Thanks for the info. I believe the ignition blanks are Silca ISP2 or ILCO IP 63SP. I found F14 stamped next to the key hole, thinking its code used to cut the key. If I'm successful, I'll post the details. I believe the fork lock blanks are is Ilco SR61N or N2M, Silca NE5, JMA NE6, or Taylor B69K. I may elect to just buy a new lock set for the forks once I get the courage to remove the old lock from my pristine frame (would have been so easy before...).
