Author Topic: yamaha turn off after 10 seconds?  (Read 1498 times)
Offline harley21
« on: May 21, 2022, 08:44:56 AM »
Hey guys,
I just did some maintenance on an outboard Yamaha 9.9 4 stroke that I hadn't used in about a year. I replaced the impeller, and the spark plugs, and i cleaned the carburater, (incl the needle valve). Now my motor starts easily but while running a lot of fuel is getting in the water, I've checked for loose tubes but nothing seems to be leaking. I think the fuel is coming from the exhaust. After about 10 to 15 seconds of running in neutral, the motor shuts off, and won't start again. After waiting for an hour or more, the motor will start again and do the same thing. I think the engine may be getting too much fuel. But the gas handle connected to the throttle cable inside the motor can't be pushed in any further.
Any advice?
Re: yamaha turn off after 10 seconds?
« Reply #1 on: May 21, 2022, 09:10:16 AM »
Float bowl not floating or wrongly adjusted?
Offline Moparnut72
« Reply #2 on: May 21, 2022, 11:53:13 AM »
Sounds like the float needle valve may be sticking open or mal-adjusted.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline aklawok
« Reply #3 on: May 22, 2022, 01:19:39 AM »
x3 on needle/float. sometimes a good rap or two on the side of carb with the end of a screwdriver hit with something is enough to jostle it free, otherwise u r stuck r+r the carb again.
2007 california vintage
