Author Topic: Norge TPS  (Read 970 times)
Offline Bison
Norge TPS
« on: May 22, 2022, 05:42:56 AM »
Hi Folks,
Are all Magneti Marelli TPS with the number PF1C/00 created equal?. I've found that sensor is fitted to lots of european cars, Alfa's, Fiats etc. It looks identical, the number is the same, it says Magneti Marelli on it, and it's much cheaper than OEM. I do remember reading that the same sensor is fitted to some Harleys, but doesn't work very well on a Guzzi?, that's why I thought I would ask.
I know many people prefer to fit OEM parts, so please be gentle!.
Just thought of another question, can the tip over sensor simply be removed by unplugging?
Thanks for your patience,
Alan.
« Last Edit: May 22, 2022, 06:18:48 AM by Bison »
Re: Norge TPS
« Reply #1 on: May 22, 2022, 08:53:13 AM »
No need to use HD, try these guys-------------------------------------
https://ca-cycleworks.com/efi.html
Unplugging the tip over will throw a code.
« Last Edit: May 22, 2022, 08:59:44 AM by guzzisteve »
Offline Bison
Re: Norge TPS
« Reply #2 on: May 22, 2022, 10:41:00 AM »
Hi Guzzisteve,
Thanks for the reply.
I'm in Europe, so many car parts places will have the original magneti marelli part,  I think!. .I just wanted to check that , if the only thing I could get for some reason, was an equivilant, it would work OK.
Good info on the tip over switch,  thanks.
Cheers
Alan.
