Author Topic: V9 Roamer Engine Map  (Read 1826 times)
Offline tris
« on: May 17, 2022, 12:51:06 AM »
Does anyone know what the latest map is for a 17 plate Roamer?
It's a UK bike if that makes any difference
Cheers
Tris
« Last Edit: May 17, 2022, 05:33:38 AM by tris »
1993 TW125 "POS" - Resting
Offline Alfetta
Re: V9 Roamer Engine Map
« Reply #1 on: May 17, 2022, 08:34:32 AM »
The fact that you said "17 plate" kinda tipped the location....
Sorry, nothing to help with your question, but i am wondering what is driving your desire to play with the map ?
are you not happy with the stock map, or are you looking to make serious modifications ?
Cheers, mate
Offline tris
« Reply #2 on: May 17, 2022, 09:00:52 AM »
No - not looking to mess with the map
It's just that mine has a snatchy throttle from trailing to just on - negotiating a tight roundabout for example
When I first got the bike I messed about with checking the trace of the TPS and got the blue line below and felt that the sharp step between 10 & 20 degrees might be the root cause
So decided that a different throttle tube might work.
It's now got one from a Caponord (needed a bit of modifying but I didn't want to cough up for the G2 throttle tamer)
It softened things a little but not enough (orange line) I
I wondered if the OEM had updated the map that addressed  the issue and if they had I'd empty the piggy bank and send it to the dealer for a service
If mines the latest map I'll have another fettle of the throttle cables, valve gaps, plugs etc. and see if I can improve matters.
Failing that I'll ride it 24 hours a day for the next month and see if I can educate my throttle hand :wink:
Offline Caffeineo
  • Guzzi B00b
« Reply #3 on: May 17, 2022, 12:32:46 PM »
I put a Beetle map on my 2019 Bobber Sport. Best $100 spent on a bike. Yes it ran good before but it just ran better overall with the Beetle map. Still got 59 MPG as I could not go easy enough to break into the 60 range.  :evil:
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
