Author Topic: Sipea Neiman ignition switch dissassembly  (Read 1384 times)
Offline Semitone
« on: May 17, 2022, 08:01:07 PM »
Hello folks. I lost the key for my ‘75 850t and removed the Sipea Neiman ignition switch with the intention of pulling the tumbler to bring to a locksmith to get a key made, but there is a spring loaded pin from the tumbler that is engaged in a hole in the ignition housing that I can’t push in to release tumbler. Am I right to assume that you actually can’t remove it without the key? If so, do I have any options other than replacing the switch? Many thanks, Paul
Paul
'75 850T
'73 Norton Commando 850
'65 Honda CB160
'70 Honda CB350
'65 Suzuki K11
Re: Sipea Neiman ignition switch dissassembly
« Reply #1 on: May 17, 2022, 08:43:36 PM »
Pretty sure you need the key to depress that spring loaded pin.
Here's some information that might help (or not).
https://www.thisoldtractor.com/moto_guzzi_tonti_v7_sport_ignition_switch_replacement.html
Offline Semitone
« Reply #2 on: May 18, 2022, 09:01:23 AM »
Thanks ACC. I already reached out to Greg and he said he thought it was possible, but has never done it. P
Paul
'75 850T
'65 Honda CB160
'70 Honda CB350
'65 Suzuki K11
