Author Topic: Oil pressure sensor adapter?  (Read 1321 times)
Online Pescatore
« on: May 30, 2022, 01:09:04 PM »
I would like to measure the oil pressure on my small block V65.
I'm not trying to make a full time monitor, just checking how it varies.
The stock pressure sensor looks like this, with a long stem:
The pressure sensors I find online look like this, shorter:
Does anyone know what might happen if I use the shorter sensor?  Will it measure wrong, or will oil get into bad places?
Some time ago I saw an adapter, just the stem portion, and I can't find it anymore.
I also will add the 1/8 thread to M12 adapter and a 90 elbow to keep it under the air box.
Thanks,
P
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Frenchfrog
Re: Oil pressure sensor adapter?
« Reply #1 on: May 30, 2022, 01:29:42 PM »
The pin part of the original part is crucial...earlier smallblocs used a two piece sender set up but god knows where you would get that from.I think the pin bit has something to do with camshaft bearing location.
Offline Frenchfrog
« Reply #2 on: May 30, 2022, 01:42:44 PM »
« Reply #3 on: May 30, 2022, 02:21:53 PM »
Neither one. What *will* happen is the cam bearing will rotate, and you will "be in a heap of trouble, boy.."  :smiley:
« Reply #4 on: May 30, 2022, 04:03:06 PM »
$25  from MG cycle to do it right w/light.
« Reply #5 on: May 30, 2022, 04:45:48 PM »
Just hook up a 0-100 psi gauge then, it will run at ~60 psi
You can hook it to the pressure switch or either of the lines supplying the valve gear, they are at full system pressure, there is a flow restrictor in the head.
« Reply #6 on: May 30, 2022, 09:33:24 PM »
Do the modern small block oil pressure switches still have the locating pin for the cam bearing?
Edit: I reread . They do.  I must have been feeling good….. :boozing:
« Last Edit: May 31, 2022, 09:21:56 AM by John A »
Online Pescatore
« Reply #7 on: May 31, 2022, 10:44:52 AM »
Thanks for the info about the bearing.  I'm glad I didn't turn the engine while I had the switch out.
Is it the half bearing #23, or a bearing in the engine casing?  Just trying to visualize the purpose of the stem.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Frenchfrog
« Reply #8 on: May 31, 2022, 02:44:19 PM »
That's the one !
Online Pescatore
« Reply #9 on: May 31, 2022, 03:04:54 PM »
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
