Author Topic: Alternator Mount- Brush holder  (Read 4752 times)
Offline Frenchfrog
Re: Alternator Mount- Brush holder
« Reply #30 on: June 11, 2022, 06:48:12 AM »
So wher are you at now? Curious minds must know !! :boozing:
Offline Jens_L
« Reply #31 on: June 15, 2022, 02:09:37 AM »
I had some spacers turned .1mm in between, outside diameter 14.8mm, inside diameter 8.5mm.
In this way I can adjust the spacing between the Silent Hektik rotor and the hall sensor if necessary.
As long as the brushes are in full contact with the alternator collector, I think there should be no problems.
Will make a picture when mounted!
Offline Frenchfrog
« Reply #32 on: June 15, 2022, 03:39:02 AM »
Good man ! You might need to adjust the alternator cover too.With the sachse you certainly have to ;either by putting washers behind it, getting one of their deeper covers or cover spacers.
