H
« Reply #5 on: May 13, 2022, 06:08:38 PM »
Sorry I can't be of help. A bump to the top is what I can do.
As mentioned, maybe the bike shop can store it for you. AAA will also tow bikes if you have the RV add on.
Good luck,
Online groundhog105
« Reply #6 on: May 13, 2022, 06:25:36 PM »
Thanks for all the suggestions.   I had ordered a tow to take it to Prescott when my brother called and is headed my way.  The problem is with the right cylinder.  I. Was getting a loud metallic sound in  the right cylinder and then it started dropping out then quit. I didn’t have much in the way of tools (left them home this time because the griso has always been bulletproof) I did take the cover off and all the adjustment nuts were there and tight so without any tools that’s as far as I went.  Im wondering if it’s the cam chain tensioner that has failed but at 19thousand I wouldn’t think so.
Thanks Tom.  I do have the RV AAA and was set to use it when my brother called.
« Last Edit: May 13, 2022, 06:27:25 PM by groundhog105 »
« Reply #7 on: May 13, 2022, 07:03:14 PM »
Sorry I could not be of assistance as I have guests in town this weekend that I have to entertain.
I was going to suggest Jim and team at Powersports Outlet in Prescott, as they are the closest official and authorized Moto Guzzi dealer in northern Arizona.  Mechanically, they should be able to diagnose the problem and help you.  Keep us posted and good luck with your Griso.
JJ
Online Tom H
« Reply #8 on: May 13, 2022, 07:04:46 PM »
Sorry for your troubles. At least your in a safe enough place and not stuck on the side of a road.
Good luck on the tow and the fix!
Online groundhog105
« Reply #9 on: May 13, 2022, 09:19:48 PM »
JJ
Thanks JJ.  That’s where I was going to go.  I’ve stopped in to see those guys several time.  Seems to be a great shop
Offline egschade
  • Eric S - MGNOC NJ Rep - mgnocnj.forumotion.com
« Reply #10 on: May 14, 2022, 06:40:49 AM »
"  The bike was making metallic noise out of the right head then quit running.  "
Sorry to read about your predicament but as others have already said, at least you safe.
You probably know but just in case, early year 1200 came with flawed flat valve tappets that wear quickly and can cause problems. Factory upgraded to roller tappets mid-2012. My SE was one of the first to have the rollers from the factory. Tons of info and knowledge on Griso Ghetto if you weren't aware.
Whatever the problem hopefully it's a straightforward fix and not overly expensive.
The elder Eric in NJ
2016 V7 Stornello #394
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
« Reply #11 on: May 14, 2022, 06:46:10 AM »
Uhh, yeah. Pete probably can tell you off the top of his head what is going on..I'll PM you his address.
« Reply #12 on: May 14, 2022, 08:35:33 AM »
Might help if we knew what year Griso?  Early 1100's are bulletproof, later 1200 4V motors not so much unless after 2013.
Online Tom H
« Reply #13 on: May 14, 2022, 08:28:01 PM »
Please give us a heads up that your good and then when you find out the problem, let us know.
bobrebos
« Reply #14 on: May 15, 2022, 01:13:37 AM »
Best of luck to you in hoping you can get it fixed and not be stranded to long.  I’ve been stranded twice lately on my 2013 Stelvio.  Not a fun feeling and leaves one questioning the bikes reliability!
« Reply #15 on: May 16, 2022, 08:11:57 AM »
Just read on GT he's back in CA, broken valve springs on intake of 17' 8V motor.
Offline Bigtime
« Reply #16 on: May 16, 2022, 08:19:18 AM »
  There's a guy on the ADV forum that broke a valve spring on his Stelvio. I think he was at about 100k when it broke. He replaced the spring and now has about 125k on it. Still going strong.
« Reply #17 on: May 16, 2022, 08:58:38 AM »
I know anything can happen anytime...anywhere. ..to any bike...but somehow, this just does not sound right...?????
Defective / broken valve spring?  Metal fatigue?  Poor quality control at the factory?  Other?  :rolleyes: :shocked: :huh:
« Reply #18 on: May 16, 2022, 09:50:29 AM »
Broken valve spring. Well, there's a new one.
« Reply #19 on: May 16, 2022, 11:54:03 AM »
It's not the 1st one i've seen. Been a few around the world. Not many though compared to production.
« Reply #20 on: May 16, 2022, 06:23:21 PM »
He said the bike rattled then stopped.
A broken valve spring will only stop half of the motor, the good side will help destroy the bad side and Guzzisteve reports that it’s broken valve SPRINGS (plural).
How do you break more than one spring ?
Surely when the first on lets go, you drop compression on that side and she runs on one ?
If it’s dumped a spring, then the valve has probably given the piston a kiss and they’ve “made friends”… :sad:
I hark back to the fact that she’s died on BOTH sides, that’s not a valve spring issue.
Jeez, these damn 4 valve heads are finicky bastards. Lovely when they’re going, but…….Jeeeez.
« Last Edit: May 16, 2022, 06:36:00 PM by Huzo »
Online groundhog105
« Reply #21 on: May 17, 2022, 08:45:31 PM »
Sorry I haven’t posted a follow up here.  I got the bike home and pulled the valve cover to find the intake valve next to the cam chain was in the open position and the spring appears to be collapsed or broken.  I recovered the two keepers and the valve cap from on top of the head but couldn’t find the part of the adjuster the sets on top of the valve stem.  This motor has never been reved over 7K or abused so I’m at a loss for an explanation.  The bike only has about 19,000 miles on it.
« Last Edit: May 17, 2022, 08:51:07 PM by groundhog105 »
« Reply #22 on: May 18, 2022, 12:42:45 PM »
Well I guess it’s…”off with her head…”
Hope like hell the valve hasn’t contacted the piston or exhaust valve and replace the bits.
Why did the first one let go ?
Dunno.
But you will when you get it our on the bench. It’s immaterial now anyway, if the stem is straight then there’s been no tangling, get a new valve, springs, collets and stuff.
Throw the whole lot in .
BTW..
So the bike didn’t actually stop, it just dropped onto one cylinder…?
Online groundhog105
« Reply #23 on: May 18, 2022, 09:30:03 PM »
Huzo
    It dropped to one cylinder and I shut it down.
« Reply #24 on: May 19, 2022, 02:01:04 AM »
That makes more sense,
Online groundhog105
« Reply #25 on: May 19, 2022, 08:11:34 PM »
Update for those interested.  I took the Griso to Todd Eagan yesterday and found out today that the damage is limited to the head. I need a new valve,spring, valve guide and valve adjuster.  I feel fortunate there was no damage to the piston and cylinder.
« Reply #26 on: May 19, 2022, 08:20:45 PM »
hope you're on the road again.
Online Tom H
« Reply #27 on: May 19, 2022, 08:47:36 PM »
Thanks for the update. Could have been worse. Please let us know if they find why the failure.
« Reply #28 on: May 19, 2022, 09:33:38 PM »
Good update...and good news for the potential to be on the road again soon!! :thumb: :bow: :boozing: :cool:
Online nc43bsa
« Reply #29 on: May 19, 2022, 11:07:15 PM »
One of the reasons I like Guzzis;  they're so easy to work on.
Can you imagine having to make the same repair on a water-cooled 4vpc inline 4?
« Last Edit: May 20, 2022, 12:18:53 PM by nc43bsa »
1990 MilleGT
