Author Topic: Valve clearance  (Read 6338 times)
czakky82
Valve clearance
« on: May 31, 2022, 07:35:13 PM »
I’m running in my 73’V7 Sport w/fresh cam, followers, guides, valves. Seats were good.
I set this up as normal (for me) by setting valves to .009”, torque heads, re-torque and set clearance a few days later. Ran it up to temp, heat cycled again, re-torque, do valves. I’ve read about running in a fresh cam and flat tappets by keeping steady RPMs at 2k for a few minutes. So I did that. Went for two 15-20mile break-in runs. Then I did my latest torque/valve setting.
Cripes! Clearances were mostly all closed up like I’ve never seen! LH Ex .008”(normal) LH In .004” RH Ex .0025” RH In .006”.
I’ve refreshed atleast three Guzzi top ends and a few others. Never seen them tighten up like that!
Is that normal?
I was hoping to hold off until another few hundred miles like I normally do before checking again. Not sure I’m comfortable going that long now.
Re: Valve clearance
« Reply #1 on: May 31, 2022, 07:59:21 PM »
That seems normal, I seen them w/no lash. After the 1st retorque I usually run 300mi or more checking the lash & making it .009". Then one last time on retorque. I also make them tight- 34ftlbs . I only do them twice.
Offline cappisj1
Re: Valve clearance
« Reply #2 on: May 31, 2022, 08:17:38 PM »
I just put new piston and cylinders on my 75 T. I did not measure them after running the first couple times but the .009 was not going to get in there.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
czakky82
Re: Valve clearance
« Reply #3 on: June 01, 2022, 06:02:52 AM »
Thanks guys, I’ve never seen them close up so much. I’ve never done a cam and followers either.
Offline TOMB
Re: Valve clearance
« Reply #4 on: June 01, 2022, 06:45:11 AM »
Here's my take retorquing the heads with a head gasket and there if it's new will take quite a few times to compress it and will finally find its place and stay set for the torque as far as the valve clearances go in my cases when the valves were put in  lap brand new valves cetera are conforming to the seat now the seat is a taper so is the valve it will conform to the seat in the valve together but it will also recessed slightly into the seat and it's closing up your clearances hope that makes some sense and this will also stabilized the clearances for longer periods of time
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline moto-uno
Re: Valve clearance
« Reply #5 on: June 01, 2022, 07:04:53 PM »
  Took a few times , but I got what you're saying , next time I might suggest saying it
in a few sentences  :thumb: .  Peter
Re: Valve clearance
« Reply #6 on: June 02, 2022, 07:28:11 PM »
Apparently it is common. When I checked my new Norge back in 07 the factory had set them at .014 and .015. Apparently they figured they'd close up before the first service.
Offline Don G
Re: Valve clearance
« Reply #7 on: June 03, 2022, 06:05:08 PM »
Its better to have the clearance disappear and expect it than to have clearances widening, as this bodes disaster :cry:.  Be happy.  DonG
« Last Edit: June 03, 2022, 06:06:33 PM by Don G »
czakky82
Re: Valve clearance
« Reply #8 on: June 25, 2022, 09:35:21 AM »
Cripes! Now the clearance is opening up. Both intakes were .002” wider after only 80 miles. I must be doing something wrong.
Re: Valve clearance
« Reply #9 on: June 25, 2022, 11:37:23 AM »
That’s weird.
Re: Valve clearance
« Reply #10 on: June 25, 2022, 12:40:49 PM »
Keep a eye on it , getting wider could be caused by some bad things. The worst would be cam& lifter wear on the new cam.  Could be collapsed pushrods, especially the aluminum ones. Hopefully it’s a measurement error.
Re: Valve clearance
« Reply #11 on: June 25, 2022, 03:40:01 PM »
Yeah, I can't think of anything good to say about clearances opening up. I *assume* you are setting/checking them the same way at the same engine temperature?
czakky82
Re: Valve clearance
« Reply #12 on: June 25, 2022, 03:58:40 PM »
Yeah, I am checking them on a cold engine. I will run them for 50 miles and check again. I’m not too worried yet….
I should add that I did just replace the rocker arm shafts as two of them appeared to have lost some small amount of plating. The new ones appear to be hardened.
« Last Edit: June 25, 2022, 04:03:10 PM by czakky82 »
Re: Valve clearance
« Reply #13 on: June 25, 2022, 05:51:56 PM »
FWIW, the old ones were hardened, too.. probably induction case hardening. Not plated.  If that case starts to go.. bad things happen. Maybe that is what you are finding. (?)Fingers crossed..
czakky82
Re: Valve clearance
« Reply #14 on: August 08, 2022, 08:21:14 PM »
Yeah, not good…I’ve been checking clearance every 500 miles and it continues to open up.
All four valves had opened up atleast .002” worst was .004”. I set them to 6 and 8 originally.
Rockers and shafts look good. Cam and followers are new and oil looked good, I dropped the pan just to check, I have an external filter setup as well. Compression was 170 both, cold.
My thoughts turn to either pushrods or cam “bearings”.
How do I diagnose bad pushrods, I don’t have accurate enough measurement tools for this length.
Re: Valve clearance
« Reply #15 on: August 09, 2022, 12:43:53 AM »
Compare pushrods to each other, check the ends for looseness. Ring test to see if they sound the same, roll them on a piece of glass. If you replace them, get steel ones. Check the valves for stretching or receding.
Re: Valve clearance
« Reply #16 on: August 09, 2022, 08:58:05 AM »
Both of those would cause clearance to close up, not open up.
Re: Valve clearance
« Reply #17 on: August 09, 2022, 10:01:05 AM »
Yep, it was late and brain was running on mt
czakky82
Re: Valve clearance
« Reply #18 on: August 14, 2022, 11:14:25 AM »
I had a thought. It looks like HMB sells a one size cam follower. I didn’t realize that short stroke BBs have different pushrod ends….
Hopefully my new followers aren’t too beat up. I might try to use some of the later pushrods I have here, although they might be too short.
Wish me luck! :boozing:
czakky82
Re: Valve clearance
« Reply #19 on: September 02, 2022, 09:27:55 AM »
Well that sucks!
I now have the correct pushrods. Lash still opened up after only 200miles!….
I double checked to verify correct rockers and these dont match what Guzziology describes as correct. The adjuster screw boss measures 11mm (guzziology says they should be 14mm) but they appear to be what is in other early BBs just going off pics.
Even if my lifters were wearing would they wear that fast?
I never did check cam runout, but there was no noticeable play.
What am I missing before tearing off the top end?
czakky82
Re: Valve clearance
« Reply #20 on: September 03, 2022, 08:40:49 AM »
Full lift on exhaust and intake. Does the rocker angle look extreme?
Offline Scout63
Re: Valve clearance
« Reply #21 on: September 04, 2022, 10:25:50 AM »
All the big blocks I’ve done have 11mm adjuster lock nuts. Strange spec. Just thoughts, but are the small head bolt oil seal rings in their correct position?  Is TDC accurate on your flywheel? I would take the heads off, check the base gasket and oil rings, check TDC and start over.
Ben Zehnder - Orleans, MA USA
Offline Stretch
Re: Valve clearance
« Reply #22 on: September 04, 2022, 04:10:55 PM »
I'm not sure I'd be too concerned just yet.
Check 'em every 500 miles or so and see if they stabilize
after 2K to 3K. If things are still changing lots after 3K, then
you've maybe got some trouble. Run some more heat cycles
so that everything can find it's happy place. YMMV.
New cams and pushrods - there's lots to change there, especially if all is
not factory.
Good Luck!
                                                -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
czakky82
Re: Valve clearance
« Reply #23 on: September 04, 2022, 05:16:21 PM »
@scout, early BBs have 13mm lock nuts made of the finest Italian hard cheese (soft). I made my own TDC marks on the bench, with a piston stop. Good point, will check again though. Thanks for the input.
@stretch, thanks for putting my mind at ease a little.
Here’s where my head goes. If it was bad lifter(s) I’d only likely see one or two. Same with collapsed pushrods. Cam bearings I’d be losing oil pressure and timing would be sloppy. It squirts oil when I rotate the wheel in 5th gear and timing is as stable as any ignition I’ve seen.
Offline Vagrant
Re: Valve clearance
« Reply #24 on: September 05, 2022, 09:52:02 AM »
My 98 EV wore like that the first 1500 miles. 10 thousands larger at 1500 than where they were set at the 600 first set. Settled down after that and quit completely at 20000 when I changed to full synthetic oil.
czakky82
Re: Valve clearance
« Reply #25 on: September 05, 2022, 10:56:22 AM »
You have no idea how much better I feel! I will keep an eye on it.
czakky82
Re: Valve clearance
« Reply #26 on: September 12, 2022, 08:23:42 AM »
So much for feeling better…
Re: Valve clearance
« Reply #27 on: September 12, 2022, 08:43:44 AM »
Are those the "V7 Sport" Gilardonis you got from GTM? Look like plain old Ambassador pistons without the valve relief to me. V7 Sport pistons will have the relief for this very reason...
czakky82
Re: Valve clearance
« Reply #28 on: September 12, 2022, 08:57:02 AM »
Sure are… measured at 82.5mm and I read somewhere that there were v7 pistons without an intake pocket. So I went with it… :violent1:
Re: Valve clearance
« Reply #29 on: September 12, 2022, 09:53:06 AM »
Crap. That definitely looks like a warranty claim to me.. as we say in Indiana.. "that ain't rat."
